fireboi
September 3, 2023, 1:49pm
1
Hello all!
I keep having a very weird problem that persists for months now with no solution.
My problem is that sometimes (80%) the system will totally freeze during power off.
I can see the message Reached target System Power Off. and the LED code on my motherboard turns 05 (undocumented). The keyboard is powered off, so no sysrq works to shut down the PC apart from pressing the power button, doesnt matter how long I wait, it will never shutdown otherwise. Journal logs are no help in determining what is the problem, and keep in mind that windows totally shuts down the PC successfully every time.
I would appreciate any pointers on what might be the problem.
Thanks!
Host: beast Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10
wm: kwin_x11 vt: 2 dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: MAXIMUS IX HERO v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1301
date: 03/14/2018
Info: quad core model: Intel Core i7-7700K bits: 64 type: MT MCP
smt: enabled arch: Kaby Lake rev: 9 cache: L1: 256 KiB L2: 1024 KiB
L3: 8 MiB
Speed (MHz): avg: 1225 high: 4200 min/max: 800/4500 cores: 1: 800 2: 800
3: 800 4: 800 5: 800 6: 4200 7: 800 8: 800 bogomips: 67200
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia
v: 535.104.05 arch: Pascal pcie: speed: 8 GT/s lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-D-1 bus-ID: 01:00.0
chip-ID: 10de:1b81 class-ID: 0300
Device-2: Microsoft LifeCam VX-2000 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-4:3 chip-ID: 045e:0761
class-ID: 0102
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 95 s-size: 513x292mm (20.20x11.50")
s-diag: 590mm (23.24")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Asus VX239
serial: H1LMTJ019138 res: 1920x1080 hz: 60 dpi: 96
size: 509x286mm (20.04x11.26") diag: 584mm (23") modes: max: 1920x1080
min: 640x480
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce GTX
1070/PCIe/SSE2 direct-render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Microsoft LifeCam VX-2000 driver: snd-usb-audio,uvcvideo
class-ID: 0102
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full
mac: b0:6e:bf:35:62:63
IF-ID-1: br-30058b55d0da state: down mac: 02:42:61:53:44:9f
IF-ID-2: br-6e51c441d121 state: up speed: 10000 Mbps duplex: unknown
mac: 02:42:7f:90:6c:6a
IF-ID-3: docker0 state: down mac: 02:42:a7:2e:80:7e
IF-ID-4: veth3747de5 state: up speed: 10000 Mbps duplex: full
mac: b2:a9:65:48:a4:0f
Bluetooth:
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 1-7:6
chip-ID: 0a12:0001 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
Local Storage: total: 2.73 TiB used: 324.45 GiB (11.6%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 500GB
size: 465.76 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: S4EVNX0T912827X
fw-rev: 2B2QEXM7 temp: 52.9 C scheme: GPT
ID-2: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
speed: 6.0 Gb/s tech: SSD serial: S2RBNX0J604382W fw-rev: 2B6Q scheme: GPT
ID-3: /dev/sdb vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB
speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: Z8E12TBV fw-rev: CC26
scheme: GPT
ID-1: / size: 423.35 GiB used: 324.45 GiB (76.6%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 316 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 34.28 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3
System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 256 Uptime: 1h 26m wakeups: 1 Memory: total: 32 GiB note: est.
available: 31.16 GiB used: 5.68 GiB (18.2%) Init: systemd v: 254
default: graphical Compilers: gcc: 13.2.1 alt: 12 Packages: pm: pacman
pkgs: 1627 Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.29
http://ix.io/4FhK
could be firmware (Bios) setting on power options.
And you do tried other kernels or always only zen?
fireboi
September 3, 2023, 3:01pm
3
Hi, yes, I have also tried the default linux kernel, didn’t change anything.
Can you elaborate on the bios settings you are referring to? And if it was a bios problem, why it doesn’t happen on Windows?
fireboi
September 3, 2023, 3:03pm
4
Also posting GRUB cmdline just in case it has anything to do:
GRUB_CMDLINE_LINUX_DEFAULT="resume=UUID={some_uuid} loglevel=3 nvme_load=YES nvidia-drm.modeset=1 mitigations=off ipv6.disable=1"
xircon
September 3, 2023, 3:35pm
5
Have you tried enabling the nVidia suspend services and changing the location of the temporary files? See #10 and onwards here:
https://wiki.archlinux.org/title/NVIDIA/Tips_and_tricks
My partner’s new machine (a Clevo) will only resume on the LTS kernel (though I have not tried/tested newer kernels for a while).
Sep 03 05:49:11 sddm[867]: Auth: sddm-helper exited with 1
Sep 03 05:49:11 sddm[867]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Sep 03 05:49:11 sddm[867]: Auth: sddm-helper (--socket /tmp/sddm-auth-XXX --id 1 --start /usr/bin/startplasma-x11 --user delta) crashed (exit code 1)
sddm?
Sep 03 05:49:21 dockerd[949]: time="2023-09-03T05:49:21.393080710+03:00" level=warning msg="ShouldRestart failed, container will not be restarted" container=XXX
daemonShuttingDown=true error="restart canceled" execDuration=54.131899651s exitStatus="{137 2023-09-03 02:49:21.379851251 +0000 UTC}" hasBeenManuallyStopped=false restartCount=2511
Sep 03 05:49:21 dockerd[949]: time="2023-09-03T05:49:21.387546888+03:00" level=info msg="ignoring event" container=XXX module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Sep 03 05:49:21 containerd[862]: time="2023-09-03T05:49:21.387524540+03:00" level=info msg="cleaning up dead shim" namespace=moby
Sep 03 05:49:21 containerd[862]: time="2023-09-03T05:49:21.387514502+03:00" level=warning msg="cleaning up after shim disconnected" id=XXX namespace=moby
Sep 03 05:49:21 containerd[862]: time="2023-09-03T05:49:21.387480359+03:00" level=info msg="shim disconnected" id=XXX namespace=moby
Sep 03 05:49:21 systemd[1]: docker-XXX.scope: Deactivated successfully.
Sep 03 05:49:21 dockerd[949]: time="2023-09-03T05:49:21.371161874+03:00" level=info msg="Container failed to exit within 10s of signal 15 - using the force" container=XXX
docker?
Sep 03 05:49:11 plasmashell[5315]: [5315:0903/054911.369808:ERROR:gpu_service_impl.cc(988)] Exiting GPU process because some drivers can't recover from errors. GPU process will restart shortly.
Sep 03 05:49:11 plasmashell[5315]: [5315:0903/054911.369088:ERROR:gles2_cmd_decoder_passthrough.cc(1586)] GLES2DecoderPassthroughImpl: Context lost during MakeCurrent.
Sep 03 05:49:11 plasmashell[5315]: [5315:0903/054911.369050:ERROR:gl_context_egl.cc(473)] eglMakeCurrent failed with error EGL_CONTEXT_LOST
Sep 03 05:49:11 plasmashell[5315]: [5315:0903/054911.368986:ERROR:gl_display.cc(508)] EGL Driver message (Critical) eglMakeCurrent: Failed to make the GLX context current
plasmashell?
i see a bunch of errors…
is the system waked from sleep or hibernation before that?
in cas eBios has settings for how much energy it should save on sleep mode… and stuff… if this is set to a lower level it could be in the way.
fireboi
September 3, 2023, 4:21pm
8
Hi, I don’t think the nVidia trick is applicable to me since my system never hibernates, it’s a desktop, so I have it always on.
Now about the temp files, I guess you mean the .cache ?
fireboi
September 3, 2023, 4:30pm
9
Ok, let me tell what I think about these and correct me if I’m wrong.
SDDM
Yes indeed I have also seen this error, but I suspect, it has to do with sddm receiving the SIGTERM signal before. I have also tried first logging-out and then clicking shutdown, still nothing changes.
Sep 03 05:49:11 sddm-helper[1556]: Signal received: SIGTERM
Docker
I don’t see anything here that will bug the shutdown process. I also sometimes see a waiting time until the docker services are stopped. After they are stopped, it continues doing things until it reaches the System power off target and hangs. Nevertheless, I have also closed the docker services myself as a test, before clicking shutdown and still nothing.
Plasma
Not really sure how to interpret that error, but my nVidia drivers are up-to-date.
Sleep
My system never goes to sleep or hibernation mode, as configured by the power management settings in KDE.
fireboi:
Docker
still could be something not properly stopped in both ways… when only power off or if shutting down docker first.
fireboi
September 3, 2023, 7:43pm
11
Here is also a log of the just now successful shutdown that I had.
Sep 03 22:34:36 systemd-journald[231]: Journal stopped
Sep 03 22:34:36 systemd-journald[231]: Received SIGTERM from PID 1 (systemd-shutdow).
Sep 03 22:34:36 systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Sep 03 22:34:36 systemd-shutdown[1]: Syncing filesystems and block devices.
Sep 03 22:34:36 systemd[1]: Shutting down.
Sep 03 22:34:36 systemd[1]: Reached target System Power Off.
Sep 03 22:34:36 systemd[1]: Finished System Power Off.
Sep 03 22:34:36 systemd[1]: systemd-poweroff.service: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Reached target Late Shutdown Services.
Sep 03 22:34:36 systemd[1]: Reached target System Shutdown.
Sep 03 22:34:36 systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Sep 03 22:34:36 systemd[1]: lvm2-monitor.service: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Reached target Unmount All Filesystems.
Sep 03 22:34:36 systemd[1]: Deactivated swap /dev/disk/by-uuid/488ee30b-b7fb-4112-82d8-e35f588df986.
Sep 03 22:34:36 systemd[1]: dev-disk-by\x2duuid-488ee30b\x2db7fb\x2d4112\x2d82d8\x2de35f588df986.swap: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Deactivated swap /dev/nvme0n1p3.
