System crashes after waking up from sleep
System crashes after waking up from sleep.
After some recent updates system crashes when I try to wake it up. I never seen that type of messages before.
Does anyone know what can cause them to happen?
inxi -Fxxc0z --no-host and screens of error
Kernel: 6.9.8-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: ASRock model: H67DE3/SI serial:
BIOS: American Megatrends v: P1.30 date: 02/21/2011
Info: quad core model: Intel Core i5-2500 bits: 64 type: MCP
arch: Sandy Bridge rev: 7 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 1599 high: 1600 min/max: 1600/3700 cores: 1: 1600
2: 1596 3: 1600 4: 1600 bogomips: 26348
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: Micro-Star MSI
driver: nvidia v: 555.58.02 arch: Pascal pcie: speed: 5 GT/s lanes: 16
ports: active: none off: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 01:00.0
chip-ID: 10de:1c81
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Huawei SSN-24
res: 1920x1080 dpi: 93 diag: 604mm (23.8")
API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 2 drv: swrast
gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.58.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
API: Vulkan v: 1.3.279 surfaces: xcb,xlib device: 0 type: discrete-gpu
driver: nvidia device-ID: 10de:1c81
Device-1: Intel 6 Series/C200 Series Family High Definition Audio
vendor: ASRock driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0fb9
API: ALSA v: k6.9.8-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASRock driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac:
IF-ID-1: outline-tun0 state: down mac: N/A
Local Storage: total: 2.73 TiB used: 325.73 GiB (11.7%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-00BBHA0
size: 931.51 GiB speed: 6.0 Gb/s serial:
ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-08WN4A0
ID-3: /dev/sdc vendor: Samsung model: HD103SJ size: 931.51 GiB
ID-1: / size: 901.05 GiB used: 325.73 GiB (36.1%) fs: ext4 dev: /dev/sdb1
ID-1: swap-1 type: partition size: 15 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 40 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 45%
Memory: total: 16 GiB note: est. available: 13.63 GiB used: 3.3 GiB (24.2%)
Processes: 228 Power: uptime: 2h 34m wakeups: 0 Init: systemd v: 256
default: graphical
Packages: 1363 pm: pacman pkgs: 1332 pm: flatpak pkgs: 31 Compilers:
clang: 18.1.8 gcc: 14.1.1 Shell: fish v: 3.7.1 running-in: kitty
inxi: 3.3.35
Well, I actually already have this file. Is there a way to check if a parameter was successfully added?
cat /proc/cmdline
May do it.
That’s all I got:
BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=… rw nowatchdog nvme_load=YES resume=UUID=… loglevel=3 nvidia-drm.modeset=1 nvidia-drm.fbdev=1
What is in nvidia-power-management.conf?
:Edit:
It should be this - all on one line:
options nvidia NVreg_PreserveVideoMemoryAllocations=1 NVreg_TemporaryFilePath=/var/tmp
pm
See above.
OK, changed it to one line. Now I need to regenerate initramfs?
Yes, Dracut? Just run sudo reinstall-kernels
Yes, I use Dracut, but for some reason there is no command sudo reinstall-kernels.
I used something like:
sudo dracut --hostonly --no-hostonly-cmdline --force /boot/initramfs-linux.img
for each kernel.
Unfortunately it still crashes with similar message. I can post a bigger photo if needed.
Just sudo dracut-rebuild this is EndeavourOS, not Arch?
That is a core dump, something really very wrong.
reinstall-kernels is in:
/usr/bin/reinstall-kernels is owned by kernel-install-for-dracut 1.10.1-1
1 endeavouros/kernel-install-for-dracut 1.10.1-1 (18.3 KiB 20.8 KiB) (Installed)
    Enables systemd-boot automation using kernel-install with dracut
This command actually exists but after reboot the problem is still there.
Also there is a message:
:: Building initramfs for linux (6.9.8-arch1-1)
/etc/dracut.conf.d/nvidia.conf: line 1: nvidia: command not found
/etc/dracut.conf.d/nvidia.conf/
force_drivers+=” nvidia nvidia-drm nvidia-modeset nvidia-uvm ”
Is there anything else I could try?
I am out of ideas :frowning:
I guess the only way is to wait for the next NVIDIA driver update or downgrade the current one.
Maybe switching to Wayland could help, but I really doubt that.
Still thank you for your help, now I know about sudo dracut-rebuild.
The entry in the nvidia-power-management.conf and the command dracut-rebuild solved the problem on my computer.
thanks a lot. :+1:
  1. What video card do you have?
  2. Do you use x11 or Wayland?
Gtx1070 with driver 555 and wayland.
Well, it seems to be working for me too. I had big doubts about Wayland, but now it works. The only thing left to figure out is how to launch apps for x11.
