My system freez expecially when watchin video online, I can do nothing, the only way is to force off the notebook. At restart I try to see if I can have some logs helping understand what’s the isse but:
cris@cris-huawei ~]$ journalctl -b -1
Specifying boot ID or boot offset has no effect, no persistent journal was found.
How can I have a log considering I need to force restart my pc?
i have the same problem with Arch, Manjaro, Garuda, OpenSuse and with ol lts kernel too … so is not strictly related to EnOs but probably hardare problem
Thanks
My system is:
#################### inxi -Fxxc0z ########################
Kernel: 6.2.2-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.1 Desktop: KDE Plasma v: 5.27.2
tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: HUAWEI product: KPL-W0X v: M1D serial:
Mobo: HUAWEI model: KPL-W0X-PCB v: M1D serial: UEFI: HUAWEI v: 1.24
date: 04/11/2022
Battery:
ID-1: BAT1 charge: 53.5 Wh (100.0%) condition: 53.5/56.3 Wh (95.0%) volts: 8.0 min: 7.6
model: DYNAPACK HB4593R1ECW serial: status: full
Info: quad core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP
arch: Zen rev: 0 cache: L1: 384 KiB L2: 2 MiB L3: 4 MiB
Speed (MHz): avg: 1571 high: 1600 min/max: 1600/2000 boost: enabled cores: 1: 1370 2: 1600
3: 1600 4: 1600 5: 1600 6: 1600 7: 1600 8: 1600 bogomips: 31952
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series] vendor: Huawei
driver: amdgpu v: kernel arch: GCN-5 pcie: speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 02:00.0 chip-ID: 1002:15dd temp: 49.0 C
Device-2: Quanta hm1091_techfront type: USB driver: uvcvideo bus-ID: 1-1:2 chip-ID: 0408:1020
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x14d4 res: 1920x1080 dpi: 158
diag: 354mm (13.9")
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon Vega 8 Graphics (raven LLVM 15.0.7 DRM
3.49 6.2.2-arch1-1) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Huawei driver: snd_hda_intel v: kernel
pcie: speed: 8 GT/s lanes: 16 bus-ID: 02:00.1 chip-ID: 1002:15de
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Huawei driver: snd_pci_acp3x v: kernel
pcie: speed: 8 GT/s lanes: 16 bus-ID: 02:00.5 chip-ID: 1022:15e2
Device-3: AMD Family 17h/19h HD Audio vendor: Huawei driver: snd_hda_intel v: kernel pcie:
speed: 8 GT/s lanes: 16 bus-ID: 02:00.6 chip-ID: 1022:15e3
Sound API: ALSA v: k6.2.2-arch1-1 running: yes
Sound Server-2: PipeWire v: 0.3.66 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: speed: 2.5 GT/s lanes: 1
bus-ID: 01:00.0 chip-ID: 8086:24fd
IF: wlan0 state: up mac:
Bluetooth:
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 2-2:2
chip-ID: 8087:0a2b
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: see --recommends
Local Storage: total: 238.47 GiB used: 23.7 GiB (9.9%)
ID-1: /dev/sda vendor: LITE-ON model: CV8-8E256 size: 238.47 GiB speed: 6.0 Gb/s
serial:
ID-1: / size: 237.49 GiB used: 23.63 GiB (9.9%) fs: btrfs dev: /dev/sda2
ID-2: /home size: 237.49 GiB used: 23.63 GiB (9.9%) fs: btrfs dev: /dev/sda2
ID-3: /var/log size: 237.49 GiB used: 23.63 GiB (9.9%) fs: btrfs dev: /dev/sda2
System Temperatures: cpu: 49.1 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): N/A
Processes: 263 Uptime: 1m Memory: 6.68 GiB used: 1.27 GiB (19.0%) Init: systemd v: 253
default: graphical Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1017
Client: Unknown Client: systemd inxi: 3.3.25
