BONK
January 19, 2021, 6:29pm
122
Display configuration
Sway manages displays for you, xrandr should not be used.
Run swaymsg -t get_outputs to get a list of output names. Then use the output command to arrange your displays.
For detailed information, check the manual. Run man 5 sway-output.
Multihead
Managing multiple monitors is simple through the use of multiple output commands.
e.g., if we want to have a monitor with HDMI1 and a resolution of 1920x1080, and to the right of it a laptop monitor with eDP1 and a resolution of 1600x900; the following two commands can be placed in your config file:
output HDMI1 pos 0 0 res 1920x1080
output eDP1 pos 1920 0 res 1600x900
Take a note that you might want to change the focus of monitor on sway launch. Add this to your sway config:
focus output <name-or-identifier>
or
exec swaymsg focus output <name-or-identifier>
so it doesn’t trigger on reload.
For more details read man 5 sway-output.
I will add this to the config Thank you!!
I have an issue: When I try to kill a window with mod+shift+c it kills waybar instead. Anyone have the same experience?
Also, shoudn’t we go with Arc-Dark instead of Arc?
Kill a window is just $mod+c
It is pretty non-dark at me. Both the file manager and firefox
BONK
January 19, 2021, 6:48pm
129
morten-b:
file manager
Did you use a file manager that has root access?
Its fixed now. The was an error in sway config. For both filemanager and firefox
Sorry!! Can you also delete autostart? We don’t need it anymore.
I’ve added a mode to shutdown, logout etc. It is activated with mod+e.
The text of waybar is not very nice when this is activated, but it is functional.
Is the shutdown button of waybar able to mimic a keyboard combo? So that we can activate the sway mode from there?
Yes it is. Instead of wlogout in waybar config under “custom/power on-click” launch your sway mode instead.
Yeah, but launching is done with a key combo, not like execiting a script. And ydotool, which could have been used for this is only in AUR
Could you turn that mode into a script??
Hmmmm… I really don’t have any idea.
seems it do not take gtk theme at all and uses the defaults, i do put this what will read the theme settings from the files and apply it:
added this to config file:
# apply gtk theming
exec_always ~/.config/sway/scripts/import-gsettings
~/.config/sway/scripts/import-gsettings:
#!/bin/sh
# usage: import-gsettings
config="${XDG_CONFIG_HOME:-$HOME/.config}/gtk-3.0/settings.ini"
if [ ! -f "$config" ]; then exit 1; fi
gnome_schema="org.gnome.desktop.interface"
gtk_theme="$(grep 'gtk-theme-name' "$config" | cut -d'=' -f2)"
icon_theme="$(grep 'gtk-icon-theme-name' "$config" | cut -d'=' -f2)"
cursor_theme="$(grep 'gtk-cursor-theme-name' "$config" | cut -d'=' -f2)"
font_name="$(grep 'gtk-font-name' "$config" | cut -d'=' -f2)"
gsettings set "$gnome_schema" gtk-theme "$gtk_theme"
gsettings set "$gnome_schema" icon-theme "$icon_theme"
gsettings set "$gnome_schema" cursor-theme "$cursor_theme"
gsettings set "$gnome_schema" font-name "$font_name"
You put my stuff in a script? Clever. Are you adding to your fork? Or a pull request?
