Hello,
sometimes my system randomly freezes. The times it froze was while using zoom from aur and vlc from community repo.
I can’t even use the emergency Terminal trick (CTRL+ALT+F*).
I looked into my Xorg.log.old and the last entry is the Cuplrit it think.
The device HID 046a:0023 is my keyboard, I can change the keyboard, but I think this wont fix anything
. I think this is me hammering on the keyboard …
I use the i3 edition with calamaris installer.
here is A link to the pastebin logs:
https://clbin.com/yRrMd
cat /var/log/Xorg.0.log.old
[man@man-allseries ~]$ cat /var/log/Xorg.0.log.old
[ 2904.827]
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
[ 2904.827]
X.Org X Server 1.21.1.1
X Protocol Version 11, Revision 0
[ 2904.827] Current Operating System: Linux man-allseries 5.10.80-1-lts #1 SMP Thu, 18 Nov 2021 13:34:49 +0000 x86_64
[ 2904.827] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=a2f86ffc-ffae-4ea7-828b-db0a708b6d35 rw rootflags=subvol=@ quiet loglevel=3 nowatchdog
[ 2904.827]
[ 2904.827] Current version of pixman: 0.40.0
[ 2904.828] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 2904.828] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 2904.828] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Nov 23 09:14:00 2021
[ 2904.828] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 2904.828] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 2904.828] (==) No Layout section. Using the first Screen section.
[ 2904.828] (==) No screen section available. Using defaults.
[ 2904.828] (**) |-->Screen "Default Screen Section" (0)
[ 2904.828] (**) | |-->Monitor "<default monitor>"
[ 2904.828] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 2904.828] (==) Automatically adding devices
[ 2904.828] (==) Automatically enabling devices
[ 2904.828] (==) Automatically adding GPU devices
[ 2904.828] (==) Automatically binding GPU devices
[ 2904.828] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 2904.828] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 2904.828] Entry deleted from font path.
[ 2904.828] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 2904.828] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 2904.828] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 2904.828] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 2904.828] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 2904.828] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 2904.828] (==) FontPath set to:
[ 2904.828] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 2904.828] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 2904.828] (II) Module ABI versions:
[ 2904.828] X.Org ANSI C Emulation: 0.4
[ 2904.828] X.Org Video Driver: 25.2
[ 2904.828] X.Org XInput driver : 24.4
[ 2904.828] X.Org Server Extension : 10.0
[ 2904.829] (++) using VT number 7
[ 2904.829] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 2904.829] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 2904.829] (II) Platform probe for /sys/devices/pci0000:00/0000:00:1c.4/0000:05:00.0/drm/card0
[ 2904.831] (--) PCI:*(5@0:0:0) 10de:1380:1043:84bb rev 162, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 2904.831] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 2904.831] (II) LoadModule: "glx"
[ 2904.831] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 2904.832] (II) Module glx: vendor="X.Org Foundation"
[ 2904.832] compiled for 1.21.1.1, module version = 1.0.0
[ 2904.832] ABI class: X.Org Server Extension, version 10.0
[ 2904.832] (==) Matched nouveau as autoconfigured driver 0
[ 2904.832] (==) Matched nv as autoconfigured driver 1
[ 2904.832] (==) Matched modesetting as autoconfigured driver 2
[ 2904.832] (==) Matched fbdev as autoconfigured driver 3
[ 2904.832] (==) Matched vesa as autoconfigured driver 4
[ 2904.832] (==) Assigned the driver to the xf86ConfigLayout
[ 2904.832] (II) LoadModule: "nouveau"
[ 2904.832] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 2904.832] (II) Module nouveau: vendor="X.Org Foundation"
[ 2904.832] compiled for 1.21.1.1, module version = 1.0.17
[ 2904.832] Module class: X.Org Video Driver
[ 2904.832] ABI class: X.Org Video Driver, version 25.2
[ 2904.832] (II) LoadModule: "nv"
[ 2904.832] (WW) Warning, couldn't open module nv
[ 2904.832] (EE) Failed to load module "nv" (module does not exist, 0)
[ 2904.832] (II) LoadModule: "modesetting"
[ 2904.832] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 2904.833] (II) Module modesetting: vendor="X.Org Foundation"
[ 2904.833] compiled for 1.21.1.1, module version = 1.21.1
[ 2904.833] Module class: X.Org Video Driver
[ 2904.833] ABI class: X.Org Video Driver, version 25.2
[ 2904.833] (II) LoadModule: "fbdev"
[ 2904.833] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 2904.833] (II) Module fbdev: vendor="X.Org Foundation"
[ 2904.833] compiled for 1.21.1.1, module version = 0.5.0
[ 2904.833] (II) LoadModule: "vesa"
[ 2904.833] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 2904.833] (II) Module vesa: vendor="X.Org Foundation"
[ 2904.833] compiled for 1.21.1.1, module version = 2.5.0
[ 2904.833] (II) NOUVEAU driver
[ 2904.833] (II) NOUVEAU driver for NVIDIA chipset families :
[ 2904.833] RIVA TNT (NV04)
[ 2904.833] RIVA TNT2 (NV05)
[ 2904.833] GeForce 256 (NV10)
[ 2904.833] GeForce 2 (NV11, NV15)
[ 2904.833] GeForce 4MX (NV17, NV18)
[ 2904.833] GeForce 3 (NV20)
[ 2904.833] GeForce 4Ti (NV25, NV28)
[ 2904.833] GeForce FX (NV3x)
[ 2904.833] GeForce 6 (NV4x)
[ 2904.833] GeForce 7 (G7x)
[ 2904.833] GeForce 8 (G8x)
[ 2904.833] GeForce 9 (G9x)
[ 2904.833] GeForce GTX 2xx/3xx (GT2xx)
[ 2904.833] GeForce GTX 4xx/5xx (GFxxx)
[ 2904.833] GeForce GTX 6xx/7xx (GKxxx)
[ 2904.833] GeForce GTX 9xx (GMxxx)
[ 2904.833] GeForce GTX 10xx (GPxxx)
[ 2904.833] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 2904.833] (II) FBDEV: driver for framebuffer: fbdev
[ 2904.833] (II) VESA: driver for VESA chipsets: vesa
[ 2904.834] (II) [drm] nouveau interface version: 1.3.1
[ 2904.834] (WW) Falling back to old probe method for modesetting
[ 2904.834] (WW) Falling back to old probe method for fbdev
[ 2904.834] (II) Loading sub module "fbdevhw"
[ 2904.834] (II) LoadModule: "fbdevhw"
[ 2904.834] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 2904.834] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 2904.834] compiled for 1.21.1.1, module version = 0.0.2
[ 2904.834] ABI class: X.Org Video Driver, version 25.2
[ 2904.834] (II) Loading sub module "dri2"
[ 2904.834] (II) LoadModule: "dri2"
[ 2904.834] (II) Module "dri2" already built-in
[ 2904.835] (--) NOUVEAU(0): Chipset: "NVIDIA NV117"
[ 2904.835] (II) NOUVEAU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 2904.835] (==) NOUVEAU(0): Depth 24, (--) framebuffer bpp 32
[ 2904.835] (==) NOUVEAU(0): RGB weight 888
[ 2904.835] (==) NOUVEAU(0): Default visual is TrueColor
[ 2904.835] (==) NOUVEAU(0): Using HW cursor
[ 2904.835] (==) NOUVEAU(0): Allowed maximum DRI level 2.
[ 2904.835] (==) NOUVEAU(0): GLX sync to VBlank enabled.
[ 2904.835] (==) NOUVEAU(0): Page flipping enabled
[ 2904.835] (==) NOUVEAU(0): Swap limit set to 1 [Max allowed 2]
[ 2904.835] (==) NOUVEAU(0): Page flipping synced to vblank by kernel.
[ 2904.835] (II) NOUVEAU(0): Initializing outputs ...
[ 2904.871] (II) NOUVEAU(0): Output VGA-1 has no monitor section
[ 2904.873] (II) NOUVEAU(0): Output DVI-D-1 has no monitor section
[ 2904.874] (II) NOUVEAU(0): Output DVI-D-2 has no monitor section
[ 2904.946] (II) NOUVEAU(0): Output HDMI-1 has no monitor section
[ 2904.946] (II) NOUVEAU(0): 4 crtcs needed for screen.
