System froze during an update
My system froze during an update (I used eos-update in welcome app), and my Alt + SysRq REISUB didn’t work, so I held the power button to force shutdown.
I turned on my laptop to see if it would boot; I noticed that I only had LTS Kernel as an option in the menu.
Everything is green during the boot (with LTS Kernel); there’s also fsck (usually, I see this every time I force the shutdown of my laptop).
I landed on the login screen, but logging in to Wayland or X11 only shows a black screen.
I need help. What should I do next in this situation? :confused:
Logs (via chroot):
Hardware information: https://0x0.st/XoA0.txt
Partition and Format info: https://0x0.st/XoAk.txt
Boot logs: https://0x0.st/XoAn.txt
" (with timespan): https://0x0.st/XoA5.txt
Please post logs not pictures
nVidia? Same thing happened to me :frowning:
Reinstall each of those packages:
sudo pacman -S <package-name> --overwrite='*'
This should get you working :crossed_fingers:
Lucky you thought to get a picture!
along with what xircon suggests try the first solution in the linked reply
and in case pacman doesn’t work you’ll need to use a live iso to re-install packages
Hello, I already included the logs in my post; please let me know if you need more. Thank you. :slight_smile:
Yes. Unfortunately, I have an Nvidia on this laptop. I have a hybrid graphics laptop. I mainly use Intel for display and Nvidia for gaming. I’ll try your solution later. I’ll let you guys know; hopefully, it works. :smiley:
Hello, should I try your solution before reinstalling the packages, or is it okay to try it after reinstalling them? :smiley:
This one solved my problem. Thanks to everyone who gave me hints on how to solve this problem. As a newbie, I’m learning every time my system breaks. :smile:
These guides also helped me fix this problem:
https://discovery.endeavouros.com/system-rescue/arch-chroot/2022/12/
now that the packages are re-installed i would recommend creating the file before you update again.
