I’m using Cinnamon on EndeavourOS, everything is up to date.
Since some time ago (1-3 weeks, can’t remember exactly) I cannot shut down/restart using the menu, as it logs out instead.
I can shutdown using cli no problem, but I’m used to use the menu so I would like to fix it.
There is definetely some good clues in the syslog, but I cannot decifer it. Tried to duck it, but couldn’t find anything that helped me fix the issue.
Can anyone point me in the right direction? Thank you
Here’s the relevant part of journalctl -b 0
juni 19 20:46:18 studio cinnamon-session-binary[4042]: WARNING: t+422.48781s: Requesting system restart...
juni 19 20:46:18 studio cinnamon-session-binary[4042]: WARNING: t+422.48796s: Attempting to restart using systemd...
juni 19 20:46:18 studio wireplumber[1434]: m-dbus-connection: <WpDBusConnection:0x61551f2a8120> DBus connection closed: Underlying GIOStream returned 0 bytes on an async read
juni 19 20:46:18 studio cinnamon-session-binary[4042]: CRITICAL: t+422.48834s: Unable to start session: Lost name on bus: org.gnome.SessionManager
juni 19 20:46:18 studio systemd[1274]: Stopping D-Bus User Message Bus...
juni 19 20:46:18 studio gvfsd[4095]: A connection to the bus can't be made
juni 19 20:46:18 studio gvfsd[4367]: A connection to the bus can't be made
juni 19 20:46:18 studio dbus-broker[3905]: Dispatched 3063 messages @ 3(±3)μs / message.
juni 19 20:46:18 studio dbus-broker[4162]: Dispatched 497 messages @ 2(±3)μs / message.
juni 19 20:46:18 studio wireplumber[1434]: m-dbus-connection: <WpDBusConnection:0x61551f2a8120> Trying to reconnect after core sync
juni 19 20:46:18 studio systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
juni 19 20:46:18 studio systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
juni 19 20:46:18 studio systemd[1274]: Stopped D-Bus User Message Bus.
juni 19 20:46:18 studio systemd[1274]: xdg-permission-store.service: Main process exited, code=exited, status=1/FAILURE
juni 19 20:46:18 studio systemd[1274]: xdg-permission-store.service: Failed with result 'exit-code'.
juni 19 20:46:18 studio systemd[1274]: Finished EOS update notifier service.
juni 19 20:46:18 studio systemd[1274]: eos-update-notifier.service: Consumed 8.568s CPU time.
juni 19 20:46:18 studio systemd[1274]: Starting D-Bus User Message Bus...
juni 19 20:46:18 studio dbus-broker-launch[6344]: Service file '/usr/share/dbus-1/services/nemo.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
juni 19 20:46:18 studio dbus-broker-launch[6344]: Service file '/usr/share/dbus-1/services/nemo.service' is not named after the D-Bus name 'org.Nemo'.
juni 19 20:46:18 studio dbus-broker-launch[6344]: Service file '/usr/share/dbus-1/services/org.gnome.Caribou.Antler.service' is not named after the D-Bus name 'org.gnome.Caribou.Keyboard'.
juni 19 20:46:18 studio dbus-broker-launch[6344]: Service file '/usr/share/dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
juni 19 20:46:18 studio dbus-broker-launch[6344]: Service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
juni 19 20:46:18 studio dbus-broker-launch[6344]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
juni 19 20:46:18 studio dbus-broker-launch[6344]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
juni 19 20:46:18 studio dbus-broker-launch[6344]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
juni 19 20:46:18 studio dbus-broker-launch[6344]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
juni 19 20:46:18 studio dbus-broker-launch[6344]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
juni 19 20:46:18 studio systemd[1274]: Started D-Bus User Message Bus.
juni 19 20:46:18 studio dbus-broker-launch[6344]: Ready
juni 19 20:46:18 studio lightdm[4023]: pam_unix(lightdm:session): session closed for user alf
juni 19 20:46:18 studio polkitd[811]: Error converting subject to JS object: Process 4042 terminated
juni 19 20:46:18 studio systemd-logind[780]: Session 8 logged out. Waiting for processes to exit.
juni 19 20:46:18 studio polkitd[811]: Unregistered Authentication Agent for unix-session:8 (system bus name :1.138, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8) (disconnected from bus)
juni 19 20:46:18 studio systemd[1274]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
juni 19 20:46:18 studio systemd[1274]: xdg-document-portal.service: Failed with result 'exit-code'.
juni 19 20:46:19 studio lightdm[6391]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=969) by (uid=0)
juni 19 20:46:19 studio systemd-logind[780]: New session c5 of user lightdm.
juni 19 20:46:19 studio systemd[1]: Created slice User Slice of UID 969.
juni 19 20:46:19 studio systemd[1]: Starting User Runtime Directory /run/user/969...
juni 19 20:46:19 studio systemd[1]: Finished User Runtime Directory /run/user/969.
juni 19 20:46:19 studio systemd[1]: Starting User Manager for UID 969...
juni 19 20:46:19 studio (systemd)[6397]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
juni 19 20:46:19 studio (systemd)[6397]: pam_unix(systemd-user:session): session opened for user lightdm(uid=969) by lightdm(uid=0)
juni 19 20:46:19 studio systemd[6397]: Queued start job for default target Main User Target.
juni 19 20:46:19 studio systemd[6397]: Created slice User Application Slice.
juni 19 20:46:19 studio systemd[6397]: Reached target Paths.
juni 19 20:46:19 studio systemd[6397]: Reached target Timers.
juni 19 20:46:19 studio systemd[6397]: Starting D-Bus User Message Bus Socket...
juni 19 20:46:19 studio systemd[6397]: Listening on GnuPG network certificate management daemon.
juni 19 20:46:19 studio systemd[6397]: Starting GCR ssh-agent wrapper...
juni 19 20:46:19 studio systemd[6397]: Listening on GNOME Keyring daemon.
juni 19 20:46:19 studio systemd[6397]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
juni 19 20:46:19 studio systemd[6397]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
juni 19 20:46:19 studio systemd[6397]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