[ 2904.947] (II) NOUVEAU(0): Allocated crtc nr. 0 to this screen.
[ 2904.947] (II) NOUVEAU(0): Allocated crtc nr. 1 to this screen.
[ 2904.947] (II) NOUVEAU(0): Allocated crtc nr. 2 to this screen.
[ 2904.947] (II) NOUVEAU(0): Allocated crtc nr. 3 to this screen.
[ 2904.984] (II) NOUVEAU(0): EDID for output VGA-1
[ 2904.984] (II) NOUVEAU(0): Manufacturer: ACR Model: 1a9 Serial#: 342916771
[ 2904.984] (II) NOUVEAU(0): Year: 2011 Week: 47
[ 2904.984] (II) NOUVEAU(0): EDID Version: 1.3
[ 2904.984] (II) NOUVEAU(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 2904.984] (II) NOUVEAU(0): Sync: Separate
[ 2904.984] (II) NOUVEAU(0): Max Image Size [cm]: horiz.: 48 vert.: 27
[ 2904.984] (II) NOUVEAU(0): Gamma: 2.20
[ 2904.984] (II) NOUVEAU(0): DPMS capabilities: StandBy Suspend; RGB/Color Display
[ 2904.984] (II) NOUVEAU(0): First detailed timing is preferred mode
[ 2904.984] (II) NOUVEAU(0): redX: 0.648 redY: 0.339 greenX: 0.282 greenY: 0.603
[ 2904.984] (II) NOUVEAU(0): blueX: 0.143 blueY: 0.070 whiteX: 0.313 whiteY: 0.329
[ 2904.984] (II) NOUVEAU(0): Supported established timings:
[ 2904.984] (II) NOUVEAU(0): 720x400@70Hz
[ 2904.984] (II) NOUVEAU(0): 640x480@60Hz
[ 2904.984] (II) NOUVEAU(0): 640x480@67Hz
[ 2904.984] (II) NOUVEAU(0): 800x600@56Hz
[ 2904.984] (II) NOUVEAU(0): 800x600@60Hz
[ 2904.984] (II) NOUVEAU(0): 1024x768@60Hz
[ 2904.984] (II) NOUVEAU(0): 1024x768@70Hz
[ 2904.984] (II) NOUVEAU(0): 1280x1024@75Hz
[ 2904.984] (II) NOUVEAU(0): Manufacturer's mask: 0
[ 2904.984] (II) NOUVEAU(0): Supported standard timings:
[ 2904.984] (II) NOUVEAU(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 2904.984] (II) NOUVEAU(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 2904.984] (II) NOUVEAU(0): #2: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 2904.984] (II) NOUVEAU(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 2904.984] (II) NOUVEAU(0): #4: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 2904.984] (II) NOUVEAU(0): Supported detailed timing:
[ 2904.984] (II) NOUVEAU(0): clock: 148.5 MHz Image Size: 477 x 268 mm
[ 2904.984] (II) NOUVEAU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 2904.984] (II) NOUVEAU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 2904.984] (II) NOUVEAU(0): Ranges: V min: 56 V max: 76 Hz, H min: 31 H max: 83 kHz, PixClock max 175 MHz
[ 2904.984] (II) NOUVEAU(0): Monitor name: S221HQL
[ 2904.984] (II) NOUVEAU(0): Serial No: LP20D0348533
[ 2904.984] (II) NOUVEAU(0): EDID (in hex):
[ 2904.984] (II) NOUVEAU(0): 00ffffffffffff000472a901a37e7014
[ 2904.984] (II) NOUVEAU(0): 2f15010368301b78ca3585a656489a24
[ 2904.984] (II) NOUVEAU(0): 125054b30d00714f818081009500d1c0
[ 2904.984] (II) NOUVEAU(0): 010101010101023a801871382d40582c
[ 2904.984] (II) NOUVEAU(0): 4500dd0c1100001e000000fd00384c1f
[ 2904.984] (II) NOUVEAU(0): 5311000a202020202020000000fc0053
[ 2904.984] (II) NOUVEAU(0): 32323148514c0a2020202020000000ff
[ 2904.984] (II) NOUVEAU(0): 004c50323044303334383533330a00a3
[ 2904.984] (II) NOUVEAU(0): Printing probed modes for output VGA-1
[ 2904.984] (II) NOUVEAU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 2904.984] (II) NOUVEAU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 2904.984] (II) NOUVEAU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 2904.984] (II) NOUVEAU(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 2904.984] (II) NOUVEAU(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 2904.984] (II) NOUVEAU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 2904.984] (II) NOUVEAU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 2904.984] (II) NOUVEAU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 2904.984] (II) NOUVEAU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 2904.984] (II) NOUVEAU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 2904.984] (II) NOUVEAU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 2904.984] (II) NOUVEAU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 2904.984] (II) NOUVEAU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 2904.985] (II) NOUVEAU(0): EDID for output DVI-D-1
[ 2904.987] (II) NOUVEAU(0): EDID for output DVI-D-2
[ 2905.058] (II) NOUVEAU(0): EDID for output HDMI-1
[ 2905.059] (II) NOUVEAU(0): Manufacturer: VSC Model: e635 Serial#: 16843009
[ 2905.059] (II) NOUVEAU(0): Year: 2019 Week: 34
[ 2905.059] (II) NOUVEAU(0): EDID Version: 1.3
[ 2905.059] (II) NOUVEAU(0): Digital Display Input
[ 2905.059] (II) NOUVEAU(0): Max Image Size [cm]: horiz.: 70 vert.: 39
[ 2905.059] (II) NOUVEAU(0): Gamma: 2.20
[ 2905.059] (II) NOUVEAU(0): DPMS capabilities: Off
[ 2905.059] (II) NOUVEAU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 2905.059] (II) NOUVEAU(0): Default color space is primary color space
[ 2905.059] (II) NOUVEAU(0): First detailed timing is preferred mode
[ 2905.059] (II) NOUVEAU(0): redX: 0.648 redY: 0.329 greenX: 0.290 greenY: 0.614
[ 2905.059] (II) NOUVEAU(0): blueX: 0.138 blueY: 0.055 whiteX: 0.313 whiteY: 0.329
[ 2905.059] (II) NOUVEAU(0): Supported established timings:
[ 2905.059] (II) NOUVEAU(0): 720x400@70Hz
[ 2905.059] (II) NOUVEAU(0): 640x480@60Hz
[ 2905.059] (II) NOUVEAU(0): 640x480@67Hz
[ 2905.059] (II) NOUVEAU(0): 640x480@72Hz
[ 2905.059] (II) NOUVEAU(0): 640x480@75Hz
[ 2905.059] (II) NOUVEAU(0): 800x600@56Hz
[ 2905.059] (II) NOUVEAU(0): 800x600@60Hz
[ 2905.059] (II) NOUVEAU(0): 800x600@72Hz
[ 2905.059] (II) NOUVEAU(0): 800x600@75Hz
[ 2905.059] (II) NOUVEAU(0): 832x624@75Hz
[ 2905.059] (II) NOUVEAU(0): 1024x768@60Hz
[ 2905.059] (II) NOUVEAU(0): 1024x768@70Hz
[ 2905.059] (II) NOUVEAU(0): 1024x768@75Hz
[ 2905.059] (II) NOUVEAU(0): 1280x1024@75Hz
[ 2905.059] (II) NOUVEAU(0): 1152x864@75Hz
[ 2905.059] (II) NOUVEAU(0): Manufacturer's mask: 0
[ 2905.059] (II) NOUVEAU(0): Supported standard timings:
[ 2905.059] (II) NOUVEAU(0): #0: hsize: 2048 vsize 1152 refresh: 60 vid: 49377
[ 2905.059] (II) NOUVEAU(0): #1: hsize: 1920 vsize 1440 refresh: 60 vid: 16593
[ 2905.059] (II) NOUVEAU(0): #2: hsize: 1920 vsize 1200 refresh: 60 vid: 209
[ 2905.059] (II) NOUVEAU(0): #3: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 2905.059] (II) NOUVEAU(0): #4: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 2905.059] (II) NOUVEAU(0): #5: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 2905.059] (II) NOUVEAU(0): #6: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 2905.059] (II) NOUVEAU(0): #7: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 2905.059] (II) NOUVEAU(0): Supported detailed timing:
[ 2905.059] (II) NOUVEAU(0): clock: 241.5 MHz Image Size: 698 x 393 mm
[ 2905.059] (II) NOUVEAU(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 2905.059] (II) NOUVEAU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0
[ 2905.059] (II) NOUVEAU(0): Serial No: V9W193400366
[ 2905.059] (II) NOUVEAU(0): Ranges: V min: 24 V max: 75 Hz, H min: 15 H max: 113 kHz, PixClock max 305 MHz
[ 2905.059] (II) NOUVEAU(0): Monitor name: VX3276-QHD
[ 2905.059] (II) NOUVEAU(0): clock: 148.5 MHz Image Size: 698 x 393 mm
[ 2905.059] (II) NOUVEAU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 2905.059] (II) NOUVEAU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 2905.059] (II) NOUVEAU(0): clock: 74.2 MHz Image Size: 698 x 393 mm