Sep 03 22:34:36 systemd[1]: dev-nvme0n1p3.swap: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Deactivated swap /dev/disk/by-id/nvme-Samsung_SSD_970_EVO_Plus_500GB_S4EVNX0T912827X-part3.
Sep 03 22:34:36 systemd[1]: dev-disk-by\x2did-nvme\x2dSamsung_SSD_970_EVO_Plus_500GB_S4EVNX0T912827X\x2dpart3.swap: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Deactivated swap /dev/disk/by-diskseq/3-part3.
Sep 03 22:34:36 systemd[1]: dev-disk-by\x2ddiskseq-3\x2dpart3.swap: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Deactivated swap /dev/disk/by-label/swap.
Sep 03 22:34:36 systemd[1]: dev-disk-by\x2dlabel-swap.swap: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Deactivated swap /dev/disk/by-id/nvme-eui.0025385921b07cd6-part3.
Sep 03 22:34:36 systemd[1]: dev-disk-by\x2did-nvme\x2deui.0025385921b07cd6\x2dpart3.swap: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Deactivated swap /dev/disk/by-path/pci-0000:06:00.0-nvme-1-part3.
Sep 03 22:34:36 systemd[1]: dev-disk-by\x2dpath-pci\x2d0000:06:00.0\x2dnvme\x2d1\x2dpart3.swap: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Deactivated swap /dev/disk/by-partuuid/0f403df0-a26b-6f49-8ece-ba496b5515c6.
Sep 03 22:34:36 systemd[1]: dev-disk-by\x2dpartuuid-0f403df0\x2da26b\x2d6f49\x2d8ece\x2dba496b5515c6.swap: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Deactivated swap /dev/disk/by-id/nvme-Samsung_SSD_970_EVO_Plus_500GB_S4EVNX0T912827X_1-part3.
Sep 03 22:34:36 systemd[1]: dev-disk-by\x2did-nvme\x2dSamsung_SSD_970_EVO_Plus_500GB_S4EVNX0T912827X_1\x2dpart3.swap: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Stopped Create Static Device Nodes in /dev.
Sep 03 22:34:36 systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Stopped Remount Root and Kernel File Systems.
Sep 03 22:34:36 systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Sep 03 22:34:36 systemd[1]: Stopped target Preparation for Local File Systems.
Sep 03 22:34:36 systemd[1]: Removed slice Slice /system/systemd-fsck.
Sep 03 22:34:36 systemd[1]: Stopped File System Check on /dev/disk/by-uuid/BEC0-5A3C.
Sep 03 22:34:36 systemd[1]: systemd-fsck@dev-disk-by\x2duuid-BEC0\x2d5A3C.service: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Deactivating swap /dev/disk/by-diskseq/3-part3...
Sep 03 22:34:36 systemd[1]: Stopped target Swaps.
Sep 03 22:34:36 systemd[1]: Unmounted Temporary Directory /tmp.
Sep 03 22:34:36 systemd[1]: tmp.mount: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Unmounted /boot/efi.
Sep 03 22:34:36 systemd[1]: boot-efi.mount: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Unmounting Temporary Directory /tmp...
Sep 03 22:34:36 systemd[1]: Unmounting /boot/efi...
Sep 03 22:34:36 systemd[1]: Stopped target Local File Systems.
Sep 03 22:34:36 systemd[1]: Stopped Create Volatile Files and Directories.
Sep 03 22:34:36 systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Sep 03 22:34:36 systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Stopped Network Time Synchronization.
Sep 03 22:34:36 systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Sep 03 22:34:36 systemd[1]: Stopped Network Name Resolution.
Sep 03 22:34:36 systemd[1]: systemd-resolved.service: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Sep 03 22:34:35 systemd[1]: Stopping Network Time Synchronization...
Sep 03 22:34:35 systemd[1]: Stopped Load Kernel Modules.
Sep 03 22:34:35 systemd[1]: systemd-modules-load.service: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Closed Process Core Dump Socket.
Sep 03 22:34:35 systemd[1]: systemd-coredump.socket: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Stopped Apply Kernel Variables.
Sep 03 22:34:35 systemd[1]: systemd-sysctl.service: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Stopping Network Name Resolution...
Sep 03 22:34:35 systemd[1]: Stopped target Local Verity Protected Volumes.
Sep 03 22:34:35 systemd[1]: Stopped target Local Integrity Protected Volumes.
Sep 03 22:34:35 systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Sep 03 22:34:35 systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Sep 03 22:34:35 systemd[1]: systemd-ask-password-console.path: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Stopped target Local Encrypted Volumes.
Sep 03 22:34:35 systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Sep 03 22:34:35 systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Stopped target System Initialization.
Sep 03 22:34:35 systemd[1]: Closed Docker Socket for the API.
Sep 03 22:34:35 systemd[1]: docker.socket: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Closed D-Bus System Message Bus Socket.
Sep 03 22:34:35 systemd[1]: dbus.socket: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Closed CUPS Scheduler.
Sep 03 22:34:35 systemd[1]: cups.socket: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Stopped target Socket Units.
Sep 03 22:34:35 systemd[1]: user.slice: Consumed 50.495s CPU time.
Sep 03 22:34:35 systemd[1]: Removed slice User and Session Slice.
Sep 03 22:34:35 systemd[1]: Stopped target Slice Units.
Sep 03 22:34:35 systemd[1]: Stopped CUPS Scheduler.
Sep 03 22:34:35 systemd[1]: cups.path: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Stopped target Path Units.
Sep 03 22:34:35 systemd[1]: Stopped target Basic System.
Sep 03 22:34:35 systemd[1]: Stopped D-Bus System Message Bus.
Sep 03 22:34:35 systemd[1]: dbus.service: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Stopping D-Bus System Message Bus...
Sep 03 22:34:35 systemd[1]: Stopped Network Manager.
Sep 03 22:34:35 systemd[1]: NetworkManager.service: Deactivated successfully.
Sep 03 22:34:35 NetworkManager[684]: <info> [1693769675.7986] exiting (success)
Sep 03 22:34:35 dbus-daemon[669]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Sep 03 22:34:35 dbus-daemon[669]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=684 comm="/usr/bin/NetworkManager --no-daemon")
Sep 03 22:34:35 NetworkManager[684]: <info> [1693769675.7773] manager: NetworkManager state is now CONNECTED_SITE
Sep 03 22:34:35 NetworkManager[684]: <info> [1693769675.7755] caught SIGTERM, shutting down normally.
Sep 03 22:34:35 systemd[1]: Stopping Network Manager...
Sep 03 22:34:35 systemd[1]: Stopped target Remote File Systems.
Sep 03 22:34:35 systemd[1]: Stopped target Network.
Sep 03 22:34:35 systemd[1]: user-1000.slice: Consumed 49.521s CPU time.
Sep 03 22:34:35 systemd[1]: Removed slice User Slice of UID 1000.
Sep 03 22:34:35 systemd[1]: Stopped User Runtime Directory /run/user/1000.
Sep 03 22:34:35 systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Unmounted /run/user/1000.
Sep 03 22:34:35 systemd[1]: run-user-1000.mount: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Stopped Permit User Sessions.
Sep 03 22:34:35 systemd[1]: systemd-user-sessions.service: Deactivated successfully.
Sep 03 22:34:35 systemd[1]: Stopping User Runtime Directory /run/user/1000...
Sep 03 22:34:35 systemd[1]: Stopping Permit User Sessions...
Sep 03 22:34:35 systemd[1]: user@1000.service: Consumed 49.073s CPU time.
Sep 03 22:34:35 systemd[1]: Stopped User Manager for UID 1000.
Sep 03 22:34:35 systemd[1]: user@1000.service: Deactivated successfully.
Sep 03 22:34:35 (sd-pam)[1086]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[delta] ruser=[<unknown>] rhost=[<unknown>]
Sep 03 22:34:35 systemd[1085]: Reached target Exit the Session.
Sep 03 22:34:35 systemd[1085]: Finished Exit the Session.
Sep 03 22:34:35 systemd[1085]: Reached target Shutdown.
Sep 03 22:34:35 systemd[1085]: app.slice: Consumed 38.877s CPU time.
Sep 03 22:34:35 systemd[1085]: Removed slice User Application Slice.
Sep 03 22:34:35 systemd[1085]: Closed PipeWire Multimedia System Socket.
Sep 03 22:34:35 systemd[1085]: Closed PipeWire PulseAudio.
Sep 03 22:34:35 systemd[1085]: Closed p11-kit server.
Sep 03 22:34:35 systemd[1085]: Closed GnuPG cryptographic agent and passphrase cache.
Sep 03 22:34:35 systemd[1085]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Sep 03 22:34:35 systemd[1085]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Sep 03 22:34:35 systemd[1085]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Sep 03 22:34:35 systemd[1085]: Closed Docker Socket for the API.
Sep 03 22:34:35 systemd[1085]: Closed GnuPG network certificate management daemon.
Sep 03 22:34:35 systemd[1085]: Closed D-Bus User Message Bus Socket.
Sep 03 22:34:35 systemd[1085]: Stopped EOS update notifier runs periodically (weekly) and soon after a reboot.
Sep 03 22:34:35 systemd[1085]: Stopped target Timers.
Sep 03 22:34:35 systemd[1085]: Stopped target Sockets.
Sep 03 22:34:35 systemd[1085]: Stopped target Paths.
Sep 03 22:34:35 systemd[1085]: Stopped target Basic System.
Sep 03 22:34:35 systemd[1085]: Stopped Docker Application Container Engine (Rootless).
