System hangs on resume
Hi,
I’m having an issue where my system fails to wake up correctly after suspending. I cannot open another terminal and I am forced to hard shutdown the system with the power button. This just started after an update, though my system was maybe a month out of date prior to this.
Upon resuming, the screen displays a log of the suspend process. I thought the displayed error messages were at fault at first, but I think they’re a normal part of the suspend process. What isn’t normal is that it looks like the kernel suspends before suspending user processes, and then continues the suspend process when it should be resuming. Here’s a relevant portion of the logs:
Aug 09 21:47:30 [] systemd[1]: Reached target Sleep.
Aug 09 21:47:30 [] systemd[1]: Starting System Suspend...
Aug 09 21:47:30 [] systemd-sleep[6940]: User sessions remain unfrozen on explicit request ($SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=0).
Aug 09 21:47:30 [] systemd-sleep[6940]: This is not recommended, and might result in unexpected behavior, particularly
Aug 09 21:47:30 [] systemd-sleep[6940]: in suspend-then-hibernate operations or setups with encrypted home directories.
Aug 09 21:47:30 [] systemd-sleep[6940]: Performing sleep operation 'suspend'...
Aug 09 21:47:30 [] kernel: PM: suspend entry (deep)
Aug 09 21:47:30 [] kernel: Filesystems sync: 0.001 seconds
Aug 10 16:49:14 [] kernel: Freezing user space processes
Aug 10 16:49:14 [] kernel: Freezing user space processes completed (elapsed 0.002 seconds)
Aug 10 16:49:14 [] kernel: OOM killer disabled.
Note the timestamps. The suspend process continues when I woke the machine the next day. Googling has shown me a few other instances of people encountering this, but it’s all from several years ago.(links below) I don’t know what would have changed in the past month or so that would have reintroduced this issue.
https://bugzilla.kernel.org/show_bug.cgi?id=203791
https://askubuntu.com/questions/828486/kernel-suspends-too-quickly-upon-resume-continues-suspend-tasks
Hardware?
Of course!
https://0x0.st/XW48.txt
Point 10:
https://wiki.archlinux.org/title/NVIDIA/Tips_and_tricks
That doesn’t seem particularly relevant to my case. Doesn’t disabling this just cause some programs to break on resume? This is stalling the whole system, and it only started recently. Regardless, I did try this and it did not alleviate the issue. The system still defers half of the suspend process until after I wake the machine.
I am having a similar issue when my pc suspends. It just crashes and I have to hard reboot.
@Mystagogue - How did you generate the hardware report please? I want to provide one to help with this issue as well.
See this article
This is still happening unfortunately, and I’m no closer to finding a solution. I haven’t been able to figure out how that part of the suspend process works.
I’ve found more recent threads about the issue, some are saying it could be a regression in the kernel.
https://bbs.archlinux.org/viewtopic.php?id=297517
https://bbs.archlinux.org/viewtopic.php?id=296954
Have you tested with the LTS kernel?
I’m aware of the comments in the 2nd thread you listed, where one user had the issue consistently with standard and LTS kernels, but I think it’s still worth trying on your hardware.
Suspend has randomly (probably an update), started working for me! Legion5/Ryzen/RTX3070.
I had a spare phone charging from the laptop, shut the lid, the phone buzzed. Opened lid, it had suspended and it resumed OK.
I had written a @suspend service that killed all my odd drive mounts (cifs & sshfs) a while ago and that runs OK.