[ 2905.059] (II) NOUVEAU(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[ 2905.059] (II) NOUVEAU(0): h_active: 1920 h_sync: 2448 h_sync_end 2492 h_blank_end 2640 h_border: 0
[ 2905.059] (II) NOUVEAU(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 2905.059] (II) NOUVEAU(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 2905.059] (II) NOUVEAU(0): Number of EDID sections to follow: 1
[ 2905.059] (II) NOUVEAU(0): EDID (in hex):
[ 2905.059] (II) NOUVEAU(0): 00ffffffffffff005a6335e601010101
[ 2905.059] (II) NOUVEAU(0): 221d0103804627782e1545a6544a9d23
[ 2905.059] (II) NOUVEAU(0): 0e5054bfef80e1c0d140d100d1c0b300
[ 2905.059] (II) NOUVEAU(0): 9500818081c0565e00a0a0a029503020
[ 2905.059] (II) NOUVEAU(0): 3500ba892100001a000000ff00563957
[ 2905.059] (II) NOUVEAU(0): 3139333430303336360a000000fd0018
[ 2905.059] (II) NOUVEAU(0): 4b0f711e000a202020202020000000fc
[ 2905.059] (II) NOUVEAU(0): 005658333237362d5148440a20200110
[ 2905.059] (II) NOUVEAU(0): 020333f15b010203040506070e0f9011
[ 2905.059] (II) NOUVEAU(0): 12131415161d1e1f222120565758595a
[ 2905.059] (II) NOUVEAU(0): 23097f07830100006a030c002000303c
[ 2905.059] (II) NOUVEAU(0): 200000023a801871382d40582c4500ba
[ 2905.059] (II) NOUVEAU(0): 892100001e011d8018711c1620582c25
[ 2905.059] (II) NOUVEAU(0): 00ba892100009e023a80d072382d4010
[ 2905.059] (II) NOUVEAU(0): 2c4580ba892100001e011d007251d01e
[ 2905.059] (II) NOUVEAU(0): 206e285500ba892100001e0000000093
[ 2905.059] (--) NOUVEAU(0): HDMI max TMDS frequency 300000KHz
[ 2905.059] (II) NOUVEAU(0): Printing probed modes for output HDMI-1
[ 2905.059] (II) NOUVEAU(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 2905.059] (II) NOUVEAU(0): Modeline "1920x1440"x60.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "2560x1080"x60.0 198.00 2560 2808 2852 3000 1080 1084 1089 1100 +hsync +vsync (66.0 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "2560x1080"x59.9 197.80 2560 2808 2852 3000 1080 1084 1089 1100 +hsync +vsync (65.9 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "2560x1080"x50.0 185.62 2560 3108 3152 3300 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "2560x1080"x30.0 118.80 2560 3328 3372 3520 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "2560x1080"x30.0 118.68 2560 3328 3372 3520 1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "2560x1080"x24.0 99.00 2560 3558 3602 3750 1080 1084 1089 1100 +hsync +vsync (26.4 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "2560x1080"x24.0 98.90 2560 3558 3602 3750 1080 1084 1089 1100 +hsync +vsync (26.4 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "2560x1080"x25.0 90.00 2560 3008 3052 3200 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "2048x1152"x60.0 162.00 2048 2074 2154 2250 1152 1153 1156 1200 +hsync +vsync (72.0 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1920x1080"x30.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1920x1080"x25.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1920x1080"x24.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1920x1080"x30.0 74.18 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1920x1080"x24.0 74.18 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1440x576"x50.0 54.00 1440 1464 1592 1728 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1440x480"x60.0 54.05 1440 1472 1596 1716 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "1440x480"x59.9 54.00 1440 1472 1596 1716 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 2905.059] (II) NOUVEAU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 2905.059] (II) NOUVEAU(0): Output VGA-1 connected
[ 2905.059] (II) NOUVEAU(0): Output DVI-D-1 disconnected
[ 2905.060] (II) NOUVEAU(0): Output DVI-D-2 disconnected
[ 2905.060] (II) NOUVEAU(0): Output HDMI-1 connected
[ 2905.060] (II) NOUVEAU(0): Using spanning desktop for initial modes
[ 2905.060] (II) NOUVEAU(0): Output VGA-1 using initial mode 1920x1080 +0+0
[ 2905.060] (II) NOUVEAU(0): Output HDMI-1 using initial mode 2560x1440 +1920+0
[ 2905.060] (==) NOUVEAU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 2905.060] (II) NOUVEAU(0): Virtual size is 4480x1440 (pitch 0)
[ 2905.060] (**) NOUVEAU(0): Driver mode "1920x1080": 148.5 MHz (scaled from 0.0 MHz), 67.5 kHz, 60.0 Hz
[ 2905.060] (II) NOUVEAU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 2905.060] (**) NOUVEAU(0): Driver mode "1280x1024": 135.0 MHz (scaled from 0.0 MHz), 80.0 kHz, 75.0 Hz
[ 2905.060] (II) NOUVEAU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 2905.060] (**) NOUVEAU(0): Driver mode "1280x1024": 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
[ 2905.060] (II) NOUVEAU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 2905.060] (**) NOUVEAU(0): Driver mode "1440x900": 106.5 MHz (scaled from 0.0 MHz), 55.9 kHz, 59.9 Hz
[ 2905.060] (II) NOUVEAU(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 2905.060] (**) NOUVEAU(0): Driver mode "1280x800": 83.5 MHz (scaled from 0.0 MHz), 49.7 kHz, 59.8 Hz
[ 2905.060] (II) NOUVEAU(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 2905.060] (**) NOUVEAU(0): Driver mode "1152x864": 108.0 MHz (scaled from 0.0 MHz), 67.5 kHz, 75.0 Hz
[ 2905.060] (II) NOUVEAU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 2905.060] (**) NOUVEAU(0): Driver mode "1024x768": 75.0 MHz (scaled from 0.0 MHz), 56.5 kHz, 70.1 Hz
[ 2905.060] (II) NOUVEAU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 2905.060] (**) NOUVEAU(0): Driver mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz
[ 2905.060] (II) NOUVEAU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 2905.060] (**) NOUVEAU(0): Driver mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.3 Hz
[ 2905.060] (II) NOUVEAU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 2905.060] (**) NOUVEAU(0): Driver mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.2 Hz
[ 2905.060] (II) NOUVEAU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 2905.060] (**) NOUVEAU(0): Driver mode "640x480": 30.2 MHz (scaled from 0.0 MHz), 35.0 kHz, 66.7 Hz
[ 2905.060] (II) NOUVEAU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 2905.060] (**) NOUVEAU(0): Driver mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 59.9 Hz
[ 2905.060] (II) NOUVEAU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 2905.060] (**) NOUVEAU(0): Driver mode "720x400": 28.3 MHz (scaled from 0.0 MHz), 31.5 kHz, 70.1 Hz
[ 2905.060] (II) NOUVEAU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 2905.060] (==) NOUVEAU(0): DPI set to (96, 96)
[ 2905.060] (II) Loading sub module "fb"
[ 2905.060] (II) LoadModule: "fb"
[ 2905.060] (II) Module "fb" already built-in
[ 2905.060] (II) Loading sub module "shadowfb"
[ 2905.060] (II) LoadModule: "shadowfb"
[ 2905.060] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[ 2905.060] (II) Module shadowfb: vendor="X.Org Foundation"
[ 2905.060] compiled for 1.21.1.1, module version = 1.0.0
[ 2905.060] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2905.060] (II) UnloadModule: "modesetting"
[ 2905.060] (II) Unloading modesetting
[ 2905.060] (II) UnloadModule: "fbdev"
[ 2905.060] (II) Unloading fbdev
[ 2905.060] (II) UnloadSubModule: "fbdevhw"
[ 2905.060] (II) Unloading fbdevhw
[ 2905.060] (II) UnloadModule: "vesa"
[ 2905.060] (II) Unloading vesa
[ 2905.061] (II) NOUVEAU(0): Channel setup complete.