Sep 03 22:34:34 systemd[1]: Stopped User Login Management.
Sep 03 22:34:34 systemd[1]: systemd-logind.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopping User Login Management...
Sep 03 22:34:34 systemd-logind[676]: Removed session 2.
Sep 03 22:34:34 systemd[1]: Stopped containerd container runtime.
Sep 03 22:34:34 systemd[1085]: session.slice: Consumed 5.737s CPU time.
Sep 03 22:34:34 systemd[1085]: Removed slice User Core Session Slice.
Sep 03 22:34:34 systemd[1085]: Stopped PipeWire Multimedia Service.
Sep 03 22:34:34 systemd[1085]: Stopping PipeWire Multimedia Service...
Sep 03 22:34:34 systemd[1085]: Stopped Multimedia Service Session Manager.
Sep 03 22:34:34 systemd[1]: containerd.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: sddm.service: Consumed 2.608s CPU time.
Sep 03 22:34:34 systemd[1]: Stopped Simple Desktop Display Manager.
Sep 03 22:34:34 wireplumber[1280]: disconnected from pipewire
Sep 03 22:34:34 wireplumber[1280]: stopped by signal: Terminated
Sep 03 22:34:34 systemd[1085]: Stopping Multimedia Service Session Manager...
Sep 03 22:34:34 systemd[1085]: Stopped PipeWire PulseAudio.
Sep 03 22:34:34 systemd[1085]: Stopped D-Bus User Message Bus.
Sep 03 22:34:34 systemd[1085]: Stopped Bluetooth OBEX service.
Sep 03 22:34:34 dockerd-rootless.sh[2501]: time="2023-09-03T22:34:34.632166769+03:00" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
Sep 03 22:34:34 dockerd-rootless.sh[2501]: time="2023-09-03T22:34:34.632150585+03:00" level=info msg="stopping healthcheck following graceful shutdown" module=libcontainerd
Sep 03 22:34:34 dockerd-rootless.sh[2501]: time="2023-09-03T22:34:34.632130604+03:00" level=info msg="Daemon shutdown complete"
Sep 03 22:34:34 systemd[1085]: obex.service: Failed with result 'exit-code'.
Sep 03 22:34:34 systemd[1085]: obex.service: Main process exited, code=exited, status=1/FAILURE
Sep 03 22:34:34 dockerd-rootless.sh[2501]: time="2023-09-03T22:34:34.631977634+03:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Sep 03 22:34:34 systemd[1085]: Stopped User preferences database.
Sep 03 22:34:34 dockerd-rootless.sh[2501]: time="2023-09-03T22:34:34.631605134+03:00" level=info msg="Processing signal 'terminated'"
Sep 03 22:34:34 systemd[1085]: Stopping PipeWire PulseAudio...
Sep 03 22:34:34 systemd[1085]: Stopping Bluetooth OBEX service...
Sep 03 22:34:34 systemd[1085]: Stopping Docker Application Container Engine (Rootless)...
Sep 03 22:34:34 systemd[1085]: Stopping User preferences database...
Sep 03 22:34:34 systemd[1085]: Stopping D-Bus User Message Bus...
Sep 03 22:34:34 systemd[1085]: Stopped target Main User Target.
Sep 03 22:34:34 systemd[1085]: background.slice: Consumed 3.883s CPU time.
Sep 03 22:34:34 systemd[1085]: Removed slice User Background Tasks Slice.
Sep 03 22:34:34 systemd[1085]: Activating special unit Exit the Session...
Sep 03 22:34:34 systemd[1]: sddm.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopping User Manager for UID 1000...
Sep 03 22:34:34 containerd[781]: time="2023-09-03T22:34:34.629595935+03:00" level=info msg="Stop CRI service"
Sep 03 22:34:34 systemd[1]: Stopping containerd container runtime...
Sep 03 22:34:34 systemd[1]: Stopped Network Manager Wait Online.
Sep 03 22:34:34 sddm[784]: Running display stop script ("/usr/share/sddm/scripts/Xstop")
Sep 03 22:34:34 sddm[784]: Display server stopped.
Sep 03 22:34:34 systemd[1]: NetworkManager-wait-online.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped target System Time Set.
Sep 03 22:34:34 systemd[1]: Stopped target Network is Online.
Sep 03 22:34:34 systemd-logind[676]: Session 2 logged out. Waiting for processes to exit.
Sep 03 22:34:34 systemd[1]: Stopped Session 2 of User delta.
Sep 03 22:34:34 systemd[1]: session-2.scope: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Finished Generate shutdown-ramfs.
Sep 03 22:34:34 systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Load/Save OS Random Seed.
Sep 03 22:34:34 mkinitcpio[2809]: ==> Build complete.
Sep 03 22:34:34 systemd[1]: systemd-random-seed.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Initialize hardware monitoring sensors.
Sep 03 22:34:34 systemd[1]: lm_sensors.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Save/Restore Sound Card State.
Sep 03 22:34:34 systemd[1]: alsa-restore.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Sep 03 22:34:34 systemd[1]: rtkit-daemon.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Docker Application Container Engine.
Sep 03 22:34:34 systemd[1]: docker.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Daemon for power management.
Sep 03 22:34:34 systemd[1]: upower.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Disk Manager.
Sep 03 22:34:34 systemd[1]: udisks2.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped CUPS Scheduler.
Sep 03 22:34:34 mkinitcpio[2809]: -> Running build hook: [sd-shutdown]
Sep 03 22:34:34 mkinitcpio[2809]: ==> Starting build: 'none'
Sep 03 22:34:34 systemd[1]: cups.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Power Profiles daemon.
Sep 03 22:34:34 systemd[1]: power-profiles-daemon.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Authorization Manager.
Sep 03 22:34:34 udisksd[891]: udisks daemon version 2.9.4 exiting
Sep 03 22:34:34 systemd[1]: polkit.service: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopping Daemon for power management...
Sep 03 22:34:34 systemd[1]: Stopping Disk Manager...
Sep 03 22:34:34 systemd[1]: Stopping Load/Save OS Random Seed...
Sep 03 22:34:34 systemd[1]: Stopping Simple Desktop Display Manager...
Sep 03 22:34:34 sddm[784]: Display server stopping...
Sep 03 22:34:34 sddm[784]: Socket server stopped.
Sep 03 22:34:34 sddm[784]: Socket server stopping...
Sep 03 22:34:34 sddm[784]: Signal received: SIGTERM
Sep 03 22:34:34 systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Sep 03 22:34:34 systemd[1]: Stopping Power Profiles daemon...
Sep 03 22:34:34 systemd[1]: Stopping Authorization Manager...
Sep 03 22:34:34 systemd[1]: Starting Generate shutdown-ramfs...
Sep 03 22:34:34 dockerd[923]: time="2023-09-03T22:34:34.420753263+03:00" level=info msg="Daemon shutdown complete"
Sep 03 22:34:34 (modprobe)[2808]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
Sep 03 22:34:34 systemd[1]: Stopping Initialize hardware monitoring sensors...
Sep 03 22:34:34 dockerd[923]: time="2023-09-03T22:34:34.420375024+03:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Sep 03 22:34:34 systemd[1]: Stopping Docker Application Container Engine...
Sep 03 22:34:34 dockerd[923]: time="2023-09-03T22:34:34.418923309+03:00" level=info msg="Processing signal 'terminated'"
Sep 03 22:34:34 systemd[1]: Stopping CUPS Scheduler...
Sep 03 22:34:34 systemd[1]: Stopping Save/Restore Sound Card State...
Sep 03 22:34:34 systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Sep 03 22:34:34 systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Closed LVM2 poll daemon socket.
Sep 03 22:34:34 systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Daily locate database update.
Sep 03 22:34:34 systemd[1]: updatedb.timer: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Sep 03 22:34:34 systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Daily verification of password and group files.
Sep 03 22:34:34 systemd[1]: shadow.timer: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Refresh Pacman mirrorlist weekly with Reflector..
Sep 03 22:34:34 systemd[1]: reflector.timer: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Discard unused packages weekly.
Sep 03 22:34:34 systemd[1]: paccache.timer: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Daily man-db regeneration.
Sep 03 22:34:34 systemd[1]: man-db.timer: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Daily rotation of log files.
Sep 03 22:34:34 systemd[1]: logrotate.timer: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Discard unused filesystem blocks once a week.
Sep 03 22:34:34 systemd[1]: fstrim.timer: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
Sep 03 22:34:34 systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
Sep 03 22:34:34 systemd[1]: Stopped target Timer Units.
Sep 03 22:34:34 systemd[1]: Stopped target Sound Card.
Sep 03 22:34:34 systemd[1]: Stopped target Smart Card.
Sep 03 22:34:34 systemd[1]: Stopped target Host and Network Name Lookups.
Sep 03 22:34:34 systemd[1]: Stopped target Login Prompts.
Sep 03 22:34:34 systemd[1]: Stopped target Multi-User System.
Sep 03 22:34:34 systemd[1]: Stopped target Graphical Interface.
Sep 03 22:34:34 systemd[1]: Stopped target Bluetooth Support.
Sep 03 22:34:34 systemd[1]: Removed slice Slice /system/modprobe.
Sep 03 22:34:34 systemd[1085]: Stopped KDE Daemon.
Sep 03 22:34:34 systemd[1]: Removed slice Slice /system/getty.
Sep 03 22:34:34 systemd[1085]: plasma-kwin_x11.service: Consumed 1.309s CPU time.
Sep 03 22:34:34 systemd[1085]: Stopped KDE Window Manager.
