Tealk
May 7, 2023, 1:28pm
1
Hello,
I have the problem that from time to time the system freezes, so mainly the operation and the display, audio continues to run.
When it hangs then also the display goes black again and again and then shows the last displayed image again.
15:08:39 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process firefox pid 11426 thread firefox:cs0 pid 11478
15:08:39 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx_low timeout, signaled seq=2041649, emitted seq=2041652
14:18:39 systemd-coredum: Process 12346 (QtWebEngineProc) of user 1000 dumped core.
Stack trace of thread 1:
#0 0x00007f4c42320e2d n/a (libc.so.6 + 0x10ae2d)
ELF object binary architecture: AMD x86-64
13:49:41 systemd: Failed to start Application launched by gnome-session-binary.
13:49:37 gdm-session-wor: gkr-pam: unable to locate daemon control file
13:49:28 kernel: amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
13:49:28 bluetoothd: src/device.c:set_wake_allowed_complete() Set device flags return status: Invalid Parameters
Tealk
May 7, 2023, 4:06pm
3
sure
Kernel: 6.3.1-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: initrd=\1f55c54a217744e497b075e2472d8670\6.3.1-arch1-1\initrd
nvme_load=YES nowatchdog rw rootflags=subvol=/@
rd.luks.uuid=c25f3862-54cc-4289-af20-d4e72ec2d53f
root=/dev/mapper/luks-c25f3862-54cc-4289-af20-d4e72ec2d53f
rd.luks.uuid=cb415483-2790-4fba-839b-41768cd78e0c
resume=/dev/mapper/luks-cb415483-2790-4fba-839b-41768cd78e0c
systemd.machine_id=1f55c54a217744e497b075e2472d8670
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: TUXEDO product: TUXEDO Aura 15 Gen1 v: N/A
Mobo: NB01 model: NL5xRU serial: <superuser required> UEFI: INSYDE
v: 1.07.08TTR3 date: 03/18/2021
Battery:
ID-1: BAT0 charge: 22.9 Wh (53.9%) condition: 42.5/48.3 Wh (88.2%)
volts: 15.4 min: 15.2 model: Notebook BAT type: Li-ion serial: <filter>
status: not charging
Device-1: hid-18:7e:b9:67:f4:86-battery model: Tealk-Magic Trackpad 2
serial: N/A charge: N/A status: charging
Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1397 high: 1400 min/max: 1400/2000 boost: disabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 1400 2: 1397
3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 bogomips: 31959
Vulnerabilities:
Type: retbleed mitigation: untrained return thunk; SMT disabled
prctl
sanitization
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir vendor: CLEVO/KAPOK driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-2,eDP-1 empty: DP-1
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 58.0 C
Device-2: Bison BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 3-4:6
chip-ID: 5986:9102 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: LG (GoldStar) HDR WQHD serial: <filter> built: 2021
res: 3440x1440 dpi: 107 gamma: 1.2 size: 820x346mm (32.28x13.62")
diag: 888mm (34.9") modes: max: 3440x1440 min: 640x480
Monitor-2: eDP-1 model: ChiMei InnoLux 0x15e8 built: 2016 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.1-arch1-1) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel bus-ID: 3-1.1.4.2:11 chip-ID: 2e50:000e
pcie: class-ID: 0300 gen: 4 serial: <filter> speed: 16 GT/s lanes: 16
bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: CLEVO/KAPOK
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Beyerdynamic FOX type: USB
driver: hid-generic,snd-usb-audio,usbhid
API: ALSA v: k6.3.1-arch1-1 status: kernel-api tools: alsamixer,amixer
Server-1: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: wwp4s0f4u2c2 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:5
chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Local Storage: total: 1.82 TiB used: 417.77 GiB (22.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO M.2 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate
model: UltraTouch SSD size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 896.73 GiB size: 896.73 GiB (100.00%)
used: 194.01 GiB (21.6%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-c25f3862-54cc-4289-af20-d4e72ec2d53f
ID-2: /home raw-size: 896.73 GiB size: 896.73 GiB (100.00%)
ID-3: /var/log raw-size: 896.73 GiB size: 896.73 GiB (100.00%)
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 33.8 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-cb415483-2790-4fba-839b-41768cd78e0c
System Temperatures: cpu: 59.6 C mobo: N/A gpu: amdgpu temp: 57.0 C
Fan Speeds (RPM): N/A
Processes: 364 Uptime: 2h 55m wakeups: 70 Memory: 30.73 GiB
used: 8.48 GiB (27.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: 1202 pm: pacman pkgs: 1174
libs: 295 tools: yay pm: flatpak pkgs: 28 Shell: Bash v: 5.1.16
running-in: kgx inxi: 3.3.26
have you try theses parameters on boot kernel :
“iommu=pt amd_pstate=passive”
see this topic
Linux 5.17 is here and just around the corner for Arch users who dont build their own Kernels and have it already. Even if you do here is the short and easy of using the new P-State Driver for AMD CPUs. Ondemand seems to deliver the best performance/power savings over schedutil with p-state at the moment.
