Hello, I’m trying to set up pyenv to use python 3.9.10. which python still shows the path to /usr/bin/python, which is version 3.10.2, so it looks like the shim is not working. I have added this to the ~/bash.rc file:
export PATH="$HOME/.pyenv/bin:$PATH"
eval "$(pyenv init -)"
eval "$(pyenv virtualenv-init -)"
I have set the python version to 3.9.10:
$ pyenv versions
system
* 3.9.10 (set by /home/lee/.pyenv/version)
Thank you, folks.
dalto
February 13, 2022, 2:05pm
2
First welcome to the community!
Next, what is ~/bash.rc? Does that actually get sourced by bash?
Is there a reason you didn’t follow the instructions from the site?
Those recommend this:
sed -Ei -e '/^([^#]|$)/ {a \
export PYENV_ROOT="$HOME/.pyenv"
a \
export PATH="$PYENV_ROOT/bin:$PATH"
a \
' -e ':a' -e '$!{n;ba};}' ~/.bash_profile
echo 'eval "$(pyenv init --path)"' >> ~/.bash_profile
echo 'export PYENV_ROOT="$HOME/.pyenv"' >> ~/.profile
echo 'export PATH="$PYENV_ROOT/bin:$PATH"' >> ~/.profile
echo 'eval "$(pyenv init --path)"' >> ~/.profile
echo 'eval "$(pyenv init -)"' >> ~/.bashrc
Hello Dalto,
Thanks for replying.
I was doing what I could to follow this tutorial: https://realpython.com/intro-to-pyenv/
Regarding bash:
None of the script you posted is on there. Besides, Arch based is not mentioned at all.
I’ll have a go with your script. Thank you.
I uninstalled pyenv, and then followed the instructions here:
Double checked the prerequisites were installed - yes
Use the autoinstaller and follow instructions - yes
I had to add these lines to ~/.bashrc as without them pyenv could not be found
which python now points to /home/lee/.pyenv/shims/python
python -V now returns Python 3.9.10 instead of 3.10.2