[ 2905.061] (II) NOUVEAU(0): [COPY] async initialised.
[ 2905.062] (II) NOUVEAU(0): Hardware support for Present enabled
[ 2905.062] (II) NOUVEAU(0): [DRI2] Setup complete
[ 2905.062] (II) NOUVEAU(0): [DRI2] DRI driver: nouveau
[ 2905.062] (II) NOUVEAU(0): [DRI2] VDPAU driver: nouveau
[ 2905.062] (II) Loading sub module "exa"
[ 2905.062] (II) LoadModule: "exa"
[ 2905.062] (II) Loading /usr/lib/xorg/modules/libexa.so
[ 2905.062] (II) Module exa: vendor="X.Org Foundation"
[ 2905.062] compiled for 1.21.1.1, module version = 2.6.0
[ 2905.062] ABI class: X.Org Video Driver, version 25.2
[ 2905.062] (II) EXA(0): Driver allocated offscreen pixmaps
[ 2905.062] (II) EXA(0): Driver registered support for the following operations:
[ 2905.062] (II) Solid
[ 2905.062] (II) Copy
[ 2905.062] (II) Composite (RENDER acceleration)
[ 2905.062] (II) UploadToScreen
[ 2905.062] (II) DownloadFromScreen
[ 2905.062] (==) NOUVEAU(0): Backing store enabled
[ 2905.062] (==) NOUVEAU(0): Silken mouse enabled
[ 2905.062] (II) NOUVEAU(0): [XvMC] Associated with Nouveau GeForce 8/9 Textured Video.
[ 2905.062] (II) NOUVEAU(0): [XvMC] Extension initialized.
[ 2905.062] (==) NOUVEAU(0): DPMS enabled
[ 2905.062] (II) Initializing extension Generic Event Extension
[ 2905.062] (II) Initializing extension SHAPE
[ 2905.062] (II) Initializing extension MIT-SHM
[ 2905.062] (II) Initializing extension XInputExtension
[ 2905.062] (II) Initializing extension XTEST
[ 2905.063] (II) Initializing extension BIG-REQUESTS
[ 2905.063] (II) Initializing extension SYNC
[ 2905.063] (II) Initializing extension XKEYBOARD
[ 2905.063] (II) Initializing extension XC-MISC
[ 2905.063] (II) Initializing extension SECURITY
[ 2905.063] (II) Initializing extension XFIXES
[ 2905.063] (II) Initializing extension RENDER
[ 2905.063] (II) Initializing extension RANDR
[ 2905.063] (II) Initializing extension COMPOSITE
[ 2905.063] (II) Initializing extension DAMAGE
[ 2905.063] (II) Initializing extension MIT-SCREEN-SAVER
[ 2905.063] (II) Initializing extension DOUBLE-BUFFER
[ 2905.063] (II) Initializing extension RECORD
[ 2905.063] (II) Initializing extension DPMS
[ 2905.064] (II) Initializing extension Present
[ 2905.064] (II) Initializing extension DRI3
[ 2905.064] (II) Initializing extension X-Resource
[ 2905.064] (II) Initializing extension XVideo
[ 2905.064] (II) Initializing extension XVideo-MotionCompensation
[ 2905.064] (II) Initializing extension GLX
[ 2905.085] (II) AIGLX: Loaded and initialized nouveau
[ 2905.085] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 2905.085] (II) Initializing extension XFree86-VidModeExtension
[ 2905.086] (II) Initializing extension XFree86-DGA
[ 2905.086] (II) Initializing extension XFree86-DRI
[ 2905.086] (II) Initializing extension DRI2
[ 2905.089] (II) NOUVEAU(0): NVEnterVT is called.
[ 2905.147] (II) NOUVEAU(0): Setting screen physical size to 1185 x 381
[ 2905.147] resize called 4480 1440
[ 2905.171] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 2905.171] (**) Power Button: Applying InputClass "devname"
[ 2905.171] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 2905.171] (**) Power Button: Applying InputClass "system-keyboard"
[ 2905.171] (II) LoadModule: "libinput"
[ 2905.171] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 2905.172] (II) Module libinput: vendor="X.Org Foundation"
[ 2905.172] compiled for 1.21.1, module version = 1.2.0
[ 2905.172] Module class: X.Org XInput Driver
[ 2905.172] ABI class: X.Org XInput driver, version 24.4
[ 2905.172] (II) Using input driver 'libinput' for 'Power Button'
[ 2905.172] (**) Power Button: always reports core events
[ 2905.172] (**) Option "Device" "/dev/input/event1"
[ 2905.172] (**) Option "_source" "server/udev"
[ 2905.173] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 2905.173] (II) event1 - Power Button: device is a keyboard
[ 2905.174] (II) event1 - Power Button: device removed
[ 2905.221] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 2905.221] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 2905.221] (**) Option "xkb_layout" "de"
[ 2905.235] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 2905.235] (II) event1 - Power Button: device is a keyboard
[ 2905.236] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 2905.236] (**) Power Button: Applying InputClass "devname"
[ 2905.236] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 2905.236] (**) Power Button: Applying InputClass "system-keyboard"
[ 2905.236] (II) Using input driver 'libinput' for 'Power Button'
[ 2905.236] (**) Power Button: always reports core events
[ 2905.236] (**) Option "Device" "/dev/input/event0"
[ 2905.236] (**) Option "_source" "server/udev"
[ 2905.236] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 2905.236] (II) event0 - Power Button: device is a keyboard
[ 2905.236] (II) event0 - Power Button: device removed
[ 2905.281] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 2905.281] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 2905.281] (**) Option "xkb_layout" "de"
[ 2905.281] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 2905.281] (II) event0 - Power Button: device is a keyboard
[ 2905.282] (II) config/udev: Adding input device gspca_zc3xx (/dev/input/event24)
[ 2905.282] (**) gspca_zc3xx: Applying InputClass "devname"
[ 2905.282] (**) gspca_zc3xx: Applying InputClass "libinput keyboard catchall"
[ 2905.282] (**) gspca_zc3xx: Applying InputClass "system-keyboard"
[ 2905.282] (II) Using input driver 'libinput' for 'gspca_zc3xx'
[ 2905.282] (**) gspca_zc3xx: always reports core events
[ 2905.282] (**) Option "Device" "/dev/input/event24"
[ 2905.282] (**) Option "_source" "server/udev"
[ 2905.282] (II) event24 - gspca_zc3xx: is tagged by udev as: Keyboard
[ 2905.282] (II) event24 - gspca_zc3xx: device is a keyboard
[ 2905.283] (II) event24 - gspca_zc3xx: device removed
[ 2905.400] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-10/input/input24/event24"
[ 2905.401] (II) XINPUT: Adding extended input device "gspca_zc3xx" (type: KEYBOARD, id 8)
