System / notification sounds dropping after a reboot
After each of the last reboots my system / notification sounds keep getting dropped down to 40% from 150%, and I have to go in and adjust it back to 150%. Anyone have any idea what might be causing this? Thanks
[alienprober@TheMotrhership ~]$ inxi -Fxxxza
  Kernel: 5.8.13-arch1-1 x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux
  root=UUID=128d1d7c-1028-4416-b91d-882b6c7c7d2b rw rootflags=subvol=@
  quiet loglevel=3 nowatchdog
  Desktop: KDE Plasma 5.19.90 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
  Distro: EndeavourOS
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING
  v: Rev 1.xx serial: <filter> UEFI: American Megatrends v: 3103
  date: 06/17/2020
Battery:
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse
  serial: <filter> charge: 55% (should be ignored) rechargeable: yes
  status: Discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
  serial: <filter> charge: 100% (should be ignored) rechargeable: yes
  status: Discharging
  Info: Quad Core model: AMD Ryzen 3 3200G with Radeon Vega Graphics
  bits: 64 type: MCP arch: Zen+ family: 17 (23) model-id: 18 (24)
  stepping: 1 microcode: 8108109 L2 cache: 2048 KiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 28762
  Speed: 2865 MHz min/max: 1400/3600 MHz boost: enabled
  Core speeds (MHz): 1: 1680 2: 1263 3: 1305 4: 1394
  Vulnerabilities: Type: itlb_multihit status: Not affected
  Type: spec_store_bypass
  mitigation: Speculative Store Bypass disabled via prctl and seccomp
  Type: spectre_v1
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
  STIBP: disabled, RSB filling
  Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: eVga.com.
  driver: nvidia v: 455.28 bus ID: 01:00.0 chip ID: 10de:2187
  Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: nvidia
  note: display driver n/a display ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1080 s-dpi: 97 s-size: 670x283mm (26.4x11.1")
  s-diag: 727mm (28.6")
  Monitor-1: HDMI-0 res: 2560x1080 hz: 60 dpi: 97
  size: 673x284mm (26.5x11.2") diag: 730mm (28.8")
  OpenGL: renderer: GeForce GTX 1650 SUPER/PCIe/SSE2
  v: 4.6.0 NVIDIA 455.28 direct render: Yes
  Device-1: NVIDIA TU116 High Definition Audio vendor: eVga.com.
  driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:1aeb
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus ID: 0a:00.6 chip ID: 1022:15e3
  Sound Server: ALSA v: k5.8.13-arch1-1
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
  v: 5.6.0-k port: d000 bus ID: 04:00.0 chip ID: 8086:1539
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 16.38 TiB used: 7.55 TiB (46.1%)
  ID-1: /dev/nvme0n1 model: Viper M.2 VPN100 size: 238.47 GiB
  block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  serial: <filter> rev: ECFM22.6 scheme: GPT
  ID-2: /dev/sda vendor: Western Digital model: WD10EARS-00Y5B1
  size: 931.51 GiB block size: physical: 512 B logical: 512 B
  speed: 3.0 Gb/s serial: <filter> rev: 0A80 scheme: GPT
  ID-3: /dev/sdb vendor: Seagate model: ST3000DM001-1E6166
  size: 2.73 TiB block size: physical: 4096 B logical: 512 B
  speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: SC48
  scheme: GPT
  ID-4: /dev/sdc type: USB vendor: Seagate model: Expansion Desk
  size: 7.28 TiB block size: physical: 4096 B logical: 512 B
  serial: <filter> rev: 9401 scheme: GPT
  ID-5: /dev/sdd type: USB vendor: Seagate model: Expansion
  size: 1.82 TiB block size: physical: 4096 B logical: 512 B
  serial: <filter> rev: 9300 scheme: GPT
  ID-6: /dev/sde type: USB vendor: MediaMax model: WL3000GSA6454
  size: 3.41 TiB block size: physical: 4096 B logical: 512 B
  rotation: 5400 rpm serial: <filter> scheme: GPT
  ID-1: / raw size: 237.99 GiB size: 237.99 GiB (100.00%)
  used: 37.23 GiB (15.6%) fs: btrfs dev: /dev/nvme0n1p2
  ID-2: /home raw size: 237.99 GiB size: 237.99 GiB (100.00%)
  Alert: No Swap data was found.
  System Temperatures: cpu: 43.2 C mobo: N/A gpu: nvidia temp: 41 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
  Processes: 341 Uptime: 1d 5h 16m Memory: 15.62 GiB
  used: 6.45 GiB (41.3%) Init: systemd v: 246 Compilers: gcc: 10.2.0
  Packages: 1360 pacman: 1311 lib: 353 flatpak: 42 snap: 7 Shell: Bash
  v: 5.0.18 running in: konsole inxi: 3.1.07
It seems to stay on my set up. I just tried it to see. :man_shrugging:
Screenshot_20201011_103130
I’m not sure what is going on here. I just know after every reboot it drops to 40%.
I’m not sure why either? I tried it a couple of times at different levels.
You would think someone on the forums would have some idea what might be causing the issue and at least make some suggestions on what to look at.
Not necessarily unless it has happened to them. Maybe search the Arch forums or Manjaro or others?
HAPPY, HAPPY, JOY, JOY
Just received updates for the Pulse components and Alas and rebooted without the system sounds being dropped down to 40%.
Received some more sound components updates and back to the volume dropping again. Wondering if the below is related.
