Hi guys, if some of you want to get the sxhkd output in polybar modules, you will have to first start sxhkd with the -s option to use a fifo and then grab infos from it.
mkfifo /run/user/1000/sxhkd.fifo
sxhkd -s /run/user/1000/sxhkd.fifo
Then create a listener script:
#!/bin/bash
# Listen on sxhkd events to:
# - indicate when in a chord chain,
# the last hotkey and the corresponding command.
# export XDG_RUNTIME_DIR="/run/user/1000/"
# export SXHKD_FIFO="$XDG_RUNTIME_DIR"/sxhkd.fifo
cmd="$XDG_RUNTIME_DIR/cmd.txt"
keys="$XDG_RUNTIME_DIR/keys.txt"
while read line <$SXHKD_FIFO
do
if [[ "$line" == 'EEnd chain' ]]; then
polybar-msg action "#sxhkd-ipc.hook.1" >/dev/null 2>&1
elif [[ "$line" == 'BBegin chain' ]]; then
polybar-msg action "#sxhkd-ipc.hook.0" >/dev/null 2>&1
elif [[ "$line" =~ 'H' ]]; then
echo "$line" > "$keys"
polybar-msg action "#hotkeys-ipc.hook.1" >/dev/null 2>&1
elif [[ "$line" =~ 'C' ]]; then
echo "$line" > "$cmd"
polybar-msg action "#command-ipc.hook.1" >/dev/null 2>&1
fi
done
Ok now another one for sxhkd: (sxhkd-start)
#!/bin/bash
declare -a proc=( "sxhkd" "sxhkd-listener" )
# Terminate existing sxhkd scripts instances
if [[ -n $(pidof sxhkd) ]]; then
for i in "${proc[@]}"; do
kill -15 "$(ps -ef \
| grep "$i" \
| awk 'NR==1 {print $2}')" >/dev/null 2>&1
# Wait until the processes has been shut down
while pidof -x "$i" >/dev/null; do
sleep 0.2
break
done
done
fi
[[ -e $SXHKD_FIFO ]] && rm -f "$SXHKD_FIFO"
sleep 0.5
if [[ -n $(pidof bspwm) ]]; then
# Launch sxhkd, with the -s option for the listener script.
mkfifo "$SXHKD_FIFO"
sxhkd -t 5 \
-s "$SXHKD_FIFO" \
-c "$XDG_CONFIG_HOME"/sxhkd/sxhkdrc &
sxhkd-listener &
notify-send 'hotkeys daemon ready'
else
exit 127
fi
exit
In your polybar config.ini: enable-ipc = true
Now the polybar modules:
[module/sxhkd-ipc]
; Indicate if sxhkd has began a chain and serve as a launcher.
type = custom/ipc
format = <output>
format-padding = 1
hook-0 = echo " %{F#FF4747}%{F-}"
hook-1 = echo " %{F#A6E074}%{F-}"
initial = 2
click-left = sxhkd-start &
[module/hotkeys-ipc]
type = custom/ipc
format = <output>
format-padding = 1
hook-0 = echo ""
hook-1 = echo " %{F#FF4747} $(cat "$XDG_RUNTIME_DIR"/keys.txt | sed 's/H//')%{F-}"
initial = 1
[module/command-ipc]
type = custom/ipc
format = <output>
format-padding = 1
hook-0 = echo ""
hook-1 = echo " %{F#A6E074} $(cat "$XDG_RUNTIME_DIR"/cmd.txt | sed 's/^[[a-z]]//;s/C//')%{F-}"
initial = 1
The first symbol indicates if you’re in a chord chain, then the keybord shortcut and finaly the corresponding command.
Hope you like it! ![]()