[ 2905.401] (**) Option "xkb_layout" "de"
[ 2905.401] (II) event24 - gspca_zc3xx: is tagged by udev as: Keyboard
[ 2905.401] (II) event24 - gspca_zc3xx: device is a keyboard
[ 2905.402] (II) config/udev: Adding input device HID 046a:0023 (/dev/input/event2)
[ 2905.402] (**) HID 046a:0023: Applying InputClass "devname"
[ 2905.402] (**) HID 046a:0023: Applying InputClass "libinput keyboard catchall"
[ 2905.402] (**) HID 046a:0023: Applying InputClass "system-keyboard"
[ 2905.402] (II) Using input driver 'libinput' for 'HID 046a:0023'
[ 2905.402] (**) HID 046a:0023: always reports core events
[ 2905.402] (**) Option "Device" "/dev/input/event2"
[ 2905.402] (**) Option "_source" "server/udev"
[ 2905.403] (II) event2 - HID 046a:0023: is tagged by udev as: Keyboard
[ 2905.403] (II) event2 - HID 046a:0023: device is a keyboard
[ 2905.403] (II) event2 - HID 046a:0023: device removed
[ 2905.461] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0/0003:046A:0023.0001/input/input2/event2"
[ 2905.461] (II) XINPUT: Adding extended input device "HID 046a:0023" (type: KEYBOARD, id 9)
[ 2905.461] (**) Option "xkb_layout" "de"
[ 2905.462] (II) event2 - HID 046a:0023: is tagged by udev as: Keyboard
[ 2905.462] (II) event2 - HID 046a:0023: device is a keyboard
[ 2905.462] (II) config/udev: Adding input device HID 046a:0023 (/dev/input/event3)
[ 2905.462] (**) HID 046a:0023: Applying InputClass "devname"
[ 2905.462] (**) HID 046a:0023: Applying InputClass "libinput keyboard catchall"
[ 2905.462] (**) HID 046a:0023: Applying InputClass "system-keyboard"
[ 2905.462] (II) Using input driver 'libinput' for 'HID 046a:0023'
[ 2905.462] (**) HID 046a:0023: always reports core events
[ 2905.462] (**) Option "Device" "/dev/input/event3"
[ 2905.462] (**) Option "_source" "server/udev"
[ 2905.463] (II) event3 - HID 046a:0023: is tagged by udev as: Keyboard
[ 2905.463] (II) event3 - HID 046a:0023: device is a keyboard
[ 2905.463] (II) event3 - HID 046a:0023: device removed
[ 2905.551] (II) libinput: HID 046a:0023: needs a virtual subdevice
[ 2905.551] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.1/0003:046A:0023.0002/input/input3/event3"
[ 2905.551] (II) XINPUT: Adding extended input device "HID 046a:0023" (type: MOUSE, id 10)
[ 2905.551] (**) Option "AccelerationScheme" "none"
[ 2905.551] (**) HID 046a:0023: (accel) selected scheme none/0
[ 2905.551] (**) HID 046a:0023: (accel) acceleration factor: 2.000
[ 2905.551] (**) HID 046a:0023: (accel) acceleration threshold: 4
[ 2905.552] (II) event3 - HID 046a:0023: is tagged by udev as: Keyboard
[ 2905.552] (II) event3 - HID 046a:0023: device is a keyboard
[ 2905.552] (II) config/udev: Adding input device Texas Instruments MSP430-USB Mouse (/dev/input/event4)
[ 2905.552] (**) Texas Instruments MSP430-USB Mouse: Applying InputClass "devname"
[ 2905.552] (**) Texas Instruments MSP430-USB Mouse: Applying InputClass "libinput keyboard catchall"
[ 2905.552] (**) Texas Instruments MSP430-USB Mouse: Applying InputClass "system-keyboard"
[ 2905.552] (II) Using input driver 'libinput' for 'Texas Instruments MSP430-USB Mouse'
[ 2905.552] (**) Texas Instruments MSP430-USB Mouse: always reports core events
[ 2905.552] (**) Option "Device" "/dev/input/event4"
[ 2905.552] (**) Option "_source" "server/udev"
[ 2905.553] (II) event4 - Texas Instruments MSP430-USB Mouse: is tagged by udev as: Keyboard
[ 2905.553] (II) event4 - Texas Instruments MSP430-USB Mouse: device is a keyboard
[ 2905.553] (II) event4 - Texas Instruments MSP430-USB Mouse: device removed
[ 2905.621] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/0003:1044:7A16.0003/input/input4/event4"
[ 2905.621] (II) XINPUT: Adding extended input device "Texas Instruments MSP430-USB Mouse" (type: KEYBOARD, id 11)
[ 2905.621] (**) Option "xkb_layout" "de"
[ 2905.622] (II) event4 - Texas Instruments MSP430-USB Mouse: is tagged by udev as: Keyboard
[ 2905.622] (II) event4 - Texas Instruments MSP430-USB Mouse: device is a keyboard
[ 2905.622] (II) config/udev: Adding input device Texas Instruments MSP430-USB Mouse (/dev/input/event5)
[ 2905.622] (**) Texas Instruments MSP430-USB Mouse: Applying InputClass "devname"
[ 2905.622] (**) Texas Instruments MSP430-USB Mouse: Applying InputClass "libinput pointer catchall"
[ 2905.622] (II) Using input driver 'libinput' for 'Texas Instruments MSP430-USB Mouse'
[ 2905.622] (**) Texas Instruments MSP430-USB Mouse: always reports core events
[ 2905.622] (**) Option "Device" "/dev/input/event5"
[ 2905.622] (**) Option "_source" "server/udev"
[ 2905.691] (II) event5 - Texas Instruments MSP430-USB Mouse: is tagged by udev as: Mouse
[ 2905.691] (II) event5 - Texas Instruments MSP430-USB Mouse: device is a pointer
[ 2905.691] (II) event5 - Texas Instruments MSP430-USB Mouse: device removed
[ 2905.830] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.1/0003:1044:7A16.0004/input/input5/event5"
[ 2905.830] (II) XINPUT: Adding extended input device "Texas Instruments MSP430-USB Mouse" (type: MOUSE, id 12)
[ 2905.831] (**) Option "AccelerationScheme" "none"
[ 2905.831] (**) Texas Instruments MSP430-USB Mouse: (accel) selected scheme none/0
[ 2905.831] (**) Texas Instruments MSP430-USB Mouse: (accel) acceleration factor: 2.000
[ 2905.831] (**) Texas Instruments MSP430-USB Mouse: (accel) acceleration threshold: 4
[ 2905.901] (II) event5 - Texas Instruments MSP430-USB Mouse: is tagged by udev as: Mouse
[ 2905.901] (II) event5 - Texas Instruments MSP430-USB Mouse: device is a pointer
[ 2905.902] (II) config/udev: Adding input device Texas Instruments MSP430-USB Mouse (/dev/input/mouse0)
[ 2905.902] (**) Texas Instruments MSP430-USB Mouse: Applying InputClass "devname"
[ 2905.902] (II) Using input driver 'libinput' for 'Texas Instruments MSP430-USB Mouse'
[ 2905.902] (**) Texas Instruments MSP430-USB Mouse: always reports core events
[ 2905.902] (**) Option "Device" "/dev/input/mouse0"
[ 2905.902] (**) Option "_source" "server/udev"
[ 2905.990] (II) mouse0 - not using input device '/dev/input/mouse0'.
