Sway and bspwm
Hi all,
I installed Endauvouros sway Edition and would like to install the Bspwm aswell.
I installed with bspwm with yay but when I login I only get the wallpaper nothing else and no keys are working.
Best regards,
Did you install generic BSPWM or the EOS community edition? If it’s the generic version, then you will need to install something like sxhkd to handle the key bindings as well. Once you have that the config for it is in the /.config/sxhkd/sxhdkrc file. For the community edition, check out this great post:
Thanks had to solve some package conflicts but other than that it worked very nice. Thank you.
