Little hiccup to report. Did a base eos September iso install. Added sway via tty. On boot the Mouse is frozen. Keyboard has limited functionality. Unplug and replug gets back normal function. Reboot and frozen again. Switch to usb3 ports. Everything functions normally.
Also power menu when reboot is selected it just logs out. Not reboot.
I am going to go looking for why if I can in a little while.
Virtualbox or Real Harare? Mouse is probably gonna be a problem with a environment variable. Try commenting out hardware acceleration in .profile. Try commenting out the others and rebooting too…different setups need different environment variables.
The power menu is probably my fault sorry! I’ll solve that.Does the power menu script in waybar look like this
@BONK
I’m using sway in v-box and i did comment out hardware acceleration. The mouse seemed to get stuck occasionally on the bar or hesitate. It works fine now.
Not that this is terribly important but I had tried one other thing that can’t be done the way it is. I made a plasma install that was using wayland. I wanted to add sway alongside to be chosen from sddm log in. The idea being if all went well trying to see if sway could replace kwin/wayland. I have done it with i3 before and xfce/i3. The script will complain at the very end about sddm and cannot proceed. Not a big thing. Any lightdm DE will probably work.
I really like this spin it is going to be my daily driver if all goes well.
Other window managers are only available when using X.org. These changes cannot be made for Wayland sessions yet. With Wayland maturing and Wayland extensions being standardized, this feature could be implemented in Wayland[1]
Ohhhhh… thats because in the script it enables enables lightdm but not with the --force variable. You can run each line separately. Imma probably gonna remove or create a seperate script so it won’t conflict
I won’t pester you anymore lol. I need to dig into this I really like it. I have some research to do. Alacrity is the fastest terminal I have ever used Excellent choice!
I don’t mind being pestered! Makes me feel important! Alacritty is fast if you something with more features(possible the most I’ve ever seen in a terminal) try out wayland native kitty. Its featureful and fast enough