[ 2905.990] (EE) libinput: Texas Instruments MSP430-USB Mouse: Failed to create a device for /dev/input/mouse0
[ 2905.990] (EE) PreInit returned 2 for "Texas Instruments MSP430-USB Mouse"
[ 2905.990] (II) UnloadModule: "libinput"
[ 2905.991] (II) config/udev: Adding input device Texas Instruments MSP430-USB Mouse (/dev/input/event6)
[ 2905.991] (**) Texas Instruments MSP430-USB Mouse: Applying InputClass "devname"
[ 2905.991] (**) Texas Instruments MSP430-USB Mouse: Applying InputClass "libinput pointer catchall"
[ 2905.991] (II) Using input driver 'libinput' for 'Texas Instruments MSP430-USB Mouse'
[ 2905.991] (**) Texas Instruments MSP430-USB Mouse: always reports core events
[ 2905.991] (**) Option "Device" "/dev/input/event6"
[ 2905.991] (**) Option "_source" "server/udev"
[ 2905.992] (II) event6 - Texas Instruments MSP430-USB Mouse: is tagged by udev as: Mouse
[ 2905.992] (II) event6 - Texas Instruments MSP430-USB Mouse: device is a pointer
[ 2905.992] (II) event6 - Texas Instruments MSP430-USB Mouse: device removed
[ 2906.080] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.2/0003:1044:7A16.0005/input/input6/event6"
[ 2906.080] (II) XINPUT: Adding extended input device "Texas Instruments MSP430-USB Mouse" (type: MOUSE, id 13)
[ 2906.081] (**) Option "AccelerationScheme" "none"
[ 2906.081] (**) Texas Instruments MSP430-USB Mouse: (accel) selected scheme none/0
[ 2906.081] (**) Texas Instruments MSP430-USB Mouse: (accel) acceleration factor: 2.000
[ 2906.081] (**) Texas Instruments MSP430-USB Mouse: (accel) acceleration threshold: 4
[ 2906.081] (II) event6 - Texas Instruments MSP430-USB Mouse: is tagged by udev as: Mouse
[ 2906.082] (II) event6 - Texas Instruments MSP430-USB Mouse: device is a pointer
[ 2906.082] (II) config/udev: Adding input device Texas Instruments MSP430-USB Mouse (/dev/input/js0)
[ 2906.082] (**) Texas Instruments MSP430-USB Mouse: Applying InputClass "devname"
[ 2906.082] (II) Using input driver 'libinput' for 'Texas Instruments MSP430-USB Mouse'
[ 2906.082] (**) Texas Instruments MSP430-USB Mouse: always reports core events
[ 2906.082] (**) Option "Device" "/dev/input/js0"
[ 2906.082] (**) Option "_source" "server/udev"
[ 2906.160] (II) js0 - not using input device '/dev/input/js0'.
[ 2906.160] (EE) libinput: Texas Instruments MSP430-USB Mouse: Failed to create a device for /dev/input/js0
[ 2906.160] (EE) PreInit returned 2 for "Texas Instruments MSP430-USB Mouse"
[ 2906.160] (II) UnloadModule: "libinput"
[ 2906.161] (II) config/udev: Adding input device Texas Instruments MSP430-USB Mouse (/dev/input/mouse1)
[ 2906.161] (**) Texas Instruments MSP430-USB Mouse: Applying InputClass "devname"
[ 2906.161] (II) Using input driver 'libinput' for 'Texas Instruments MSP430-USB Mouse'
[ 2906.161] (**) Texas Instruments MSP430-USB Mouse: always reports core events
[ 2906.161] (**) Option "Device" "/dev/input/mouse1"
[ 2906.161] (**) Option "_source" "server/udev"
[ 2906.240] (II) mouse1 - not using input device '/dev/input/mouse1'.
[ 2906.240] (EE) libinput: Texas Instruments MSP430-USB Mouse: Failed to create a device for /dev/input/mouse1
[ 2906.240] (EE) PreInit returned 2 for "Texas Instruments MSP430-USB Mouse"
[ 2906.240] (II) UnloadModule: "libinput"
[ 2906.241] (II) config/udev: Adding input device Texas Instruments MSP430-USB Mouse Consumer Control (/dev/input/event7)
[ 2906.241] (**) Texas Instruments MSP430-USB Mouse Consumer Control: Applying InputClass "devname"
[ 2906.241] (**) Texas Instruments MSP430-USB Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 2906.241] (**) Texas Instruments MSP430-USB Mouse Consumer Control: Applying InputClass "system-keyboard"
[ 2906.241] (II) Using input driver 'libinput' for 'Texas Instruments MSP430-USB Mouse Consumer Control'
[ 2906.241] (**) Texas Instruments MSP430-USB Mouse Consumer Control: always reports core events
[ 2906.241] (**) Option "Device" "/dev/input/event7"
[ 2906.241] (**) Option "_source" "server/udev"
[ 2906.242] (II) event7 - Texas Instruments MSP430-USB Mouse Consumer Control: is tagged by udev as: Keyboard
[ 2906.242] (II) event7 - Texas Instruments MSP430-USB Mouse Consumer Control: device is a keyboard
[ 2906.242] (II) event7 - Texas Instruments MSP430-USB Mouse Consumer Control: device removed
[ 2906.280] (II) libinput: Texas Instruments MSP430-USB Mouse Consumer Control: needs a virtual subdevice
[ 2906.281] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.2/0003:1044:7A16.0005/input/input7/event7"
[ 2906.281] (II) XINPUT: Adding extended input device "Texas Instruments MSP430-USB Mouse Consumer Control" (type: MOUSE, id 14)
[ 2906.281] (**) Option "AccelerationScheme" "none"
[ 2906.281] (**) Texas Instruments MSP430-USB Mouse Consumer Control: (accel) selected scheme none/0
[ 2906.281] (**) Texas Instruments MSP430-USB Mouse Consumer Control: (accel) acceleration factor: 2.000
[ 2906.281] (**) Texas Instruments MSP430-USB Mouse Consumer Control: (accel) acceleration threshold: 4
[ 2906.281] (II) event7 - Texas Instruments MSP430-USB Mouse Consumer Control: is tagged by udev as: Keyboard
[ 2906.282] (II) event7 - Texas Instruments MSP430-USB Mouse Consumer Control: device is a keyboard
[ 2906.282] (II) config/udev: Adding input device Texas Instruments MSP430-USB Mouse (/dev/input/event8)
[ 2906.282] (**) Texas Instruments MSP430-USB Mouse: Applying InputClass "devname"
[ 2906.282] (**) Texas Instruments MSP430-USB Mouse: Applying InputClass "libinput keyboard catchall"
[ 2906.282] (**) Texas Instruments MSP430-USB Mouse: Applying InputClass "system-keyboard"
[ 2906.282] (II) Using input driver 'libinput' for 'Texas Instruments MSP430-USB Mouse'
[ 2906.282] (**) Texas Instruments MSP430-USB Mouse: always reports core events
[ 2906.282] (**) Option "Device" "/dev/input/event8"
[ 2906.282] (**) Option "_source" "server/udev"
[ 2906.283] (II) event8 - Texas Instruments MSP430-USB Mouse: is tagged by udev as: Keyboard
[ 2906.283] (II) event8 - Texas Instruments MSP430-USB Mouse: device is a keyboard
[ 2906.283] (II) event8 - Texas Instruments MSP430-USB Mouse: device removed
[ 2906.360] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.2/0003:1044:7A16.0005/input/input8/event8"
[ 2906.360] (II) XINPUT: Adding extended input device "Texas Instruments MSP430-USB Mouse" (type: KEYBOARD, id 15)
[ 2906.360] (**) Option "xkb_layout" "de"
[ 2906.361] (II) event8 - Texas Instruments MSP430-USB Mouse: is tagged by udev as: Keyboard
[ 2906.362] (II) event8 - Texas Instruments MSP430-USB Mouse: device is a keyboard
[ 2906.362] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event16)
[ 2906.362] (**) HDA Intel PCH Front Mic: Applying InputClass "devname"
[ 2906.362] (II) Using input driver 'libinput' for 'HDA Intel PCH Front Mic'
[ 2906.362] (**) HDA Intel PCH Front Mic: always reports core events
[ 2906.362] (**) Option "Device" "/dev/input/event16"
[ 2906.362] (**) Option "_source" "server/udev"
[ 2906.362] (II) event16 - HDA Intel PCH Front Mic: is tagged by udev as: Switch
[ 2906.440] (II) event16 - not using input device '/dev/input/event16'.
[ 2906.440] (EE) libinput: HDA Intel PCH Front Mic: Failed to create a device for /dev/input/event16
[ 2906.440] (EE) PreInit returned 2 for "HDA Intel PCH Front Mic"
[ 2906.440] (II) UnloadModule: "libinput"
[ 2906.441] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event17)
[ 2906.441] (**) HDA Intel PCH Rear Mic: Applying InputClass "devname"
[ 2906.441] (II) Using input driver 'libinput' for 'HDA Intel PCH Rear Mic'
[ 2906.441] (**) HDA Intel PCH Rear Mic: always reports core events
[ 2906.441] (**) Option "Device" "/dev/input/event17"
[ 2906.441] (**) Option "_source" "server/udev"
[ 2906.441] (II) event17 - HDA Intel PCH Rear Mic: is tagged by udev as: Switch
[ 2906.520] (II) event17 - not using input device '/dev/input/event17'.