It should be noted this is only for Zen2 and newer
First check if support is already enabled with
lscpu | grep cppc
if you get no output then to 2
Make sure CPPC is enabled in you…
Tealk
May 7, 2023, 4:17pm
5
I get an output with the following command, do I have to change anything?
lscpu | grep cppc
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba ibrs ibpb stibp vmmcall fsgsbase bmi1 avx2 smep bmi2 cqm rdt_a rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local clzero irperf xsaveerptr rdpru wbnoinvd cppc arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif v_spec_ctrl umip rdpid overflow_recov succor smca
cppc is on UEFI motherboard
any update for your UEFI motherboard ?
Tealk
May 7, 2023, 4:32pm
7
I just asked Tuxedo because I can’t find any downloads for my device at the moment.
Tealk
May 12, 2023, 11:49am
8
Now its up to date:
UEFI: INSYDE
v: 1.07.11RTR2 date: 01/30/2023
Tealk
May 16, 2023, 7:09pm
9
Today I had it again, I think it occurs when I change the desktop.
21:00:34 systemd: Failed to start Application launched by gnome-session-binary.
21:00:31 gdm-session-wor: gkr-pam: unable to locate daemon control file
20:59:59 kernel: amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
20:59:59 kernel: amdgpu 0000:04:00.0: amdgpu: Secure display: Generic Failure.
20:59:58 bluetoothd: src/device.c:set_wake_allowed_complete() Set device flags return status: Invalid Parameters
20:59:58 bluetoothd: src/plugin.c:plugin_init() Failed to init bap plugin
20:59:58 bluetoothd: src/plugin.c:plugin_init() Failed to init mcp plugin
20:59:58 bluetoothd: src/plugin.c:plugin_init() Failed to init vcp plugin
20:59:58 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
If I understand this correctly:
What other desktop-environments besides Gnome are you using?
Tealk
May 16, 2023, 8:16pm
11
sorry i misspoke, i mean the workspaces, those virtual desktops that you can switch.
Tealk
September 12, 2023, 7:08pm
12
I had this again and I still don’t know where exactly it comes from.
Here the log of the last crash:
http://ix.io/4Gbt
I can reproduce this relatively reliably when I open FoundryVTT in any browser.
this time i didn’t even change the workspace and last week the problem with foundryvtt was not yet. I still used it for a few hours at a time.
It shows a trace about appindicator extension
Tealk
September 26, 2023, 8:01pm
14
but can this cause the problem? I will deactivate the extension in any case to see if it occurs without it.
So currently it is so that it just occurs in the middle of working and only if i have FoundryVTT open in Browser, then the screen falckert and on my ultra-wide screen is only flashing the image of my laptop monitor displayed.
No interaction is accepted by the device and only the shutdown works.
