System keeps crashing for no reason logs below
rtw_8822bu 1-2:1.0: rtw_usb_reg_sec: reg 0x4e0, usb write 1 fail, status: -71
Mar 17 20:56:27 kernel: rtw_8822bu 1-2:1.0: mac power on failed
Mar 17 20:56:27 kernel: rtw_8822bu 1-2:1.0: failed to power on mac
Mar 17 20:56:45 kernel: rtw_8822bu 1-2:1.0: rtw_usb_reg_sec: reg 0x4e0, usb write 1 fail, status: -71
Mar 17 20:56:45 libvirtd[1457]: internal error: Missing udev property ‘ID_VENDOR_ID’ on ‘1-2’
Mar 17 19:38:37 systemd-coredump[17687]: [🡕] Process 17675 (ThreadPoolForeg) of user 1000 dumped core.
                                                            Stack trace of thread 17675:
                                                            #0  0x00005b8f1babbc98 n/a (/usr/lib/electron34/electron + 0x59c8c98)
                                                            #1  0x00005b8f1babbc3f close (/usr/lib/electron34/electron + 0x59c8c3f)
                                                            #2  0x00005b8f1bc37f4b n/a (/usr/lib/electron34/electron + 0x5b44f4b)
                                                            #3  0x00005b8f1bc3849b n/a (/usr/lib/electron34/electron + 0x5b4549b)
                                                            #4  0x00005b8f1bad69bc n/a (/usr/lib/electron34/electron + 0x59e39bc)
                                                            #5  0x00005b8f1bad683f n/a (/usr/lib/electron34/electron + 0x59e383f)
                                                            #6  0x00005b8f1babbc97 n/a (/usr/lib/electron34/electron + 0x59c8c97)
                                                            #7  0x00005b8f1babbc3f close (/usr/lib/electron34/electron + 0x59c8c3f)
                                                            #8  0x000070c475164156 n/a (libglib-2.0.so.0 + 0xbc156)
                                                            #9  0x000070c475165c20 n/a (libglib-2.0.so.0 + 0xbdc20)
                                                            #10 0x000070c475167d91 n/a (libglib-2.0.so.0 + 0xbfd91)
                                                            #11 0x000070c47512badc g_spawn_sync (libglib-2.0.so.0 + 0x83adc)
                                                            #12 0x000070c3dca3622c spd_open2 (libspeechd.so.2 + 0x622c)
                                                            #13 0x000070c3dca3675e spd_open (libspeechd.so.2 + 0x675e)
                                                            #14 0x00005b8f1aaf05e5 n/a (/usr/lib/electron34/electron + 0x49fd5e5)
                                                            #15 0x00005b8f1aaefeee n/a (/usr/lib/electron34/electron + 0x49fceee)
                                                            #16 0x00005b8f1ba5a185 n/a (/usr/lib/electron34/electron + 0x5967185)
                                                            #17 0x00005b8f1ba89fb9 n/a (/usr/lib/electron34/electron + 0x5996fb9)
                                                            #18 0x00005b8f1ba89969 n/a (/usr/lib/electron34/electron + 0x5996969)
                                                            #19 0x00005b8f1ba8941d n/a (/usr/lib/electron34/electron + 0x599641d)
                                                            #20 0x00005b8f1ba9c4cb n/a (/usr/lib/electron34/electron + 0x59a94cb)
                                                            #21 0x00005b8f1ba9bf9a n/a (/usr/lib/electron34/electron + 0x59a8f9a)
                                                            #22 0x00005b8f1ba9be31 n/a (/usr/lib/electron34/electron + 0x59a8e31)
                                                            #23 0x00005b8f1babb8d7 n/a (/usr/lib/electron34/electron + 0x59c88d7)
                                                            #24 0x000070c47305870a n/a (libc.so.6 + 0x9570a)