[ 2906.520] (EE) libinput: HDA Intel PCH Rear Mic: Failed to create a device for /dev/input/event17
[ 2906.520] (EE) PreInit returned 2 for "HDA Intel PCH Rear Mic"
[ 2906.520] (II) UnloadModule: "libinput"
[ 2906.521] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event18)
[ 2906.521] (**) HDA Intel PCH Line: Applying InputClass "devname"
[ 2906.521] (II) Using input driver 'libinput' for 'HDA Intel PCH Line'
[ 2906.521] (**) HDA Intel PCH Line: always reports core events
[ 2906.521] (**) Option "Device" "/dev/input/event18"
[ 2906.521] (**) Option "_source" "server/udev"
[ 2906.521] (II) event18 - HDA Intel PCH Line: is tagged by udev as: Switch
[ 2906.600] (II) event18 - not using input device '/dev/input/event18'.
[ 2906.600] (EE) libinput: HDA Intel PCH Line: Failed to create a device for /dev/input/event18
[ 2906.600] (EE) PreInit returned 2 for "HDA Intel PCH Line"
[ 2906.600] (II) UnloadModule: "libinput"
[ 2906.601] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event19)
[ 2906.601] (**) HDA Intel PCH Line Out Front: Applying InputClass "devname"
[ 2906.601] (II) Using input driver 'libinput' for 'HDA Intel PCH Line Out Front'
[ 2906.601] (**) HDA Intel PCH Line Out Front: always reports core events
[ 2906.601] (**) Option "Device" "/dev/input/event19"
[ 2906.601] (**) Option "_source" "server/udev"
[ 2906.601] (II) event19 - HDA Intel PCH Line Out Front: is tagged by udev as: Switch
[ 2906.680] (II) event19 - not using input device '/dev/input/event19'.
[ 2906.680] (EE) libinput: HDA Intel PCH Line Out Front: Failed to create a device for /dev/input/event19
[ 2906.680] (EE) PreInit returned 2 for "HDA Intel PCH Line Out Front"
[ 2906.680] (II) UnloadModule: "libinput"
[ 2906.681] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event20)
[ 2906.681] (**) HDA Intel PCH Line Out Surround: Applying InputClass "devname"
[ 2906.681] (II) Using input driver 'libinput' for 'HDA Intel PCH Line Out Surround'
[ 2906.681] (**) HDA Intel PCH Line Out Surround: always reports core events
[ 2906.681] (**) Option "Device" "/dev/input/event20"
[ 2906.681] (**) Option "_source" "server/udev"
[ 2906.681] (II) event20 - HDA Intel PCH Line Out Surround: is tagged by udev as: Switch
[ 2906.760] (II) event20 - not using input device '/dev/input/event20'.
[ 2906.761] (EE) libinput: HDA Intel PCH Line Out Surround: Failed to create a device for /dev/input/event20
[ 2906.761] (EE) PreInit returned 2 for "HDA Intel PCH Line Out Surround"
[ 2906.761] (II) UnloadModule: "libinput"
[ 2906.762] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event21)
[ 2906.762] (**) HDA Intel PCH Line Out CLFE: Applying InputClass "devname"
[ 2906.762] (II) Using input driver 'libinput' for 'HDA Intel PCH Line Out CLFE'
[ 2906.762] (**) HDA Intel PCH Line Out CLFE: always reports core events
[ 2906.762] (**) Option "Device" "/dev/input/event21"
[ 2906.762] (**) Option "_source" "server/udev"
[ 2906.764] (II) event21 - HDA Intel PCH Line Out CLFE: is tagged by udev as: Switch
[ 2906.840] (II) event21 - not using input device '/dev/input/event21'.
[ 2906.841] (EE) libinput: HDA Intel PCH Line Out CLFE: Failed to create a device for /dev/input/event21
[ 2906.841] (EE) PreInit returned 2 for "HDA Intel PCH Line Out CLFE"
[ 2906.841] (II) UnloadModule: "libinput"
[ 2906.842] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event22)
[ 2906.842] (**) HDA Intel PCH Line Out Side: Applying InputClass "devname"
[ 2906.842] (II) Using input driver 'libinput' for 'HDA Intel PCH Line Out Side'
[ 2906.842] (**) HDA Intel PCH Line Out Side: always reports core events
[ 2906.842] (**) Option "Device" "/dev/input/event22"
[ 2906.842] (**) Option "_source" "server/udev"
[ 2906.844] (II) event22 - HDA Intel PCH Line Out Side: is tagged by udev as: Switch
[ 2906.920] (II) event22 - not using input device '/dev/input/event22'.
[ 2906.921] (EE) libinput: HDA Intel PCH Line Out Side: Failed to create a device for /dev/input/event22
[ 2906.921] (EE) PreInit returned 2 for "HDA Intel PCH Line Out Side"
[ 2906.921] (II) UnloadModule: "libinput"
[ 2906.922] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event23)
[ 2906.922] (**) HDA Intel PCH Front Headphone: Applying InputClass "devname"
[ 2906.922] (II) Using input driver 'libinput' for 'HDA Intel PCH Front Headphone'
[ 2906.922] (**) HDA Intel PCH Front Headphone: always reports core events
[ 2906.922] (**) Option "Device" "/dev/input/event23"
[ 2906.922] (**) Option "_source" "server/udev"
[ 2906.924] (II) event23 - HDA Intel PCH Front Headphone: is tagged by udev as: Switch
[ 2907.000] (II) event23 - not using input device '/dev/input/event23'.
[ 2907.001] (EE) libinput: HDA Intel PCH Front Headphone: Failed to create a device for /dev/input/event23
[ 2907.001] (EE) PreInit returned 2 for "HDA Intel PCH Front Headphone"
[ 2907.001] (II) UnloadModule: "libinput"
[ 2907.003] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
[ 2907.003] (**) HDA NVidia HDMI/DP,pcm=3: Applying InputClass "devname"
[ 2907.003] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=3'
[ 2907.003] (**) HDA NVidia HDMI/DP,pcm=3: always reports core events
[ 2907.003] (**) Option "Device" "/dev/input/event10"
[ 2907.003] (**) Option "_source" "server/udev"
[ 2907.006] (II) event10 - HDA NVidia HDMI/DP,pcm=3: is tagged by udev as: Switch
[ 2907.080] (II) event10 - not using input device '/dev/input/event10'.
[ 2907.081] (EE) libinput: HDA NVidia HDMI/DP,pcm=3: Failed to create a device for /dev/input/event10
[ 2907.081] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=3"
[ 2907.081] (II) UnloadModule: "libinput"
[ 2907.082] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[ 2907.082] (**) HDA NVidia HDMI/DP,pcm=7: Applying InputClass "devname"
[ 2907.082] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=7'
[ 2907.082] (**) HDA NVidia HDMI/DP,pcm=7: always reports core events
[ 2907.082] (**) Option "Device" "/dev/input/event11"
[ 2907.082] (**) Option "_source" "server/udev"
[ 2907.085] (II) event11 - HDA NVidia HDMI/DP,pcm=7: is tagged by udev as: Switch
[ 2907.160] (II) event11 - not using input device '/dev/input/event11'.
[ 2907.161] (EE) libinput: HDA NVidia HDMI/DP,pcm=7: Failed to create a device for /dev/input/event11
[ 2907.161] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=7"
[ 2907.161] (II) UnloadModule: "libinput"
[ 2907.162] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
[ 2907.162] (**) HDA NVidia HDMI/DP,pcm=8: Applying InputClass "devname"
[ 2907.162] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=8'
[ 2907.162] (**) HDA NVidia HDMI/DP,pcm=8: always reports core events
[ 2907.162] (**) Option "Device" "/dev/input/event12"
[ 2907.162] (**) Option "_source" "server/udev"
[ 2907.165] (II) event12 - HDA NVidia HDMI/DP,pcm=8: is tagged by udev as: Switch
[ 2907.240] (II) event12 - not using input device '/dev/input/event12'.
