I just got back to my computer recently & decided to update it but now every time that I login I must unplug my second monitor in order for the plasma session to remain responsive. Plugging the monitor back in after logging in seems to be fine. I am new to providing useful information, so please let me know if there are any logs that will help me with this problem.
Hi @101grease and welcome to the
-Forum
Several bugs of this type have occurred so far. I posted about it on KDE Bugs
and also here in the forum. See below.
What CPU and GPU are you using?
This behavior occurs mainly with AMD GPUs.
CPU: Intel(R) Core™ i7-6700K (8) @ 4.20 GHz
GPU: NVIDIA GeForce RTX 2080 Ti Rev. A [Discrete]
do you know which packages are affected, I didn’t have this issue before updating & I didn’t have the foresight to add timeshift into my system.
It’s not that easy to tell if a package is broken or something else. I see you are using Nvidia. I can’t tell you what’s going on. I just know that several computers are affected by similar bugs.
Here is another Topic on KDE Discuss I have started.
Maybe @bink’s solution will work for you as he is on Nvidia too
I am surmising that I do not have monitors that support adaptive sync since the option isn’t in display configuration so bink’s solution is a non-starter. Based upon what was said for the issue you were running into, you think it is a plasma issue, so do you think I should submit a bug report there for my issue or would it be more useful of a report in some other package?
I would submit a bug report to KDE Bugs. If the maintainers there want any logs, you can send them in at any time. It’s also not a problem to bring this up directly on KDE Discuss. The whole situation is really annoying. I’m sure I’m not the only one who feels this way. Every time my screen turns off, I have to shut down my computer using the power button. That’s not really useful. I’ve already disabled all power-saving settings, both in KDE and on the monitor. Today I got lucky and haven’t had to restart since noon. Like I said, that’s not really satisfactory.
