My system keeps freezing after a couple minutes of usage on a fresh install of Endeavour. Most applications stop working, and entering any command in the terminal results in the message “command not found”. My task bar disappears and eventually my entire screen turns black. I do not know if this is a hardware or software failure. I have included the logs of journalctl --since=today. Please help!
When I first got in I updated my mirrors and ran sudo pacman -Syu. Crashes started happening after I installed lutris. Specifically upon installing League of Legends did my system start to freeze. I later removed lutris and crashed one more time. I’ve now been using the system for about an hour and everything seems to be working alright.
Thanks for the help @petsam, it seems like lutris is the main culprit. I installed it again to test and it indeed froze my whole system. Upon removing lutris everything returns to normal. Guess I’ll just refrain from using lutris for now!
Looks like my pc crashed again, thrice.
Here are the boot logs: https://clbin.com/zAZjH
The first time it happened after installing steam. The following crashes both happened a couple minutes after booting and using firefox. My entire system freezes and any commands I insert into the terminal are met with “command not found”. Kinda lost right now…
Something worth a try would be to check the healt of the disk and also perhaps run a filesystem check from within a live session. Just to eliminate possible causes.
I got met with this after I let my pc running during a freeze. Sorry I had to take it with my phone. I’ll see if I can boot again to try what you guys said.
I crashed again after about an hour of usage. It worked fine until then. It was different this time though. Instead of my system freezing up, I was instantly brought to the screen above.