[ 2907.241] (EE) libinput: HDA NVidia HDMI/DP,pcm=8: Failed to create a device for /dev/input/event12
[ 2907.241] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=8"
[ 2907.241] (II) UnloadModule: "libinput"
[ 2907.242] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[ 2907.242] (**) HDA NVidia HDMI/DP,pcm=9: Applying InputClass "devname"
[ 2907.242] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=9'
[ 2907.242] (**) HDA NVidia HDMI/DP,pcm=9: always reports core events
[ 2907.242] (**) Option "Device" "/dev/input/event13"
[ 2907.242] (**) Option "_source" "server/udev"
[ 2907.245] (II) event13 - HDA NVidia HDMI/DP,pcm=9: is tagged by udev as: Switch
[ 2907.340] (II) event13 - not using input device '/dev/input/event13'.
[ 2907.341] (EE) libinput: HDA NVidia HDMI/DP,pcm=9: Failed to create a device for /dev/input/event13
[ 2907.341] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=9"
[ 2907.341] (II) UnloadModule: "libinput"
[ 2907.342] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event14)
[ 2907.342] (**) HDA NVidia HDMI/DP,pcm=10: Applying InputClass "devname"
[ 2907.342] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=10'
[ 2907.342] (**) HDA NVidia HDMI/DP,pcm=10: always reports core events
[ 2907.342] (**) Option "Device" "/dev/input/event14"
[ 2907.342] (**) Option "_source" "server/udev"
[ 2907.345] (II) event14 - HDA NVidia HDMI/DP,pcm=10: is tagged by udev as: Switch
[ 2907.420] (II) event14 - not using input device '/dev/input/event14'.
[ 2907.421] (EE) libinput: HDA NVidia HDMI/DP,pcm=10: Failed to create a device for /dev/input/event14
[ 2907.421] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=10"
[ 2907.421] (II) UnloadModule: "libinput"
[ 2907.422] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event15)
[ 2907.422] (**) HDA NVidia HDMI/DP,pcm=11: Applying InputClass "devname"
[ 2907.422] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=11'
[ 2907.422] (**) HDA NVidia HDMI/DP,pcm=11: always reports core events
[ 2907.422] (**) Option "Device" "/dev/input/event15"
[ 2907.422] (**) Option "_source" "server/udev"
[ 2907.425] (II) event15 - HDA NVidia HDMI/DP,pcm=11: is tagged by udev as: Switch
[ 2907.500] (II) event15 - not using input device '/dev/input/event15'.
[ 2907.500] (EE) libinput: HDA NVidia HDMI/DP,pcm=11: Failed to create a device for /dev/input/event15
[ 2907.500] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=11"
[ 2907.500] (II) UnloadModule: "libinput"
[ 2907.501] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event9)
[ 2907.501] (**) Eee PC WMI hotkeys: Applying InputClass "devname"
[ 2907.501] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 2907.501] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[ 2907.501] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[ 2907.501] (**) Eee PC WMI hotkeys: always reports core events
[ 2907.501] (**) Option "Device" "/dev/input/event9"
[ 2907.501] (**) Option "_source" "server/udev"
[ 2907.501] (II) event9 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 2907.501] (II) event9 - Eee PC WMI hotkeys: device is a keyboard
[ 2907.501] (II) event9 - Eee PC WMI hotkeys: device removed
[ 2907.580] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input9/event9"
[ 2907.580] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 16)
[ 2907.580] (**) Option "xkb_layout" "de"
[ 2907.581] (II) event9 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 2907.581] (II) event9 - Eee PC WMI hotkeys: device is a keyboard
[ 2907.586] (**) HID 046a:0023: Applying InputClass "devname"
[ 2907.586] (**) HID 046a:0023: Applying InputClass "libinput keyboard catchall"
[ 2907.586] (**) HID 046a:0023: Applying InputClass "system-keyboard"
[ 2907.586] (II) Using input driver 'libinput' for 'HID 046a:0023'
[ 2907.586] (**) HID 046a:0023: always reports core events
[ 2907.586] (**) Option "Device" "/dev/input/event3"
[ 2907.586] (**) Option "_source" "_driver/libinput"
[ 2907.586] (II) libinput: HID 046a:0023: is a virtual subdevice
[ 2907.586] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.1/0003:046A:0023.0002/input/input3/event3"
[ 2907.586] (II) XINPUT: Adding extended input device "HID 046a:0023" (type: KEYBOARD, id 17)
[ 2907.586] (**) Option "xkb_layout" "de"
[ 2907.586] (**) Texas Instruments MSP430-USB Mouse Consumer Control: Applying InputClass "devname"
[ 2907.586] (**) Texas Instruments MSP430-USB Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 2907.586] (**) Texas Instruments MSP430-USB Mouse Consumer Control: Applying InputClass "system-keyboard"
[ 2907.586] (II) Using input driver 'libinput' for 'Texas Instruments MSP430-USB Mouse Consumer Control'
[ 2907.586] (**) Texas Instruments MSP430-USB Mouse Consumer Control: always reports core events
[ 2907.586] (**) Option "Device" "/dev/input/event7"
[ 2907.586] (II) libinput: Texas Instruments MSP430-USB Mouse Consumer Control: is a virtual subdevice
[ 2907.586] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.2/0003:1044:7A16.0005/input/input7/event7"
[ 2907.586] (II) XINPUT: Adding extended input device "Texas Instruments MSP430-USB Mouse Consumer Control" (type: KEYBOARD, id 18)
[ 2949.225] failure to allocate surface 10x8@8 (pitch 64): -2
[ 3336.156] (EE) event2 - HID 046a:0023: client bug: event processing lagging behind by 15ms, your system is too slow
[ 3506.251] failure to allocate surface 12x16@8 (pitch 64): -2
[ 3822.937] (EE) event2 - HID 046a:0023: client bug: event processing lagging behind by 26ms, your system is too slow
inxi -Fx
[man@man-allseries ~]$ inxi -Fxx
System: Host: man-allseries Kernel: 5.10.80-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: i3 4.20.1 dm: LightDM
Machine: Type: Desktop System: ASUS product: All Series v: N/A serial: <superuser required>
Mobo: ASUSTeK model: H97-PRO v: Rev X.0x serial: <superuser required> UEFI: American Megatrends v: 2906
date: 02/24/2016
CPU: Info: Quad Core model: Intel Core i7-4790 bits: 64 type: MT MCP arch: Haswell rev: 3 cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57470
Speed: 3610 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 3610 2: 3597 3: 3592 4: 3592 5: 3592 6: 3627 7: 3703
8: 3624
Graphics: Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ASUSTeK driver: nouveau v: kernel bus-ID: 05:00.0
chip-ID: 10de:1380
Display: x11 server: X.Org 1.21.1.1 driver: loaded: nouveau unloaded: fbdev,modesetting,vesa alternate: nv
resolution: 1: 1920x1080~60Hz 2: 2560x1440~60Hz s-dpi: 96
Audio: Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8ca0
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 05:00.1 chip-ID: 10de:0fbc
Device-3: Logitech QuickCam Messanger type: USB driver: gspca_zc3xx,snd-usb-audio bus-ID: 3-10:6 chip-ID: 046d:08da
Sound Server-1: ALSA v: k5.10.80-1-lts running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Network: Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: kernel port: f040 bus-ID: 00:19.0
chip-ID: 8086:15a1
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 78:24:af:34:c5:71
Drives: Local Storage: total: 3.64 TiB used: 50.64 GiB (1.4%)
ID-1: /dev/sda vendor: Seagate model: ST3000DM001-1ER166 size: 2.73 TiB speed: 6.0 Gb/s serial: Z5004M0V
ID-2: /dev/sdb vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB speed: 6.0 Gb/s serial: 1830E14B53BB
Partition: ID-1: / size: 931.01 GiB used: 50.64 GiB (5.4%) fs: btrfs dev: /dev/sdb2
ID-2: /boot/efi size: 511 MiB used: 576 KiB (0.1%) fs: vfat dev: /dev/sdb1
ID-3: /home size: 931.01 GiB used: 50.64 GiB (5.4%) fs: btrfs dev: /dev/sdb2
ID-4: /var/log size: 931.01 GiB used: 50.64 GiB (5.4%) fs: btrfs dev: /dev/sdb2
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 27.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1110
Info: Processes: 236 Uptime: 3h 6m Memory: 31.27 GiB used: 3.74 GiB (12.0%) Init: systemd v: 249 Compilers: gcc: 11.1.0
Packages: pacman: 1061 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.07
