Created a new branch with theses themes and our CSS attempts
is that workspace button .focused … you talk about?
Just like in general what do you think? Wofi’s color also been changed and waybar
i like your round corner + old purple focused in wofi … just my opinion
Hmmmm… do you think its weird to have the wofi app launcher like it was before and the bar as it is.
Sorry for the questions! Its nice to have an outside eye.
maybe wofi focused be blue like focused workspace ?
if you try keep EOS theming ? maybe try the grey in thunar (File Edit View ) for your waybar modules/workspaces ( white when in use ) Hope you understand ?
grey no in your face … just idea
i do also thinking about taking the colors from arc-dark to theme i3, and the rofi stuff (menu and powermenu)
rofi have already a arc-dark theme inside the default themes installed with the package, this blueishpurple colors come from the xfce4-terminal colors used for xfce4 theming:
The idea of themed setups should be asminimal as we can get, it is only a startingpoint for users to start play with it, and i do not want currently to change from arc theme as it is very stable and complete.
So it is natural to set colors for the WM`s with this colors to even L&F for gui part.
With making it possible to inject personal setup scripts for theming and packages into installer it will be possible to provide different themes on git repos users can choose to use for installation.
would be nice if this “buttons” will be used to show workspace and in the same way open the workspace with indicated application, so that it will be workspace indicator and launcher in the same place…
I see. So you ok for us theming the sway edition arc dark over endeavour os theme
Is that even possible? It seems to be a good idea but might be hard to implement…
100% … then we can add your one to official-supported setups from EOS and also as template for variations what will be very very helpful to implement this new implementation!!!
Logical it could be possible and cool also in a way… it would fit my workflow i do currently autostart most apps i do use on regular base but it would be very natural to have the icons persistent and only need to click on them to open apps—
Well @morten-b we’ve got some work ahead of us now! Lets go ArcDarking and Waybaring.
Arc Dark for Wofi - Thoughts?? Quite nice if I may so myself
@OdiousImp Arc-Darkest is nice but as @joekamprad said the Arc theme EOS use is very stable and never give problems (kept updated )
i have also this new keybind helper coded in yad what will fit with it then:
This is going well . It might take bit longer now but we’ll be ready…
Sorry I’m a bit away, but I’ll catch up with you guys later