                                                            #25 0x000070c4730dcaac n/a (libc.so.6 + 0x119aac)
                                                            ELF object binary architecture: AMD x86-64
Mar 18 07:05:58 kernel: BUG: kernel NULL pointer dereference, address: 0000000000000002
journalctl -b -1 | grep -i “oom”
Mar 17 20:55:19
[1461]: time=“2025-03-17T20:55:19.008974990+02:00” level=info msg=“starting cri plugin” config=“{"containerd":{"defaultRuntimeName":"ru
nc","runtimes":{"runc":{"runtimeType":"io.containerd.runc.v2","runtimePath":"","PodAnnotations":null,"ContainerAnnotations":null,"options":{"BinaryName":"","CriuImag
ePath":"","CriuWorkPath":"","IoGid":0,"IoUid":0,"NoNewKeyring":false,"Root":"","ShimCgroup":""},"privileged_without_host_devices":false,"privileged_without_host_devi
ces_all_devices_allowed":false,"baseRuntimeSpec":"","cniConfDir":"","cniMaxConfNum":0,"snapshotter":"","sandboxer":"podsandbox","io_type":""}},"ignoreBlockIONotEnabl
edErrors":false,"ignoreRdtNotEnabledErrors":false},"cni":{"binDir":"/opt/cni/bin","confDir":"/etc/cni/net.d","maxConfNum":1,"setupSerially":false,"confTemplate":"","ip
Pref":"","useInternalLoopback":false},"enableSelinux":false,"selinuxCategoryRange":1024,"maxContainerLogSize":16384,"disableApparmor":false,"restrictOOMScoreAdj":false,"disa
bleProcMount":false,"unsetSeccompProfile":"","tolerateMissingHugetlbController":true,"disableHugetlbController":true,"device_ownership_from_security_context":false,"ignoreImageD
efinedVolumes":false,"netnsMountsUnderStateDir":false,"enableUnprivilegedPorts":true,"enableUnprivilegedICMP":true,"enableCDI":true,"cdiSpecDirs":["/etc/cdi","/var/run/cdi"],
"drainExecSyncIOTimeout":"0s","ignoreDeprecationWarnings":null,"containerdRootDir":"/var/lib/containerd","containerdEndpoint":"/run/containerd/containerd.sock","rootDir":"/
var/lib/containerd/io.containerd.grpc.v1.cri","stateDir":"/run/containerd/io.containerd.grpc.v1.cri"}”
Mar 17 20:55:48 kded6[2547]: QDBusObjectPath: invalid path “/modules/oom-notifier”
Mar 17 20:55:48 kded6[2547]: kf.dbusaddons: The kded module name “oom-notifier” is invalid!
edit found more errors
0.592154] Could not retrieve perf counters (-19)
[ 0.609639] amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
[ 1.063744] ata3.00: Model ‘Samsung SSD 750 EVO 120GB’, rev ‘MAT01B6Q’, applying quirks: zeroaftertrim
[ 1.063824] ata3.00: supports DRM functions and may not be fully accessible
[ 1.066582] ata3.00: supports DRM functions and may not be fully accessible
[ 1.071165] ata4.00: Model ‘CT120BX500SSD1’, rev ’ M6CR013’, applying quirks: nolpm
[ 1.071167] ata4.00: LPM support broken, forcing max_power
[ 1.082190] ata4.00: LPM support broken, forcing max_power
[ 1.472177] binder_linux: loading out-of-tree module taints kernel.
[ 1.472945] systemd[1]: systemd-vconsole-setup.service: Failed with result ‘exit-code’.
[ 1.473104] systemd[1]: Failed to start Virtual Console Setup.
[ 1.479484] debugfs: Directory ‘binder’ with parent ‘/’ already present!
[ 2.018520] nvidia: module license ‘NVIDIA’ taints kernel.
[ 2.018525] Disabling lock debugging due to kernel taint
[ 2.018528] nvidia: module license taints kernel.
[ 2.551332] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 570.133.07 Fri Mar 14 13:12:07 UTC 2025
[ 2.571931] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 26.786554] debugfs: Directory ‘binder’ with parent ‘/’ already present!
[ 26.818478] systemd-journald[1171]: File /var/log/journal/4822328fb17649f886ade74caa426a00/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 27.214042] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 27.423422] debugfs: Directory ‘binder’ with parent ‘/’ already present!
[ 27.440560] usb 5-1: Warning! Unlikely big volume range (=7680), cval->res is probably wrong.