Sep 03 22:34:34 sddm[784]: Auth: sddm-helper exited with 1
Sep 03 22:34:34 sddm[784]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Sep 03 22:34:34 sddm[784]: Auth: sddm-helper (--socket /tmp/sddm-auth-575593cb-f9bf-4954-abec-aa1d74fd4580 --id 1 --start /usr/bin/startplasma-x11 --user delta) crashed (exit code 1)
Sep 03 22:34:34 systemd[1]: Stopping Session 2 of User delta...
Sep 03 22:34:34 sddm-helper[1082]: Signal received: SIGTERM
Sep 03 22:34:34 systemd[1085]: Stopped KActivityManager Activity manager Service.
Sep 03 22:34:34 systemd-logind[676]: System is powering down.
Sep 03 22:34:34 systemd-logind[676]: The system will power off now!
Sep 03 22:34:34 systemd[1085]: plasma-plasmashell.service: Consumed 2.788s CPU time.
Sep 03 22:34:34 systemd[1085]: Stopped KDE Plasma Workspace.
Sep 03 22:34:34 systemd[1085]: Stopping KActivityManager Activity manager Service...
Sep 03 22:34:34 systemd[1085]: Stopped target Session services which should run early before the graphical session is brought up.
Sep 03 22:34:34 systemd[1085]: Stopped target Current graphical user session.
Sep 03 22:34:34 systemd[1085]: Stopped Accessibility.
Sep 03 22:34:34 kded5[1165]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Sep 03 22:34:34 systemd[1085]: kde-baloo.service: Consumed 2.826s CPU time.
Sep 03 22:34:34 systemd[1085]: Stopped Baloo File Indexer Daemon.
Sep 03 22:34:34 systemd[1085]: Stopping KDE Daemon...
Sep 03 22:34:34 systemd[1085]: Stopped target KDE Plasma Workspace Core.
Sep 03 22:34:34 systemd[1085]: Stopped Xdg Desktop Portal For KDE.
Sep 03 22:34:34 systemd[1085]: Stopped KDE Session Management Server.
Sep 03 22:34:34 systemd[1085]: Stopped Powerdevil.
Sep 03 22:34:34 systemd[1085]: Stopped Portal service.
Sep 03 22:34:34 systemd[1085]: Stopped flatpak document portal service.
Sep 03 22:34:34 systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
Sep 03 22:34:34 systemd[1085]: Stopped sandboxed app permission store.
Sep 03 22:34:34 systemd[1085]: Stopped Accessibility services bus.
Sep 03 22:34:34 systemd[1085]: Stopped Geoclue Demo agent.
Sep 03 22:34:34 systemd[1085]: Stopped KScreen.
Sep 03 22:34:34 systemd[1085]: Stopped KDE Global Shortcuts Server.
Sep 03 22:34:34 systemd[1085]: Stopping Baloo File Indexer Daemon...
Sep 03 22:34:34 systemd[1085]: Stopping sandboxed app permission store...
Sep 03 22:34:34 systemd[1085]: Stopping flatpak document portal service...
Sep 03 22:34:34 systemd[1085]: Stopping Portal service...
Sep 03 22:34:34 systemd[1085]: Stopping Xdg Desktop Portal For KDE...
Sep 03 22:34:34 systemd[1085]: Stopping Powerdevil...
Sep 03 22:34:34 systemd[1085]: Stopping KDE Window Manager...
Sep 03 22:34:34 systemd[1085]: Stopping KScreen...
Sep 03 22:34:34 systemd[1085]: Stopping KDE Global Shortcuts Server...
Sep 03 22:34:34 systemd[1085]: Stopping Accessibility services bus...
Sep 03 22:34:34 systemd[1085]: Stopping Accessibility...
Sep 03 22:34:34 systemd[1085]: Stopping Geoclue Demo agent...
Sep 03 22:34:34 systemd[1085]: Stopped target Startup of XDG autostart applications.
Sep 03 22:34:34 systemd[1085]: Stopped target KDE Plasma Workspace.
Sep 03 22:34:34 systemd[1085]: Stopped target plasma-workspace-x11.target.
Sep 03 22:34:34 polkitd[698]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.60, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Sep 03 22:34:34 dbus-daemon[1108]: [session uid=1000 pid=1108] Successfully activated service 'org.kde.Shutdown'
Sep 03 22:34:34 dbus-daemon[1108]: [session uid=1000 pid=1108] Activating service name='org.kde.Shutdown' requested by ':1.46' (uid=1000 pid=2753 comm="/usr/lib/ksmserver-logout-greeter")
Sep 03 22:34:32 dbus-daemon[1108]: [session uid=1000 pid=1108] Successfully activated service 'org.kde.LogoutPrompt'
Sep 03 22:34:31 dbus-daemon[1108]: [session uid=1000 pid=1108] Activating service name='org.kde.LogoutPrompt' requested by ':1.17' (uid=1000 pid=1197 comm="/usr/bin/plasmashell --no-respawn")
Sep 03 22:34:29 systemd[1085]: app-firefox-e71fa1b463164f38bfee707209137433.scope: Consumed 36.400s CPU time.
Sep 03 22:34:28 systemd[1085]: app-org.kde.konsole-6d2cd908dcfe49149a4c2abffe52646d.scope: Consumed 1.324s CPU time.
I removed all the containers that I had running, and then shutdown. But I doubt that was the cause as even in the previous hang I can see the message. Stopped Docker Application Container Engine.
Nevertheless I will not run any containers here for a week and observe. It’s really hard to debug all this because it only happens sometimes .
fireboi
September 4, 2023, 10:16am
12
And another hang from last night, this time including kernel stack trace and plasmashell errors.
Sep 04 03:33:17 systemd-journald[233]: Journal stopped
Sep 04 03:33:17 systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Sep 04 03:33:17 systemd-shutdown[1]: Syncing filesystems and block devices.
Sep 04 03:33:16 systemd[1]: Shutting down.
Sep 04 03:33:16 systemd[1]: Reached target System Power Off.
Sep 04 03:33:16 systemd[1]: Finished System Power Off.
Sep 04 03:33:16 systemd[1]: systemd-poweroff.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Reached target Late Shutdown Services.
Sep 04 03:33:16 systemd[1]: Reached target Unmount All Filesystems.
Sep 04 03:33:16 systemd[1]: Reached target System Shutdown.
Sep 04 03:33:16 systemd[1]: Deactivated swap /dev/disk/by-uuid/488ee30b-b7fb-4112-82d8-e35f588df986.
Sep 04 03:33:16 systemd[1]: dev-disk-by\x2duuid-488ee30b\x2db7fb\x2d4112\x2d82d8\x2de35f588df986.swap: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Deactivated swap /dev/nvme0n1p3.
Sep 04 03:33:16 systemd[1]: dev-nvme0n1p3.swap: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Deactivated swap /dev/disk/by-id/nvme-Samsung_SSD_970_EVO_Plus_500GB_S4EVNX0T912827X_1-part3.
Sep 04 03:33:16 systemd[1]: dev-disk-by\x2did-nvme\x2dSamsung_SSD_970_EVO_Plus_500GB_S4EVNX0T912827X_1\x2dpart3.swap: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Deactivated swap /dev/disk/by-label/swap.
Sep 04 03:33:16 systemd[1]: dev-disk-by\x2dlabel-swap.swap: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Deactivated swap /dev/disk/by-id/nvme-Samsung_SSD_970_EVO_Plus_500GB_S4EVNX0T912827X-part3.
Sep 04 03:33:16 systemd[1]: dev-disk-by\x2did-nvme\x2dSamsung_SSD_970_EVO_Plus_500GB_S4EVNX0T912827X\x2dpart3.swap: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Deactivated swap /dev/disk/by-diskseq/3-part3.
Sep 04 03:33:16 systemd[1]: dev-disk-by\x2ddiskseq-3\x2dpart3.swap: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Deactivated swap /dev/disk/by-id/nvme-eui.0025385921b07cd6-part3.
Sep 04 03:33:16 systemd[1]: dev-disk-by\x2did-nvme\x2deui.0025385921b07cd6\x2dpart3.swap: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Deactivated swap /dev/disk/by-partuuid/0f403df0-a26b-6f49-8ece-ba496b5515c6.
Sep 04 03:33:16 systemd[1]: dev-disk-by\x2dpartuuid-0f403df0\x2da26b\x2d6f49\x2d8ece\x2dba496b5515c6.swap: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Deactivated swap /dev/disk/by-path/pci-0000:06:00.0-nvme-1-part3.
Sep 04 03:33:16 systemd[1]: dev-disk-by\x2dpath-pci\x2d0000:06:00.0\x2dnvme\x2d1\x2dpart3.swap: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Sep 04 03:33:16 systemd[1]: lvm2-monitor.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Deactivating swap /dev/disk/by-diskseq/3-part3...
Sep 04 03:33:16 systemd[1]: Stopped target Swaps.
Sep 04 03:33:16 systemd[1]: Unmounted Temporary Directory /tmp.
Sep 04 03:33:16 systemd[1]: tmp.mount: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped Create Static Device Nodes in /dev.
Sep 04 03:33:16 systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped Remount Root and Kernel File Systems.
Sep 04 03:33:16 systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Sep 04 03:33:16 systemd[1]: Stopped target Preparation for Local File Systems.
Sep 04 03:33:16 systemd[1]: Removed slice Slice /system/systemd-fsck.
Sep 04 03:33:16 systemd[1]: Stopped File System Check on /dev/disk/by-uuid/BEC0-5A3C.
Sep 04 03:33:16 systemd[1]: systemd-fsck@dev-disk-by\x2duuid-BEC0\x2d5A3C.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Unmounted /boot/efi.
Sep 04 03:33:16 systemd[1]: boot-efi.mount: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Unmounting Temporary Directory /tmp...
