I tried a bit too hard to make it look nice but you know ![]()
It is ArcDark I promise not Nord!
Make qt themeing guide?? As it a physical written guide or a config file with comments?
I’m guessing after release we will write a wiki page.
Like a wiki
I try on Pi 4… no alacritty so i use xfce terminal
it nice! great work to you
Why no alacritty? Because on pi4?
Any bugs you notice?
@morten-b really little thing but do you like the bar on the bottom or the top. I only set bottom as it was the i3 edition has but by now we are quite different so?
Well I do prefer top, but I would really say that one or another is better. Its just habit. Would do you think?
My habit is top too and so is @Shjim… Imma change it to top if that is ok?
Also if you configure waybar don’t put stuff under *{ list out each module and write the universal padding and margin. This is beacause `*{ overwrites your seperate module configs so stuff like custom/power and workspaces look weird because even though you set a seperate padding it won’t do anything.
I’m not sure I understand, but I won’t touch
yes it pi4
No real bug that your fault…
This my lock screen . I not know till install what you use so it no line up like my. It a small thing but it make me insane it no line up .
if you want fix ? i do for you
Sure if you are free!
also i see your LDM need fix. login cover Endeavouros logo
or you want custom LDM screen? if do ideas welcome
Not many apps for pi4 no wayland teminals support it.
I will ask @morten-b he is in charge of the LDM.
Yes, I’ve noticed as well. Where would you position the login box, if not in the middle? I think I would prefer a custom background
That my
