Everytime i install EndeavourOS and start it, it just loads forever
It shows some logs and after that, it changes from (1 of 2) A start job is running for dracut pre-dev hook and "(2 of 2) A start job is running for /dev/disk/byuuid/b098044b-947b-445d-8a5e-bb032039af10
You are pretty vague in explaining the sequence of events as to what is going on. If you expect help you need explain what your are seeing and attempting to do.
Seems like the first step would be chrooting into the installed system. If you need to go, you can just shut down and chroot back in.
Then do what @Canoe said and post logs about the issue.