[ 27.440564] usb 5-1: [16] FU [PCM Playback Volume] ch = 2, val = -7680/0/1
[ 27.480560] usb 5-1: Warning! Unlikely big volume range (=12288), cval->res is probably wrong.
[ 27.480564] usb 5-1: [17] FU [Mic Capture Volume] ch = 2, val = -7680/4608/1
[ 27.660100] usb 1-1: Warning! Unlikely big volume range (=1008), cval->res is probably wrong.
[ 27.660103] usb 1-1: [49] FU [PCM Playback Volume] ch = 2, val = -16129/-1/16
[ 27.706087] usb 1-1: Warning! Unlikely big volume range (=496), cval->res is probably wrong.
[ 27.706089] usb 1-1: [50] FU [Mic Capture Volume] ch = 1, val = 0/7936/16
[ 29.212766] debugfs: Directory ‘binder’ with parent ‘/’ already present!
[ 31.213029] i2c i2c-8: adapter quirk: no zero length (addr 0x0018, size 0, write)
[ 31.213040] i2c i2c-8: adapter quirk: no zero length (addr 0x0019, size 0, write)
[ 31.213048] i2c i2c-8: adapter quirk: no zero length (addr 0x001a, size 0, write)
[ 31.213055] i2c i2c-8: adapter quirk: no zero length (addr 0x001b, size 0, write)
[ 31.213062] i2c i2c-8: adapter quirk: no zero length (addr 0x001c, size 0, write)
[ 31.213068] i2c i2c-8: adapter quirk: no zero length (addr 0x001d, size 0, write)
[ 31.213075] i2c i2c-8: adapter quirk: no zero length (addr 0x001e, size 0, write)
[ 31.213082] i2c i2c-8: adapter quirk: no zero length (addr 0x001f, size 0, write)
[ 31.213149] i2c i2c-9: adapter quirk: no zero length (addr 0x0018, size 0, write)
[ 31.213157] i2c i2c-9: adapter quirk: no zero length (addr 0x0019, size 0, write)
[ 48.087940] nvme nvme0: using unchecked data buffer
[ 48.104631] block nvme0n1: No UUID available providing old NGUID
[ 52.905246] warning: `kdeconnectd’ uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
System keeps crashing for no reason…
There’s always a reason. Troubleshooting is the process of discovering that reason.
The logs aren’t telling me much. What would be valuable, is a common element in the logs, such as a specific fault that presents each and every time the crash occurs. This would be more likely with a kernel, driver or software issue.
It’s also possible you won’t find that. In cases of hardware issues, a crash can occur more randomly. Some details of your hardware may help:
sudo inxi -SMGmDsxxx --za
If it is a desktop system, could you also specify your power supply brand and model.
A final note, it helps if large blocks of output text are set to preformatted text, like this, using backticks ( ` ):
Some text output here
Kernel: 6.13.7-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: tsc
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x serial:
part-nu: SKU uuid: UEFI: American Megatrends v: 4002
date: 06/15/2021
Memory:
System RAM: total: 48 GiB available: 46.84 GiB used: 5.53 GiB (11.8%)
Array-1: capacity: 128 GiB slots: 4 modules: 3 EC: None
max-module-size: 32 GiB note: est.
