You could also try adding it in this file and if it doesn’t work just remove the part you added.
Edit: Or the file if it didn’t exist!
/etc/modprobe.d/alsa.conf
add
options snd-intel-dspcfg dsp_driver=1
add
You could also try install pipewire if that doesn’t work. I’m not sure if you are running pipewire? You can check with
inxi -A
To install pipewire
sudo pacman -S pipewire pipewire-pulse --needed
No change here either
The peculiar thing is that my issue first appeared with pulseaudio
I made the switch to pipewire
this afternoon (following the Archwiki), but the issue stayed exactly the same
The only improvement I have achieved so far was to restore the connection between the system audio controls and the correct audio card by installing sof-firmware
and turning off the dummy audio card [with these two changes, the system can be operated normally and the dummy card ignored in daily usage]
I do know this issue happened on some hardware such as HP Spectre and lenovo Thinkpad and there were two different files that were used as i have given you the one. But it was related to a dummy output and also the mic not working. They changed the original contents of the file to this. But it was also that the sof driver wasn’t enabled and or supported yet. It seems yours is definitely requiring and using the sof driver. Not sure on the dummy output. It may disappear some day with a kernel update or other.
Hopefully so, just like it appeared out of the blue!
Thanks again rick, I will be heading off to bed now.
