Hi, please help, my system crashes everytime I share my screen on Wayland, on Xorg it’s working fine, I can’t seem to get into TTY as well when it crashes, how do I get the important information from the logs about the crash?, I only know journalctl command.
Bei welcome on the purple side
Not sure but I bet Wayland and screen sharing can indeed be buggy… easiest way is to use xorg session to not have such issue if possible
To provide better info check wiki:https://discovery.endeavouros.com/forum-log-tool-options/how-to-include-systemlogs-in-your-post/2021/03/
Hi Joe,
Yes, I’ve tried to use different display manager as well, and the issues still persists, for sure, while I can just switch to Xorg when I’m in the need of sharing my screen, but still if there is something I can do to fix this issue myself, I’ll be glad.
Here’s some information, I’ve read them, but I don’t think I can comprehend where the source of the issue is
Welcome to the forum!
You have both Intel and Nvidia GPU.
Are you using both of them? If so, how do you switch from one to the other?
Can you also show the output of
pacman -Qs xf86-video
lspci -vnn | grep -P 'VGA|3D|Display'
inxi -Gaz
to see what renderer is used please
using nvidia gnome on wayland… i bet it will have little issues… suggesting to use xorg session in this case… or noveau driver …
Thanks, Manuel!
I mainly use the Intel iGPU. I only use the Nvidia GPU for activities like playing games, usually I run them with the prime-run
command.
Here they are :
https://0x0.st/H8Qc.txt
Here’s the output of inxi -Gaz
, Joe :
Device-1: Intel Skylake GT2 [HD Graphics 520]
vendor: ASUSTeK driver: i915 v: kernel arch: Gen-9
process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX110] vendor: ASUSTeK
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm
non-free: 530.xx+ status: current (as of 2023-03)
arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:174e class-ID: 0302
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB
driver: uvcvideo bus-ID: 1-6:5 chip-ID: 13d3:5a01
class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland
v: 23.1.1 compositor: gnome-shell v: 43.4 driver: X:
loaded: intel,nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa dri: i965 gpu: i915
display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0696 built: 2015
res: 1366x768 dpi: 112 gamma: 1.2
size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel HD
Graphics 520 (SKL GT2) direct-render: Yes
Ah, I assume my replies were flagged because I the 0x0 link?
fixed this… system security was unhappy with all the links you posted to fast
Apr 16 09:34:26 wired kernel: asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -19
Apr 16 09:34:26 wired kernel: asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -19
by any chance ther eis possible an update for the system firmware available?
Apr 16 09:34:20 wired kernel: DMI: ASUSTeK COMPUTER INC. VivoBook 14_ASUS Laptop X441UB/X441UB, BIOS X441UB.307 08/06/2019
Also, try uninstalling xf86-video-intel.
If you’re talking about the BIOS, I believe the 307 version is already the latest.
https://www.asus.com/id/supportonly/x441ub/helpdesk_bios/
Just did it!, but is it because https://wiki.archlinux.org/title/Intel_graphics#Installation#note ?
Note: Some (Debian & Ubuntu, Fedora, KDE) recommend not installing the xf86-video-intel driver, and instead falling back on the modesetting driver for Gen 4 and newer hardware. See [1], [2], Xorg#Installation, and modesetting(4). However, the modesetting driver can cause problems such as screen tearing and mouse jittering on XFCE, artifacts when switching virtual desktops in Chromium, and vsync jitter/video stutter in mpv.
I’ve always thought that Xorg needs it for the Intel iGPU.
only for very ancient pre gen 4 intel gpus…
