Hi there
Since yesterday evening my system won’t boot anymore… It gets stuck at starting version 247.2-1-arch
The weird part is that the linux-lts kernel seems to work… Meaning that I can log in into my system.
Could it be related to a graphics driver problem?
Many thanks in advance!
Cheers
manuel
January 7, 2021, 12:05pm
2
Welcome aboard!
Yes, possibly. To find more we need logs. For example:
inxi -Fxxxz
eos-log-tool # select at least 'journalctl -b -1'
More info about giving logs: https://endeavouros.com/docs/forum/how-to-include-systemlogs-in-your-post
Thanks for the reply
Here’s the inxi log:
http://ix.io/2L9N
and here’s the eos-log-tool log (I selected journalctl -b -1 and journalctl -b -2):
https://clbin.com/uv6Cl
Maybe the lightdm logs will help too
http://ix.io/2Lan
Cheers!
looks like gpu driver issue yea:
Summary
Jan 07 12:33:37 _hostname_ kernel: i915 0000:00:02.0: drm_WARN_ON(common_len <= 0) Jan 07 12:33:37 _hostname_ kernel: WARNING: CPU: 1 PID: 486 at drivers/gpu/drm/i915/display/intel_dp.c:2358 intel_dp_compute_config+0xd6f/0xed0 [i915] Jan 07 12:33:37 _hostname_ kernel: Modules linked in: usbhid snd_sof_pci snd_sof_intel_byt snd_sof_intel_ipc snd_sof_intel_hda_common snd_soc_hdac_hda snd_sof_xtensa_dsp snd_sof_intel_hda snd_sof intel_rapl_msr intel_rapl_common ledtrig_audio snd_soc_skl snd_soc_sst_ipc snd_soc_sst_dsp snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi x86_pkg_temp_thermal snd_hda_intel intel_powerclamp nf_log_ipv6 snd_intel_dspcfg soundwire_intel coretemp ip6t_REJECT nf_reject_ipv6 soundwire_generic_allocation kvm_intel soundwire_cadence snd_hda_codec joydev mousedev xt_hl kvm iTCO_wdt snd_hda_core ip6t_rt irqbypass intel_pmc_bxt snd_hwdep crct10dif_pclmul hid_multitouch iTCO_vendor_support mei_hdcp mei_wdt wmi_bmof intel_wmi_thunderbolt crc32_pclmul i915(+) ghash_clmulni_intel iwlmvm soundwire_bus aesni_intel snd_soc_core crypto_simd cryptd glue_helper rapl intel_cstate mac80211 intel_uncore snd_compress nf_log_ipv4 ac97_bus nf_log_common libarc4 snd_pcm_dmaengine i2c_algo_bit snd_pcm ipt_REJECT nf_reject_ipv4 vfat fat Jan 07 12:33:37 _hostname_ kernel: xt_LOG iwlwifi pcspkr drm_kms_helper snd_timer snd i2c_i801 e1000e i2c_smbus tpm_crb thunderbolt cfg80211 soundcore xt_limit cec xt_addrtype intel_gtt mei_me ucsi_acpi syscopyarea intel_lpss_pci tpm_tis typec_ucsi sysfillrect tpm_tis_core xt_tcpudp intel_lpss sysimgblt mei rfkill idma64 fb_sys_fops intel_pch_thermal typec tpm mac_hid wmi i2c_hid xt_conntrack fujitsu_laptop rng_core sparse_keymap video acpi_pad ip6table_filter ip6_tables nf_conntrack_netbios_ns nf_conntrack_broadcast nf_nat_ftp nf_nat nf_conntrack_ftp nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c drm iptable_filter fuse pkcs8_key_parser crypto_user agpgart bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 sdhci_pci cqhci crc32c_intel sdhci serio_raw mmc_core xhci_pci xhci_pci_renesas Jan 07 12:33:37 _hostname_ kernel: CPU: 1 PID: 486 Comm: Xorg Not tainted 5.10.4-arch2-1 #1 Jan 07 12:33:37 _hostname_ kernel: Hardware name: FUJITSU CLIENT COMPUTING LIMITED LIFEBOOK U749/FJNB2CB, BIOS Version 2.09 04/22/2019 Jan 07 12:33:37 _hostname_ kernel: RIP: 0010:intel_dp_compute_config+0xd6f/0xed0 [i915] Jan 07 12:33:37 _hostname_ kernel: Code: 8b 78 18 4c 8b 77 50 4d 85 f6 74 37 e8 8a 71 c5 f1 48 c7 c1 0b d6 0f c1 4c 89 f2 48 c7 c7 70 d3 0f c1 48 89 c6 e8 3b 3d fe f1 <0f> 0b b9 ff ff ff ff e9 23 f4 ff ff e8 80 6b 01 00 41 89 c1 e9 57 Jan 07 12:33:37 _hostname_ kernel: RSP: 0018:ffffb302c0e5fac8 EFLAGS: 00010282 Jan 07 12:33:37 _hostname_ kernel: RAX: 0000000000000000 RBX: ffff8cad854cb000 RCX: ffff8caefa458bb8 Jan 07 12:33:37 _hostname_ kernel: RDX: 00000000ffffffd8 RSI: 0000000000000027 RDI: ffff8caefa458bb0 Jan 07 12:33:37 _hostname_ kernel: RBP: ffff8cad836d5000 R08: 0000000000000000 R09: ffffb302c0e5f900 Jan 07 12:33:37 _hostname_ kernel: R10: ffffb302c0e5f8f8 R11: ffffffffb40cb1e8 R12: ffff8cad854cb000 Jan 07 12:33:37 _hostname_ kernel: R13: ffff8cad854cb000 R14: ffff8cad814d7110 R15: ffff8cad8c355000 Jan 07 12:33:37 _hostname_ kernel: FS: 00007fa2120822c0(0000) GS:ffff8caefa440000(0000) knlGS:0000000000000000 Jan 07 12:33:37 _hostname_ kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 Jan 07 12:33:37 _hostname_ kernel: CR2: 00007fa21025dfc0 CR3: 0000000111174006 CR4: 00000000003706e0 Jan 07 12:33:37 _hostname_ kernel: Call Trace: Jan 07 12:33:37 _hostname_ kernel: intel_ddi_compute_config+0xa6/0xe0 [i915] Jan 07 12:33:37 _hostname_ kernel: intel_atomic_check+0x9c9/0x25f0 [i915] Jan 07 12:33:37 _hostname_ kernel: drm_atomic_check_only+0x57c/0x7f0 [drm] Jan 07 12:33:37 _hostname_ kernel: ? __drm_atomic_helper_crtc_duplicate_state+0x52/0xd0 [drm_kms_helper] Jan 07 12:33:37 _hostname_ kernel: drm_atomic_commit+0x13/0x50 [drm] Jan 07 12:33:37 _hostname_ kernel: drm_atomic_helper_legacy_gamma_set+0x123/0x180 [drm_kms_helper] Jan 07 12:33:37 _hostname_ kernel: drm_mode_gamma_set_ioctl+0x1d2/0x2d0 [drm] Jan 07 12:33:37 _hostname_ kernel: ? drm_color_lut_check+0xa0/0xa0 [drm] Jan 07 12:33:37 _hostname_ kernel: drm_ioctl_kernel+0xb2/0x100 [drm] Jan 07 12:33:37 _hostname_ kernel: drm_ioctl+0x215/0x390 [drm] Jan 07 12:33:37 _hostname_ kernel: ? drm_color_lut_check+0xa0/0xa0 [drm] Jan 07 12:33:37 _hostname_ kernel: __x64_sys_ioctl+0x83/0xb0 Jan 07 12:33:37 _hostname_ kernel: do_syscall_64+0x33/0x40 Jan 07 12:33:37 _hostname_ kernel: entry_SYSCALL_64_after_hwframe+0x44/0xa9 Jan 07 12:33:37 _hostname_ kernel: RIP: 0033:0x7fa212a4ef6b Jan 07 12:33:37 _hostname_ kernel: Code: 89 d8 49 8d 3c 1c 48 f7 d8 49 39 c4 72 b5 e8 1c ff ff ff 85 c0 78 ba 4c 89 e0 5b 5d 41 5c c3 f3 0f 1e fa b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d d5 ae 0c 00 f7 d8 64 89 01 48 Jan 07 12:33:37 _hostname_ kernel: RSP: 002b:00007ffc2509f178 EFLAGS: 00000246 ORIG_RAX: 0000000000000010 Jan 07 12:33:37 _hostname_ kernel: RAX: ffffffffffffffda RBX: 00007ffc2509f1b0 RCX: 00007fa212a4ef6b Jan 07 12:33:37 _hostname_ kernel: RDX: 00007ffc2509f1b0 RSI: 00000000c02064a5 RDI: 000000000000000e Jan 07 12:33:37 _hostname_ kernel: RBP: 00000000c02064a5 R08: 000055c41ed8b600 R09: 000055c41ed8b800 Jan 07 12:33:37 _hostname_ kernel: R10: fffffffffffff1ca R11: 0000000000000246 R12: 000055c41ed8ac10 Jan 07 12:33:37 _hostname_ kernel: R13: 000000000000000e R14: 0000000000000006 R15: 00007ffc2509f270 Jan 07 12:33:37 _hostname_ kernel: ---[ end trace fe6bf16e24fcc173 ]---
you can try to remove xf86-video-intel and make use of the modesetting driver from inside kernel:
login from TTY2: Ctrl+Alt+F2 login with username and password the remove the driver:
sudo pacman -R xf86-video-intel
reboot and it will boot on modesetting intel driver…
Thanks for your tip
I removed the xf86-video-intel package and I can finally boot into the newer kernel again!
Thank you so much for your time and help
PS: Would you care to explain the differences between the offical intel-video-driver and the modesetting one? I’m not that tech-savvy…