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2400 MT/s volts: 1.2 width (bits): data: 64 total: 64
manufacturer: Corsair part-no: CMH16GX4M2Z4000C18 serial: N/A
Device-2: DIMM_A2 type: no module installed
Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 32 GiB speed: 2400 MT/s volts: 1.2 width (bits): data: 64 total: 64
manufacturer: Kingston part-no: KF3600C18D4/32GX serial:
Device-1: Advanced Micro Devices [AMD/ATI] Navi 24 [Radeon RX 6400/6500
XT/6500M] vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2
pcie: speed: 16 GT/s lanes: 16 ports: active: HDMI-A-2
empty: DP-4,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:743f class-ID: 0300
Device-2: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] driver: nvidia
v: 570.124.04 arch: Ampere pcie: speed: 2.5 GT/s lanes: 4 ports:
active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 07:00.0
chip-ID: 10de:2504 class-ID: 0300
Device-3: Sunplus Innovation FHD Camera Microphone
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
bus-ID: 1-1:2 chip-ID: 1bcf:28c4 class-ID: 0102
Display: unspecified server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: radeonsi
gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :1 screens: 1
Screen-1: 0 s-res: 3200x1080 s-dpi: 96 s-size: 847x286mm (33.35x11.26")
s-diag: 894mm (35.2")
Monitor-1: HDMI-A-1 note: disabled pos: primary,right
model: LG (GoldStar) E2360 serial: res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 96 size: 510x290mm (20.08x11.42") diag: 587mm (23.1")
modes: max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-2 pos: left model: NEC EA191M serial: res:
mode: 1280x960 hz: 60 scale: 100% (1) dpi: 86 size: 376x301mm (14.8x11.85")
diag: 482mm (19") modes: max: 1280x1024 min: 720x400
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi gbm: drv: radeonsi surfaceless:
drv: nvidia x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: amd mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6500 XT (radeonsi
navi24 LLVM 19.1.7 DRM 3.61 6.13.7-arch1-1) device-ID: 1002:743f
API: Vulkan v: 1.4.304 layers: 2 surfaces: xcb,xlib device: 0
type: discrete-gpu driver: N/A device-ID: 10de:2504
de: kscreen-console,kscreen-doctor gpu: nvidia-settings,nvidia-smi
Local Storage: total: 5.07 TiB used: 567.93 GiB (10.9%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNV2S1000G size: 931.51 GiB
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: fw-rev: SBM02103
temp: 53.9 C scheme: GPT
ID-2: /dev/nvme1n1 vendor: Intel model: SSDPEKKW128G7 size: 119.24 GiB
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: fw-rev: PSF121C
temp: 42.9 C
ID-3: /dev/sda vendor: Samsung model: SSD 750 EVO 120GB size: 111.79 GiB
speed: 6.0 Gb/s tech: SSD serial: fw-rev: 1B6Q scheme: GPT
ID-4: /dev/sdb vendor: Crucial model: CT120BX500SSD1 size: 111.79 GiB
speed: 6.0 Gb/s tech: SSD serial: fw-rev: R013 scheme: MBR
ID-5: /dev/sdc vendor: Hitachi model: HTS547575A9E384 size: 698.64 GiB
speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: fw-rev: A50A
scheme: MBR
ID-6: /dev/sdd vendor: Kingston model: SA400S37960G size: 894.25 GiB
speed: 6.0 Gb/s tech: SSD serial: fw-rev: Z1.3
ID-7: /dev/sde vendor: Seagate model: BarraCuda 120 SSD ZA500CM10003
size: 465.76 GiB speed: 6.0 Gb/s tech: SSD serial: fw-rev: D012
ID-8: /dev/sdf vendor: A-Data model: SD810 size: 1.82 TiB type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 tech: SSD serial: fw-rev: 1006
scheme: GPT
System Temperatures: cpu: 46.0 C mobo: 36.0 C gpu: amdgpu temp: 57.0 C
mem: 62.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
lines 1-21/21 (END)…skipping…
Mar 25 19:52:55 anon-systemproductname systemd-modules-load[231]: Failed to insert module ‘binder_linux’: Devi>
Mar 25 19:52:55 anon-systemproductname systemd-modules-load[231]: Inserted module ‘crypto_user’
Mar 25 19:52:55 anon-systemproductname systemd-modules-load[231]: Inserted module ‘i2c_dev’
Mar 25 19:52:58 anon-systemproductname systemd-modules-load[231]: Inserted module ‘nvidia_uvm’
Mar 25 19:52:58 anon-systemproductname systemd-modules-load[231]: Inserted module ‘pkcs8_key_parser’
Mar 25 19:52:58 anon-systemproductname systemd[1]: systemd-modules-load.service: Main process exited, code=exi>
Mar 25 19:52:58 anon-systemproductname systemd[1]: systemd-modules-load.service: Failed with result 'exit-code>
Mar 25 19:52:58 anon-systemproductname systemd[1]: Failed to start Load Kernel Modules.
