experiencing random hard freezing - doesn’t seem to matter what i’m doing
the fellas over at Manjaro are also aware of this as well - freezing/crashing issues over the last month or so - for me it started with the 2025-02-04 Manjaro update
tried…
- switching OS (Manjaro > EOS)
- switching kernels
- wayland/X11
- update firmware (UEFI)
- memory test [ok]
logs...
#################### inxi -Fxxc0z ########################
Kernel: 6.13.2-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.3.0 tk: Qt v: N/A wm: kwin_x11 dm: SDDM Distro: EndeavourOS
base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 3.K2 date: 08/30/2024
Info: quad core model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64 type: MT MCP
arch: Zen/Zen+ note: check rev: 1 cache: L1: 384 KiB L2: 2 MiB L3: 4 MiB
Speed (MHz): avg: 3700 min/max: 1400/3700 boost: enabled cores: 1: 3700 2: 3700 3: 3700 4: 3700
5: 3700 6: 3700 7: 3700 8: 3700 bogomips: 59198
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile
Series] driver: amdgpu v: kernel arch: GCN-5 pcie: speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DVI-D-1,HDMI-A-2,HDMI-A-3 bus-ID: 27:00.0 chip-ID: 1002:15d8
temp: 44.0 C
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: BenQ EX2510 res: N/A dpi: 90 diag: 623mm (24.5")
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon Vega 11 Graphics (radeonsi raven LLVM 19.1.7 DRM 3.59
6.13.2-arch1-1) device-ID: 1002:15d8
Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,kscreen-doctor
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 27:00.1 chip-ID: 1002:15de
Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 27:00.6 chip-ID: 1022:15e3
Device-3: Mark of the Unicorn M Series driver: cdc_acm,snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 1-1:2 chip-ID: 07fd:000b
API: ALSA v: k6.13.2-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 22:00.0
chip-ID: 10ec:8168
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 9.1 TiB used: 2.89 TiB (31.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS100T3XHC-00SJG0 size: 931.51 GiB
speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 43.9 C
ID-2: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB speed: 6.0 Gb/s
serial: <filter>
ID-3: /dev/sdb vendor: Crucial model: CT2000MX500SSD1 size: 1.82 TiB speed: 6.0 Gb/s
serial: <filter>
ID-4: /dev/sdc vendor: Samsung model: SSD 870 EVO 4TB size: 3.64 TiB speed: 6.0 Gb/s
serial: <filter>
ID-5: /dev/sdd vendor: SanDisk model: SDSSDH32000G size: 1.82 TiB speed: 6.0 Gb/s
serial: <filter>
ID-1: / size: 889.14 GiB used: 9.12 GiB (1.0%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /home size: 915.33 GiB used: 99.84 GiB (10.9%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 26 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p2
System Temperatures: cpu: 43.4 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 13.57 GiB used: 3.24 GiB (23.9%)
Processes: 282 Power: uptime: 1h 0m wakeups: 0 Init: systemd v: 257 default: graphical
Packages: pm: pacman pkgs: 1107 Compilers: gcc: 14.2.1 Client: shell wrapper v: 5.2.37-release
inxi: 3.3.37
#################### cat ~/.xsession-errors ########################
#################### cat /etc/pacman.conf ########################
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
#CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
#HookDir = /etc/pacman.d/hooks/
HoldPkg = pacman glibc dracut kernel-install-for-dracut eos-dracut
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
Color
ILoveCandy
#NoProgressBar
#CheckSpace
VerbosePkgLists
ParallelDownloads = 5
DownloadUser = alpm
#DisableSandbox
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Arch Linux
# packagers with `pacman-key --populate archlinux`.
# REPOSITORIES
# - can be defined here or included from another file
# - pacman will search repositories in the order defined here
# - local/custom mirrors can be added here or in separate files
# - repositories listed first will take precedence when packages
# have identical names, regardless of version number
# - URLs will have $repo replaced by the name of the current repo
# - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
# [repo-name]
# Server = ServerName
# Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[endeavouros]
SigLevel = PackageRequired
Include = /etc/pacman.d/endeavouros-mirrorlist
#[core-testing]
#Include = /etc/pacman.d/mirrorlist
[core]
#[extra-testing]
[extra]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
#[multilib-testing]
[multilib]
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
#################### ForeignPkgInfo ########################