Sep 04 03:33:16 systemd[1]: Unmounting /boot/efi...
Sep 04 03:33:16 systemd[1]: Stopped target Local File Systems.
Sep 04 03:33:16 systemd[1]: Stopped Create Volatile Files and Directories.
Sep 04 03:33:16 systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Sep 04 03:33:16 systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped Network Time Synchronization.
Sep 04 03:33:16 systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: systemd-resolved.service: Consumed 4.199s CPU time.
Sep 04 03:33:16 systemd[1]: Stopped Network Name Resolution.
Sep 04 03:33:16 systemd[1]: systemd-resolved.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Sep 04 03:33:16 systemd[1]: Stopping Network Time Synchronization...
Sep 04 03:33:16 systemd[1]: Stopped Load Kernel Modules.
Sep 04 03:33:16 systemd[1]: systemd-modules-load.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Closed Process Core Dump Socket.
Sep 04 03:33:16 systemd[1]: systemd-coredump.socket: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped Apply Kernel Variables.
Sep 04 03:33:16 systemd[1]: systemd-sysctl.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopping Network Name Resolution...
Sep 04 03:33:16 systemd[1]: Stopped target Local Verity Protected Volumes.
Sep 04 03:33:16 systemd[1]: Stopped target Local Integrity Protected Volumes.
Sep 04 03:33:16 systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Sep 04 03:33:16 systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Sep 04 03:33:16 systemd[1]: systemd-ask-password-console.path: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped target Local Encrypted Volumes.
Sep 04 03:33:16 systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Sep 04 03:33:16 systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped target System Initialization.
Sep 04 03:33:16 systemd[1]: Closed Docker Socket for the API.
Sep 04 03:33:16 systemd[1]: docker.socket: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Closed D-Bus System Message Bus Socket.
Sep 04 03:33:16 systemd[1]: dbus.socket: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Closed CUPS Scheduler.
Sep 04 03:33:16 systemd[1]: cups.socket: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped target Socket Units.
Sep 04 03:33:16 systemd[1]: user.slice: Consumed 2h 6min 27.059s CPU time.
Sep 04 03:33:16 systemd[1]: Removed slice User and Session Slice.
Sep 04 03:33:16 systemd[1]: Stopped target Slice Units.
Sep 04 03:33:16 systemd[1]: Stopped CUPS Scheduler.
Sep 04 03:33:16 systemd[1]: cups.path: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped target Path Units.
Sep 04 03:33:16 systemd[1]: Stopped target Basic System.
Sep 04 03:33:16 systemd[1]: dbus.service: Consumed 1.843s CPU time.
Sep 04 03:33:16 systemd[1]: Stopped D-Bus System Message Bus.
Sep 04 03:33:16 systemd[1]: dbus.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopping D-Bus System Message Bus...
Sep 04 03:33:16 dbus-daemon[467]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Sep 04 03:33:16 systemd[1]: Stopped Network Manager.
Sep 04 03:33:16 systemd[1]: NetworkManager.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped WPA supplicant.
Sep 04 03:33:16 NetworkManager[481]: <info> [1693787596.3903] exiting (success)
Sep 04 03:33:16 systemd[1]: wpa_supplicant.service: Deactivated successfully.
Sep 04 03:33:16 dbus-daemon[467]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=481 comm="/usr/bin/NetworkManager --no-daemon")
Sep 04 03:33:16 NetworkManager[481]: <info> [1693787596.3754] manager: NetworkManager state is now CONNECTED_SITE
Sep 04 03:33:16 systemd[1]: Stopping WPA supplicant...
Sep 04 03:33:16 NetworkManager[481]: <info> [1693787596.3731] caught SIGTERM, shutting down normally.
Sep 04 03:33:16 systemd[1]: Stopping Network Manager...
Sep 04 03:33:16 systemd[1]: Stopped target Remote File Systems.
Sep 04 03:33:16 systemd[1]: Stopped target Network.
Sep 04 03:33:16 systemd[1]: user-1000.slice: Consumed 2h 6min 26.188s CPU time.
Sep 04 03:33:16 systemd[1]: Removed slice User Slice of UID 1000.
Sep 04 03:33:16 systemd[1]: Stopped User Runtime Directory /run/user/1000.
Sep 04 03:33:16 systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Unmounted /run/user/1000.
Sep 04 03:33:16 systemd[1]: run-user-1000.mount: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped Permit User Sessions.
Sep 04 03:33:16 systemd[1]: systemd-user-sessions.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopping User Runtime Directory /run/user/1000...
Sep 04 03:33:16 systemd[1]: Stopping Permit User Sessions...
Sep 04 03:33:16 systemd[1]: Stopped User Login Management.
Sep 04 03:33:16 systemd[1]: systemd-logind.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: user@1000.service: Consumed 2h 6min 24.358s CPU time.
Sep 04 03:33:16 systemd[1]: Stopped User Manager for UID 1000.
Sep 04 03:33:16 systemd[1]: user@1000.service: Deactivated successfully.
Sep 04 03:33:16 (sd-pam)[1079]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[delta] ruser=[<unknown>] rhost=[<unknown>]
Sep 04 03:33:16 systemd[1]: Stopping User Login Management...
Sep 04 03:33:16 systemd[1078]: Reached target Exit the Session.
Sep 04 03:33:16 systemd[1078]: Finished Exit the Session.
Sep 04 03:33:16 systemd[1078]: Reached target Shutdown.
Sep 04 03:33:16 systemd[1078]: app.slice: Consumed 1h 52min 22.446s CPU time.
Sep 04 03:33:16 systemd[1078]: Removed slice User Application Slice.
Sep 04 03:33:16 systemd[1078]: Closed PipeWire Multimedia System Socket.
Sep 04 03:33:16 systemd[1078]: Closed PipeWire PulseAudio.
Sep 04 03:33:16 systemd[1078]: Closed p11-kit server.
Sep 04 03:33:16 systemd[1078]: Closed GnuPG cryptographic agent and passphrase cache.
Sep 04 03:33:16 systemd[1078]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Sep 04 03:33:16 systemd[1078]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Sep 04 03:33:16 systemd[1078]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Sep 04 03:33:16 systemd[1078]: Closed Docker Socket for the API.
Sep 04 03:33:16 systemd[1078]: Closed GnuPG network certificate management daemon.
Sep 04 03:33:16 systemd[1078]: Closed D-Bus User Message Bus Socket.
Sep 04 03:33:16 systemd[1078]: Stopped EOS update notifier runs periodically (weekly) and soon after a reboot.
Sep 04 03:33:16 systemd[1078]: Stopped target Timers.
Sep 04 03:33:16 systemd[1078]: Stopped target Sockets.
Sep 04 03:33:16 systemd[1078]: Stopped target Paths.
Sep 04 03:33:16 systemd[1078]: Stopped target Basic System.
Sep 04 03:33:16 systemd[1078]: session.slice: Consumed 13min 44.785s CPU time.
Sep 04 03:33:16 systemd[1078]: Removed slice User Core Session Slice.
Sep 04 03:33:16 systemd[1078]: pipewire.service: Consumed 45.573s CPU time.
Sep 04 03:33:16 systemd[1078]: Stopped PipeWire Multimedia Service.
Sep 04 03:33:16 systemd-logind[470]: Removed session 2.
Sep 04 03:33:16 systemd[1078]: Stopping PipeWire Multimedia Service...
Sep 04 03:33:16 systemd[1]: containerd.service: Consumed 16.782s CPU time.
Sep 04 03:33:16 systemd[1078]: Stopped Multimedia Service Session Manager.
Sep 04 03:33:16 systemd[1]: Stopped containerd container runtime.
Sep 04 03:33:16 wireplumber[1282]: disconnected from pipewire
Sep 04 03:33:16 wireplumber[1282]: stopped by signal: Terminated
Sep 04 03:33:16 systemd[1]: containerd.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: sddm.service: Consumed 6min 35.334s CPU time.
Sep 04 03:33:16 systemd[1]: Stopped Simple Desktop Display Manager.
Sep 04 03:33:16 systemd[1078]: dbus.service: Consumed 1.452s CPU time.
Sep 04 03:33:16 systemd[1078]: Stopped D-Bus User Message Bus.
Sep 04 03:33:16 systemd[1078]: Stopping Multimedia Service Session Manager...
Sep 04 03:33:16 systemd[1078]: pipewire-pulse.service: Consumed 4min 56.500s CPU time.
Sep 04 03:33:16 systemd[1078]: Stopped PipeWire PulseAudio.
Sep 04 03:33:16 systemd[1078]: app-org.kde.konsole-ebd6569ae88043d68094df3170472529.scope: Consumed 9min 27.912s CPU time.
Sep 04 03:33:16 systemd[1078]: Stopped Konsole - Terminal.
Sep 04 03:33:16 systemd[1078]: Stopped Bluetooth OBEX service.
Sep 04 03:33:16 systemd[1078]: obex.service: Failed with result 'exit-code'.
Sep 04 03:33:16 systemd[1078]: obex.service: Main process exited, code=exited, status=1/FAILURE
Sep 04 03:33:16 systemd[1078]: Stopped User preferences database.
Sep 04 03:33:16 systemd[1078]: Stopping PipeWire PulseAudio...
Sep 04 03:33:16 systemd[1078]: Stopping Bluetooth OBEX service...
Sep 04 03:33:16 systemd[1078]: Stopping User preferences database...
Sep 04 03:33:16 systemd[1078]: Stopping D-Bus User Message Bus...
Sep 04 03:33:16 systemd[1078]: Stopped target Main User Target.
Sep 04 03:33:16 systemd[1078]: background.slice: Consumed 16.698s CPU time.
