Hi, I installed the system again because I changed SSD, but when I put the pc to sleep ( or happens due to inactivity), most of the time I get no login windows and just a black screen with the cursor able to move
full red team user
You can share some hardware info like this:
inxi -Fxxc0z | eos-sendlog
Are you able to reproduce the issue by manually invoking suspend?
systemctl suspend
When you resume to a black screen with only a cursor, are you able to switch to a TTY? Press Ctrl+Alt+F2 (or F3, or F4, and so on) to switch to a TTY.
When you have a chance, enable Magic SysReq: [Tip] Enable Magic SysRq Key (REISUB) See if invoking the first few letters from the black screen (R, E, I) jostles the system back into responsiveness.
I’ve been having the same issue and I figured out that re-selecting the input source on the monitor brings he display back.
here my device hardware, tried repeating the issue, it does repeat but digging more I can tab if there’s multiple apps at the moment, and also I can interact with everything (example: click a youtube video to start a again) but I cannot see the desktop once leaving tab manager
Kernel: 6.6.37-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Mobo: ASUSTeK model: ROG STRIX B650E-F GAMING WIFI v: Rev 1.xx
serial: <superuser required> part-nu: SKU UEFI: American Megatrends v: 2214
date: 01/02/2024
Info: 8-core model: AMD Ryzen 7 7700 bits: 64 type: MT MCP arch: Zen 4
rev: 2 cache: L1: 512 KiB L2: 8 MiB L3: 32 MiB
Speed (MHz): avg: 400 min/max: 400/5389 cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 400 bogomips: 121633
Device-1: AMD Navi 32 [Radeon RX 7700 XT / 7800 XT] vendor: Tul / PowerColor
driver: amdgpu v: kernel arch: RDNA-3 pcie: speed: 16 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0 chip-ID: 1002:747e
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-4,HDMI-A-2 bus-ID: 0f:00.0 chip-ID: 1002:164e temp: 48.0 C
Device-3: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-12:6
chip-ID: 0c45:6366
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: HP M24fw FHD res: 1920x1080
dpi: 93 diag: 628mm (24.7")
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: radeonsi
device: 2 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 18.1.8 DRM 3.54 6.6.37-1-lts) device-ID: 1002:747e
API: Vulkan v: 1.3.279 surfaces: xcb,xlib device: 0 type: discrete-gpu
driver: mesa radv device-ID: 1002:747e device: 1 type: integrated-gpu
driver: mesa radv device-ID: 1002:164e
Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 0f:00.1 chip-ID: 1002:1640
chip-ID: 0c45:6366
Device-4: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-6:2 chip-ID: 0b05:1a52
API: ALSA v: k6.6.37-1-lts status: kernel-api
Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0 chip-ID: 8086:15f3
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
speed: 5 GT/s lanes: 1 bus-ID: 0b:00.0 chip-ID: 14c3:0608
Bluetooth:
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 bus-ID: 1-11:5 chip-ID: 0e8d:0608
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11
Local Storage: total: 2.27 TiB used: 230.6 GiB (9.9%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNV2S500G size: 465.76 GiB
speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 45.9 C
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO Plus 2TB
size: 1.82 TiB speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 49.9 C
ID-1: / size: 1.79 TiB used: 230.44 GiB (12.6%) fs: ext4 dev: /dev/nvme1n1p2
System Temperatures: cpu: 53.9 C mobo: 44.0 C
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 48.0 C mem: 59.0 C fan: 0 device: amdgpu
temp: 48.0 C
Memory: total: 32 GiB note: est. available: 30.57 GiB used: 2.84 GiB (9.3%)
Processes: 339 Power: uptime: 7m wakeups: 0 Init: systemd v: 256
default: graphical
Packages: pm: pacman pkgs: 1203 Compilers: gcc: 14.1.1 Shell: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.35
