system-md-machine-id setup error exit code 127
is this fixed yet?
tried, using windows efi creating a new efi with esp flag. does the boot flag need to be set in efi
arch is so great when it works unfortunately that is very seldom
is this fixed yet?
sorry yes it is a windows 10 dual boot and efi is fat32
welcome
Welcome Aboard!
Hello @squaleca
Can you give an explanation of what is is your trying to do? I’m not sure what your issue is?
dual boot windows 10 already installed
partitions 63 gig / ext4
4 gig swap
1000 gig fat32 efi flags boot esp
theres already another thread on the board with the same error. but no resolution
what is THAT
1000Go fat32 for efi flags boot esp
have you checked you disk under gparted ?
MBR or GPT ?
is there a /boot/efi ( 300Mo) exists ? ( windows 10 )
if possible , with USB iso EOS
return
sudo parted -l