Sep 04 03:33:16 systemd[1078]: Removed slice User Background Tasks Slice.
Sep 04 03:33:16 systemd[1078]: Stopping Konsole - Terminal...
Sep 04 03:33:16 systemd[1]: sddm.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1078]: Activating special unit Exit the Session...
Sep 04 03:33:16 systemd[1]: Stopping User Manager for UID 1000...
Sep 04 03:33:16 containerd[527]: time="2023-09-04T03:33:16.165622689+03:00" level=info msg="Stream server stopped"
Sep 04 03:33:16 containerd[527]: time="2023-09-04T03:33:16.165618156+03:00" level=info msg="Event monitor stopped"
Sep 04 03:33:16 containerd[527]: time="2023-09-04T03:33:16.165603164+03:00" level=info msg="Stop CRI service"
Sep 04 03:33:16 containerd[527]: time="2023-09-04T03:33:16.165547477+03:00" level=info msg="Stop CRI service"
Sep 04 03:33:16 systemd[1]: Stopping containerd container runtime...
Sep 04 03:33:16 systemd[1]: Stopped Network Manager Wait Online.
Sep 04 03:33:16 sddm[530]: Running display stop script ("/usr/share/sddm/scripts/Xstop")
Sep 04 03:33:16 sddm[530]: Display server stopped.
Sep 04 03:33:16 systemd[1]: NetworkManager-wait-online.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped target System Time Set.
Sep 04 03:33:16 systemd[1]: Stopped target Network is Online.
Sep 04 03:33:16 systemd-logind[470]: Session 2 logged out. Waiting for processes to exit.
Sep 04 03:33:16 systemd[1]: session-2.scope: Consumed 1.814s CPU time.
Sep 04 03:33:16 systemd[1]: Stopped Session 2 of User delta.
Sep 04 03:33:16 systemd[1]: session-2.scope: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped Load/Save OS Random Seed.
Sep 04 03:33:16 systemd[1]: systemd-random-seed.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Finished Generate shutdown-ramfs.
Sep 04 03:33:16 systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped Initialize hardware monitoring sensors.
Sep 04 03:33:16 systemd[1]: lm_sensors.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped Save/Restore Sound Card State.
Sep 04 03:33:16 systemd[1]: alsa-restore.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Sep 04 03:33:16 systemd[1]: rtkit-daemon.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: docker.service: Consumed 3.806s CPU time.
Sep 04 03:33:16 systemd[1]: Stopped Docker Application Container Engine.
Sep 04 03:33:16 mkinitcpio[41373]: ==> Build complete.
Sep 04 03:33:16 systemd[1]: docker.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: Stopped Daemon for power management.
Sep 04 03:33:16 systemd[1]: upower.service: Deactivated successfully.
Sep 04 03:33:16 systemd[1]: udisks2.service: Consumed 3.626s CPU time.
Sep 04 03:33:16 systemd[1]: Stopped Disk Manager.
Sep 04 03:33:16 systemd[1078]: app-discord-f7520091b18d45b0a2d9f4dfdb447b5b.scope: Consumed 27min 59.044s CPU time.
Sep 04 03:33:16 plasmashell[3765]: [0904/033316.014179:ERROR:scoped_ptrace_attach.cc(45)] ptrace: No such process (3)
Sep 04 03:33:16 plasmashell[3765]: [0904/033316.014039:ERROR:process_snapshot_linux.cc(78)] Couldn't read exception info
Sep 04 03:33:16 plasmashell[3765]: [0904/033316.014036:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:16 plasmashell[3765]: [0904/033316.014021:ERROR:scoped_ptrace_attach.cc(37)] process not stopped
Sep 04 03:33:16 systemd[1]: udisks2.service: Deactivated successfully.
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981722:WARNING:process_reader_linux.cc(398)] Couldn't initialize main thread.
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981717:ERROR:ptracer.cc(446)] Unexpected registers size 0 != 216
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981712:ERROR:ptracer.cc(422)] ptrace: No such process (3)
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981707:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981700:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981696:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981692:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981685:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981682:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981679:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981676:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981672:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981668:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981665:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981661:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981657:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981644:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981344:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981340:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981336:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981332:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981326:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981322:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981318:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981314:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981310:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981306:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981302:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981298:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981294:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981290:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981286:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981282:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981277:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981273:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981269:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981265:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981261:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981257:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981247:ERROR:process_reader_linux.cc(540)] no module mappings 0x7e6af1640000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981243:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981158:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b00e7f000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981154:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981065:ERROR:process_reader_linux.cc(540)] no module mappings 0x7e6af7ea6000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.981061:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980979:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b0166a000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980975:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980886:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b022a6000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980882:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980794:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b02600000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980791:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980787:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980675:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b0ac46000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980669:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980570:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b03bcd000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980566:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980468:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b0698c000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980463:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980365:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b08bee000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980360:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980258:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b51377000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980254:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980158:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b0acd6000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980154:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980064:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b544a1000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.980060:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979959:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b544a9000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979954:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979847:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b513fa000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979845:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979782:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b5452f000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979780:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979715:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54584000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979713:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979651:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b57ee6000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979648:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979577:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b5458e000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979575:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979513:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b08b69000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979511:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979449:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b06814000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979446:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979382:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b52469000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979380:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979315:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b5448d000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979313:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979252:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b547f2000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979249:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979188:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54950000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979185:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979123:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54975000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979121:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979059:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54988000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.979057:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978995:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54991000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978992:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978930:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54ae3000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978927:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978860:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54c45000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978858:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978795:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54c7b000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978793:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978730:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54d0e000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978727:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978662:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54dc0000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978659:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978590:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54de2000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978588:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 systemd[1]: cups.service: Deactivated successfully.
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978526:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54de8000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978523:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978461:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54df6000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978459:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978396:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54dfb000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978394:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978331:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54e02000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978329:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978266:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54e16000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978263:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978197:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54e4a000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978194:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978129:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54e6c000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978127:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978064:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54fae000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.978062:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977999:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b54fc2000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977996:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977927:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55067000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977925:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977856:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b550b0000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977853:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977790:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55108000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977787:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977724:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55120000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977722:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977659:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b552d9000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977656:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977593:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b552fe000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977591:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977526:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b553d1000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977523:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977459:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b553df000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977456:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977390:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55483000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977386:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977305:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55602000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977302:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977232:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55650000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977227:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977123:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b5565d000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977118:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977014:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55662000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.977009:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976904:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55674000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976899:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976804:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55689000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976800:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976736:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55730000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976733:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976639:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b5573c000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976633:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976537:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b5574b000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976534:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976470:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55758000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976467:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976400:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b5581f000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976395:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976292:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55860000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976287:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976179:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b5586b000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976174:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976064:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55939000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.976059:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975945:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b5595d000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975936:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975821:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55971000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975816:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975705:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55a95000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975699:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975589:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55ae7000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975584:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975504:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b5625d000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975499:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975384:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55b08000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975378:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975262:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b562ac000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975257:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975141:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b562c5000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975136:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975015:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55c13000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.975009:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974884:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b562d7000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974878:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974762:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55d03000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974756:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974642:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55df3000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974637:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974522:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b55fea000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974516:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974400:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b562ea000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974394:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974284:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b562fa000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974280:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974164:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b56301000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974159:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974038:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b56306000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.974033:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.973903:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b56356000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.973898:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.973783:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b56371000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.973778:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.973672:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b5637a000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.973668:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.973553:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b56415000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.973548:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.973429:ERROR:process_reader_linux.cc(540)] no module mappings 0x7f7b56420000
Sep 04 03:33:15 plasmashell[3765]: [0904/033315.973384:ERROR:process_memory.cc(41)] short read
Sep 04 03:33:15 systemd[1]: Stopped Power Profiles daemon.
Sep 04 03:33:15 mkinitcpio[41373]: -> Running build hook: [sd-shutdown]
Sep 04 03:33:15 mkinitcpio[41373]: ==> Starting build: 'none'
Sep 04 03:33:15 plasmashell[3745]: [3745:0904/033315.970195:ERROR:command_buffer_proxy_impl.cc(325)] GPU state invalid after WaitForGetOffsetInRange.