Mar 25 19:52:58 anon-systemproductname systemd[1]: systemd-modules-load.service: Consumed 1.229s CPU time, 1.6>
Mar 25 19:53:24 anon-systemproductname systemd-modules-load[1281]: Failed to insert module ‘binder_linux’: Dev>
Mar 25 19:53:24 anon-systemproductname systemd[1]: systemd-modules-load.service: Main process exited, code=exi>
Mar 25 19:53:24 anon-systemproductname systemd[1]: systemd-modules-load.service: Failed with result 'exit-code>
Mar 25 19:53:24 anon-systemproductname systemd[1]: Failed to start Load Kernel Modules.
Mar 25 19:53:25 anon-systemproductname systemd[1]: Starting Load Kernel Modules…
Mar 25 19:53:25 anon-systemproductname systemd[1]: systemd-modules-load.service: Main process exited, code=exi>
Mar 25 19:53:25 anon-systemproductname systemd[1]: systemd-modules-load.service: Failed with result 'exit-code>
Mar 25 19:53:25 anon-systemproductname systemd[1]: Failed to start Load Kernel Modules.
Mar 25 19:53:27 anon-systemproductname systemd[1]: Starting Load Kernel Modules…
Mar 25 19:53:27 anon-systemproductname systemd[1]: systemd-modules-load.service: Main process exited, code=exi>
Mar 25 19:53:27 anon-systemproductname systemd[1]: systemd-modules-load.service: Failed with result 'exit-code>
Mar 25 19:53:27 anon-systemproductname systemd[1]: Failed to start Load Kernel Modules.
systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
● systemd-modules-load.service loaded failed failed Load Kernel Modules
● systemd-vconsole-setup.service loaded failed failed Virtual Console Setup
Legend: LOAD → Reflects whether the unit definition was properly loaded.
ACTIVE → The high-level unit activation state, i.e. generalization of SUB.
SUB → The low-level unit activation state, values depend on unit type.
What do you mean by Crashing?
please post logs via eos-sendlog and just post the url here will make it much easier to read
i copy 200 files to a external encrypted hard drive then my pc just freezes completely but does not turn off found this [ 0.778379] RAS: Correctable Errors collector initialized.
[ 31.324654] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 393.104730] eglinfo[7537]: segfault at 8 ip 00007e17e5a3c44f sp 00007fff16b574b0 error 4 in libgallium-25.0.1-arch1.2.so[3c44f,7e17e5a17000+17bc000] likely on CPU 6 (core 0, socket 0)
[anon@anon-systemproductname ~]$
this also happens when i copy 2k of videos 50 gbs i have enough space and should work with my specs
is this like drag and drop or copy paste?
what happens if you use rsync?
rsync -avh /Source /Destination
right click copy right click paste and its not rsync i just use dolphin since its local i am backing up to a external or trying
will test might take time since i am updating need to install rsync
@memphis_cult
The UEFI Firmware (Bios) is outdated. There are 10 newer updates than your posted current version.
You also have some issues with loading kernel modules not sure why at this point. I do see it is a hybrid sysytem running amd gpu with discrete nvidia. Vulkan doesn’t look like it’s installed for amd nor set up to use it.
ah ok i tried updating my bios could not find any with ufwd
vulkaninfo
ERROR: [Loader Message] Code 0 : setup_loader_term_phys_devs: Failed to detect any valid GPUs in the current config
ERROR at /usr/src/debug/vulkan-tools/Vulkan-Tools/vulkaninfo/./vulkaninfo.h:248:vkEnumeratePhysicalDevices failed with ERROR_INITIALIZATION_FAILED
[anon@anon-system
I personally wouldn’t use that method and sorry I mistakenly said it was a hybrid thinking it was a laptop while knowing otherwise thinking about the Bios at the same moment. It obviously has an amd gpu and you have an nvidia card also.
no i have 2 gpus working toghter at the same time
self built pc its a desktop
they both are working i am using them at the same time to play games etc i can run any game
For vulkan did you install vulkan-radeon?
I would also set it up for hardware acceleration and accelerated video decoding.
Edit: This is just one thing and not likely related to your issue mot likely.
Bios update
no i didnt set it up but it still works and my nvidea works only in discrete
