Switching from compile to bin question
I installed oh-my-posh some time ago from the AUR and didn’t realize there is a -bin file there so have been compiling (and waiting updates) all this time. Just discovered the bin the other day and want to switch to it, but I have a question if anyone can answer…
I spent quite a while getting my prompt set up. If I uninstall the base version then reinstall the -bin, will it lose my settings or keep them?
Packages won’t remove(or install) any settings or config in your home directory.
Thanks! I suspected that was the case, but wanted to confirm…spent too much time configuring to want to rebuild lol.
conversely, if you don’t have a lot of patience, -bin is 100X faster than compile..