Sep 04 03:33:15 kernel: ---[ end trace 0000000000000000 ]---
Sep 04 03:33:15 kernel: </TASK>
Sep 04 03:33:15 kernel: R13: 00001f5000224180 R14: 00007f7b57f46880 R15: 0000000000001000
Sep 04 03:33:15 kernel: R10: 00007f7b57f46880 R11: 0000000000000293 R12: 00007fff6e775af0
Sep 04 03:33:15 kernel: RBP: 00007fff6e775970 R08: 0000000000000000 R09: 0000000000000002
Sep 04 03:33:15 kernel: RDX: 0000000000001000 RSI: 00007fff6e775af0 RDI: 0000000000000005
Sep 04 03:33:15 kernel: RAX: ffffffffffffffda RBX: 00007fff6e776c48 RCX: 00007f35da8e88c7
Sep 04 03:33:15 kernel: RSP: 002b:00007fff6e7757d0 EFLAGS: 00000293 ORIG_RAX: 0000000000000011
Sep 04 03:33:15 kernel: Code: 08 89 3c 24 48 89 4c 24 18 e8 c5 04 fa ff 4c 8b 54 24 18 48 8b 54 24 10 41 89 c0 48 8b 74 24 08 8b 3c 24 b8 11 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 31 44 89 c7 48 89 04 24 e8 15 05 fa ff 48 8b
Sep 04 03:33:15 kernel: RIP: 0033:0x7f35da8e88c7
Sep 04 03:33:15 kernel: entry_SYSCALL_64_after_hwframe+0x72/0xdc
Sep 04 03:33:15 kernel: ? do_syscall_64+0x6c/0x90
Sep 04 03:33:15 kernel: ? syscall_exit_to_user_mode+0x2b/0x40
Sep 04 03:33:15 kernel: do_syscall_64+0x5d/0x90
Sep 04 03:33:15 kernel: __x64_sys_pread64+0x98/0xd0
Sep 04 03:33:15 kernel: ? vfs_read+0xc6/0x360
Sep 04 03:33:15 kernel: vfs_read+0xc6/0x360
Sep 04 03:33:15 kernel: mem_read+0xe0/0x160
Sep 04 03:33:15 kernel: __access_remote_vm+0x1a5/0x520
Sep 04 03:33:15 kernel: get_user_pages_remote+0x14e/0x450
Sep 04 03:33:15 kernel: ? __get_user_pages+0xa2/0x8c0
Sep 04 03:33:15 kernel: ? __get_user_pages+0x763/0x8c0
Sep 04 03:33:15 kernel: ? asm_exc_invalid_op+0x1a/0x20
Sep 04 03:33:15 kernel: ? exc_invalid_op+0x19/0xc0
Sep 04 03:33:15 kernel: ? handle_bug+0x3c/0x80
Sep 04 03:33:15 kernel: ? report_bug+0x202/0x270
Sep 04 03:33:15 kernel: ? __warn+0x81/0x1b0
Sep 04 03:33:15 kernel: <TASK>
Sep 04 03:33:15 kernel: Call Trace:
Sep 04 03:33:15 kernel: DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Sep 04 03:33:15 kernel: DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
Sep 04 03:33:15 kernel: CR2: 00001f5000212010 CR3: 00000001b73c8005 CR4: 00000000003706e0
Sep 04 03:33:15 kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Sep 04 03:33:15 kernel: FS: 00007f35dac33580(0000) GS:ffff8a7616a40000(0000) knlGS:0000000000000000
Sep 04 03:33:15 kernel: R13: 0000000000100177 R14: 0000000000000000 R15: ffff8a6f470fca80
Sep 04 03:33:15 kernel: R10: ffff8a700c9d5a80 R11: ffff8a700c9d5a0c R12: ffff8a6ec69e9600
Sep 04 03:33:15 kernel: RBP: 00007f7b57f47000 R08: ffff8a700c9d5a08 R09: 0000000000000001
Sep 04 03:33:15 kernel: RDX: 0000000000000000 RSI: 00007f7b57f47000 RDI: ffff8a6fe668c200
Sep 04 03:33:15 kernel: RAX: ffff8a6f470fca80 RBX: 000000000005000a RCX: 00007ffc246a9fff
Sep 04 03:33:15 kernel: RSP: 0018:ffff9788c3eb3bb8 EFLAGS: 00010206
Sep 04 03:33:15 kernel: Code: e9 3c fb ff ff 48 8b 45 38 f0 48 83 28 01 0f 85 19 fc ff ff 48 8b 45 38 48 8d 7d 30 48 8b 40 08 ff d0 0f 1f 00 e9 03 fc ff ff <0f> 0b e9 5f f9 ff ff f6 c3 04 0f 85 05 ff ff ff 49 8b 7d 00 48 89
Sep 04 03:33:15 kernel: RIP: 0010:__get_user_pages+0x763/0x8c0
Sep 04 03:33:15 kernel: Hardware name: System manufacturer System Product Name/MAXIMUS IX HERO, BIOS 1301 03/14/2018
Sep 04 03:33:15 kernel: CPU: 1 PID: 3765 Comm: chrome_crashpad Tainted: P OE 6.4.12-zen1-1-zen #1 fc2b2f2a83cacde5b3df8283dae0f37b220a16d6
Sep 04 03:33:15 kernel: sha512_ssse3 snd_intel_sdw_acpi aesni_intel snd_hda_codec crypto_simd eeepc_wmi cryptd asus_wmi ee1004 snd_hda_core ledtrig_audio snd_hwdep iTCO_wdt sparse_keymap rapl intel_pmc_bxt snd_pcm platform_profile vfat i2c_dev iTCO_vendor_support rfkill mei_hdcp wmi_bmof intel_wmi_thunderbolt mxm_wmi mei_pxp snd_timer intel_cstate fat nvidia(POE) snd i2c_i801 intel_uncore video i2c_smbus e1000e pcspkr soundcore mei_me mei wmi acpi_pad mac_hid crypto_user fuse dm_mod loop bpf_preload ip_tables x_tables usbhid ext4 crc32c_generic crc16 mbcache jbd2 nvme nvme_core crc32c_intel nvme_common xhci_pci xhci_pci_renesas [last unloaded: hwmon_vid]
Sep 04 03:33:15 kernel: Modules linked in: snd_seq_dummy snd_hrtimer snd_seq xt_conntrack nft_chain_nat xt_MASQUERADE nf_nat nf_conntrack_netlink nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xt_addrtype nft_compat nf_tables libcrc32c nfnetlink br_netfilter bridge stp llc sr_mod cdrom btusb btrtl btbcm btintel btmtk usb_storage bluetooth joydev mousedev ecdh_generic uvcvideo videobuf2_vmalloc uvc videobuf2_memops videobuf2_v4l2 snd_usb_audio videodev snd_usbmidi_lib snd_rawmidi videobuf2_common snd_seq_device mc overlay nct6775_core vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) pkcs8_key_parser nvidia_drm(POE) nvidia_uvm(POE) nvidia_modeset(POE) intel_rapl_msr intel_rapl_common intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp snd_soc_avs kvm_intel snd_soc_hda_codec snd_hda_ext_core kvm snd_soc_core snd_hda_codec_realtek irqbypass crct10dif_pclmul snd_hda_codec_generic snd_compress crc32_pclmul ac97_bus snd_hda_codec_hdmi polyval_clmulni snd_pcm_dmaengine polyval_generic gf128mul snd_hda_intel ghash_clmulni_intel snd_intel_dspcfg
Sep 04 03:33:15 kernel: WARNING: CPU: 1 PID: 3765 at mm/gup.c:1101 __get_user_pages+0x763/0x8c0
Sep 04 03:33:15 kernel: ------------[ cut here ]------------
Sep 04 03:33:15 systemd[1]: power-profiles-daemon.service: Deactivated successfully.
Sep 04 03:33:15 systemd[1]: Stopped Authorization Manager.
Sep 04 03:33:15 plasmashell[3793]: [3793:0904/033315.957228:ERROR:gpu_service_impl.cc(988)] Exiting GPU process because some drivers can't recover from errors. GPU process will restart shortly.
Sep 04 03:33:15 udisksd[890]: udisks daemon version 2.9.4 exiting
Sep 04 03:33:15 systemd[1]: polkit.service: Deactivated successfully.
Sep 04 03:33:15 plasmashell[3793]: [3793:0904/033315.955884:ERROR:gles2_cmd_decoder_passthrough.cc(1586)] GLES2DecoderPassthroughImpl: Context lost during MakeCurrent.
Sep 04 03:33:15 plasmashell[3793]: [3793:0904/033315.955723:ERROR:gl_context_egl.cc(473)] eglMakeCurrent failed with error EGL_CONTEXT_LOST
Sep 04 03:33:15 plasmashell[3793]: [3793:0904/033315.955608:ERROR:gl_display.cc(508)] EGL Driver message (Critical) eglMakeCurrent: Failed to make the GLX context current
Sep 04 03:33:15 plasmashell[3858]: X connection to :0 broken (explicit kill or server shutdown).
Sep 04 03:33:15 systemd[1]: Stopping Daemon for power management...
Sep 04 03:33:15 systemd[1]: Stopping Disk Manager...
Sep 04 03:33:15 plasmashell[3793]: [3793:0904/033315.953632:ERROR:connection.cc(46)] X connection error received.
Sep 04 03:33:15 systemd[1]: Stopping Load/Save OS Random Seed...
Sep 04 03:33:15 plasmashell[3793]: [3793:0904/033315.953103:ERROR:connection.cc(46)] X connection error received.
Sep 04 03:33:15 sddm[530]: Display server stopping...
Sep 04 03:33:15 sddm[530]: Socket server stopped.
Sep 04 03:33:15 sddm[530]: Socket server stopping...
Sep 04 03:33:15 sddm[530]: Signal received: SIGTERM
Sep 04 03:33:15 systemd[1]: Stopping Simple Desktop Display Manager...
Sep 04 03:33:15 systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Sep 04 03:33:15 systemd[1]: Stopping Power Profiles daemon...
Sep 04 03:33:15 systemd[1]: Stopping Authorization Manager...
Sep 04 03:33:15 systemd[1]: Starting Generate shutdown-ramfs...
Sep 04 03:33:15 (modprobe)[41372]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
Sep 04 03:33:15 dockerd[922]: time="2023-09-04T03:33:15.950434605+03:00" level=info msg="Daemon shutdown complete"
Sep 04 03:33:15 systemd[1]: Stopping Initialize hardware monitoring sensors...
Sep 04 03:33:15 dockerd[922]: time="2023-09-04T03:33:15.950244333+03:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
Sep 04 03:33:15 dockerd[922]: time="2023-09-04T03:33:15.949531243+03:00" level=info msg="Processing signal 'terminated'"
Sep 04 03:33:15 systemd[1]: Stopping Docker Application Container Engine...
Sep 04 03:33:15 systemd[1]: Stopping CUPS Scheduler...
Sep 04 03:33:15 systemd[1]: Stopping Save/Restore Sound Card State...
Sep 04 03:33:15 systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Sep 04 03:33:15 systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Sep 04 03:33:15 systemd[1]: Closed LVM2 poll daemon socket.
