Hi just a noob question about graphic driver.
I have the following graphic chips :
[a2n@a2n-eso ~]$ lspci -k | grep -EA3 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation Raptor Lake-P [Iris Xe Graphics] (rev 04)
DeviceName: Onboard - Video
Subsystem: Tongfang Hongkong Limited Raptor Lake-P [Iris Xe Graphics]
Kernel driver in use: i915
So I have installed the following driver :
sudo pacman -S mesa mesa-utils
But when I go on the “Info Center” of KDE I have a tab in “Graphics” about “Vulkan” that say :
ERROR: [Loader Message] Code 0 : vkCreateInstance: Found no drivers!
Cannot create Vulkan instance.
This problem is often caused by a faulty installation of the Vulkan driver or attempting to use a GPU that does not support Vulkan.
ERROR at /usr/src/debug/vulkan-tools/Vulkan-Tools-1.3.263/vulkaninfo/vulkaninfo.h:688:vkCreateInstance failed with ERROR_INCOMPATIBLE_DRIVER
And when I search for package on pacman
I found :
[a2n@a2n-eso ~]$ sudo pacman -Q | ack vulk
[sudo] password for a2n:
vulkan-headers 1:1.3.264-2
vulkan-icd-loader 1.3.263-1
vulkan-tools 1.3.263-1
So my questions is :
- am I using the wrong driver and need vulkan?
- are these packages useful? (I’m wondering if the EOS installation included them, as I’ve just re-installed my system).