Sep 04 03:33:15 systemd[1078]: plasma-kwin_x11.service: Consumed 6min 8.117s CPU time.
Sep 04 03:33:15 systemd[1078]: Stopped KDE Window Manager.
Sep 04 03:33:15 systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Sep 04 03:33:15 systemd[1]: Stopped Daily locate database update.
Sep 04 03:33:15 systemd[1]: updatedb.timer: Deactivated successfully.
Sep 04 03:33:15 systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Sep 04 03:33:15 systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Sep 04 03:33:15 systemd[1]: Stopped Daily verification of password and group files.
Sep 04 03:33:15 systemd[1]: shadow.timer: Deactivated successfully.
Sep 04 03:33:15 systemd[1]: Stopped Refresh Pacman mirrorlist weekly with Reflector..
Sep 04 03:33:15 systemd[1]: reflector.timer: Deactivated successfully.
Sep 04 03:33:15 systemd[1]: Stopped Discard unused packages weekly.
Sep 04 03:33:15 systemd[1]: paccache.timer: Deactivated successfully.
Sep 04 03:33:15 systemd[1]: Stopped Daily man-db regeneration.
Sep 04 03:33:15 systemd[1]: man-db.timer: Deactivated successfully.
Sep 04 03:33:15 systemd[1]: Stopped Daily rotation of log files.
Sep 04 03:33:15 systemd[1]: logrotate.timer: Deactivated successfully.
Sep 04 03:33:15 systemd[1]: Stopped Discard unused filesystem blocks once a week.
Sep 04 03:33:15 systemd[1]: fstrim.timer: Deactivated successfully.
Sep 04 03:33:15 systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
Sep 04 03:33:15 systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
Sep 04 03:33:15 systemd[1]: Stopped target Timer Units.
Sep 04 03:33:15 systemd[1]: Stopped target Sound Card.
Sep 04 03:33:15 systemd[1]: Stopped target Smart Card.
Sep 04 03:33:15 systemd[1]: Stopped target Host and Network Name Lookups.
Sep 04 03:33:15 systemd[1]: Stopped target Login Prompts.
Sep 04 03:33:15 systemd[1078]: plasma-kded.service: Consumed 6.267s CPU time.
Sep 04 03:33:15 systemd[1078]: Stopped KDE Daemon.
Sep 04 03:33:15 systemd[1]: Stopped target Multi-User System.
Sep 04 03:33:15 systemd[1]: Stopped target Graphical Interface.
Sep 04 03:33:15 systemd[1]: Stopped target Bluetooth Support.
Sep 04 03:33:15 systemd[1]: Removed slice Slice /system/modprobe.
Sep 04 03:33:15 kded5[1158]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Sep 04 03:33:15 systemd[1]: Removed slice Slice /system/getty.
Sep 04 03:33:15 systemd[1078]: plasma-kactivitymanagerd.service: Consumed 1.638s CPU time.
Sep 04 03:33:15 systemd[1078]: Stopped KActivityManager Activity manager Service.
Sep 04 03:33:15 sddm[530]: Auth: sddm-helper exited with 1
Sep 04 03:33:15 sddm[530]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Sep 04 03:33:15 sddm[530]: Auth: sddm-helper (--socket /tmp/sddm-auth-2db6456d-c3a0-4a34-9267-13bc749d93f0 --id 1 --start /usr/bin/startplasma-x11 --user delta) crashed (exit code 1)
Sep 04 03:33:15 systemd[1]: Stopping Session 2 of User delta...
Sep 04 03:33:15 sddm-helper[1075]: Signal received: SIGTERM
Sep 04 03:33:15 systemd[1078]: Stopped target Session services which should run early before the graphical session is brought up.
Sep 04 03:33:15 systemd[1078]: Stopping KDE Daemon...
Sep 04 03:33:15 systemd[1078]: Stopping KActivityManager Activity manager Service...
Sep 04 03:33:15 systemd[1078]: Stopped target KDE Plasma Workspace Core.
Sep 04 03:33:15 systemd[1078]: Stopped target Current graphical user session.
Sep 04 03:33:15 systemd[1078]: app-kaccess@autostart.service: Consumed 2.871s CPU time.
Sep 04 03:33:15 systemd[1078]: Stopped Accessibility.
Sep 04 03:33:15 systemd[1078]: plasma-xdg-desktop-portal-kde.service: Consumed 1.620s CPU time.
Sep 04 03:33:15 systemd[1078]: Stopped Xdg Desktop Portal For KDE.
Sep 04 03:33:15 systemd[1078]: plasma-plasmashell.service: Consumed 1min 41.773s CPU time.
Sep 04 03:33:15 systemd[1078]: Stopped KDE Plasma Workspace.
Sep 04 03:33:15 systemd[1078]: plasma-ksmserver.service: Consumed 1.801s CPU time.
Sep 04 03:33:15 systemd[1078]: Stopped KDE Session Management Server.
Sep 04 03:33:15 systemd-logind[470]: System is powering down.
Sep 04 03:33:15 systemd-logind[470]: The system will power off now!
Sep 04 03:33:15 systemd[1078]: kde-baloo.service: Consumed 3.573s CPU time.
Sep 04 03:33:15 systemd[1078]: Stopped Baloo File Indexer Daemon.
Sep 04 03:33:15 systemd[1078]: plasma-powerdevil.service: Consumed 2.723s CPU time.
Sep 04 03:33:15 systemd[1078]: Stopped Powerdevil.
Sep 04 03:33:15 systemd[1078]: Stopped flatpak document portal service.
Sep 04 03:33:15 systemd[1078]: Stopped Accessibility services bus.
Sep 04 03:33:15 systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
Sep 04 03:33:15 systemd[1078]: Stopped Geoclue Demo agent.
Sep 04 03:33:15 systemd[1078]: Stopped sandboxed app permission store.
Sep 04 03:33:15 systemd[1078]: Stopped Portal service.
Sep 04 03:33:15 systemd[1078]: plasma-kscreen.service: Consumed 1.601s CPU time.
Sep 04 03:33:15 systemd[1078]: Stopped KScreen.
Sep 04 03:33:15 systemd[1078]: plasma-kglobalaccel.service: Consumed 2.431s CPU time.
Sep 04 03:33:15 systemd[1078]: Stopped KDE Global Shortcuts Server.
Sep 04 03:33:15 systemd[1078]: Stopping Baloo File Indexer Daemon...
Sep 04 03:33:15 systemd[1078]: Stopping sandboxed app permission store...
Sep 04 03:33:15 systemd[1078]: Stopping flatpak document portal service...
Sep 04 03:33:15 systemd[1078]: Stopping Portal service...
Sep 04 03:33:15 systemd[1078]: Stopping Xdg Desktop Portal For KDE...
Sep 04 03:33:15 systemd[1078]: Stopping Powerdevil...
Sep 04 03:33:15 systemd[1078]: Stopping KDE Window Manager...
Sep 04 03:33:15 systemd[1078]: Stopping KScreen...
Sep 04 03:33:15 systemd[1078]: Stopping KDE Global Shortcuts Server...
Sep 04 03:33:15 systemd[1078]: Stopping Accessibility services bus...
Sep 04 03:33:15 systemd[1078]: Stopping Accessibility...
Sep 04 03:33:15 systemd[1078]: Stopping Geoclue Demo agent...
Sep 04 03:33:15 systemd[1078]: Stopped target Startup of XDG autostart applications.
Sep 04 03:33:15 systemd[1078]: Stopped target KDE Plasma Workspace.
Sep 04 03:33:15 systemd[1078]: Stopped target plasma-workspace-x11.target.
Sep 04 03:33:15 systemd[1078]: plasma-gmenudbusmenuproxy.service: Consumed 1.488s CPU time.
Sep 04 03:33:15 systemd[1078]: app-org.kde.kdeconnect.daemon@autostart.service: Consumed 3.075s CPU time.
Sep 04 03:33:15 systemd[1078]: plasma-xembedsniproxy.service: Consumed 1.555s CPU time.
Sep 04 03:33:15 systemd[1078]: plasma-polkit-agent.service: Consumed 1.679s CPU time.
Sep 04 03:33:15 polkitd[503]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.61, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
Sep 04 03:33:15 dbus-daemon[1101]: [session uid=1000 pid=1101] Successfully activated service 'org.kde.Shutdown'
Sep 04 03:33:15 dbus-daemon[1101]: [session uid=1000 pid=1101] Activating service name='org.kde.Shutdown' requested by ':1.319' (uid=1000 pid=41312 comm="/usr/lib/ksmserver-logout-greeter")
Sep 04 03:33:09 dbus-daemon[1101]: [session uid=1000 pid=1101] Successfully activated service 'org.kde.LogoutPrompt'
Sep 04 03:33:09 dbus-daemon[1101]: [session uid=1000 pid=1101] Activating service name='org.kde.LogoutPrompt' requested by ':1.17' (uid=1000 pid=1190 comm="/usr/bin/plasmashell --no-respawn")
clean
March 29, 2024, 11:53pm
13
Did you ever figure out what is causing this? I have the same motherboard and cpu with a 1660 Super and I’m experiencing the same on stock Archlinux. I’ve looked up the 5 error code, and the manual does contain 0x05 which means sleep state S5 (shutdown). I’m using the newest UEFI version using only the default options. Just like you, there is nothing in my logs that mention errors when shutting down and it only occurs sometimes.
I’ve tried the stock and zen kernels, and they both experience the same exact symptom you described. It sometimes hangs after reaching the final poweroff message with the keyboard and mouse off, and the hang is seemingly random.
Could it be possible there is a bug in the kernel regarding our cpu/motherboard?
