Suspend fails when running software using NVIDIA GPU
I’ve been having this issue on and off recently, and in the past few days it happens regularly.
I’m running a Lenovo P51 with a dual GPU setup (Intel and NVIDIA) and nvidia-dkms 580.82.09-1
If I suspend the computer while, say, using a terminal, it does so just fine. If I run, for instance, Blender, and suspended it before closing it, it stays on, and if i try to resume it (Alt+F1) it does, but the fans run loud and a few things don’t work until a reboot, like nm
this is the relevant output from the journal
#journalctl -b
set 26 13:32:30 laptop-len systemd-logind[813]: The system will suspend now!
set 26 13:32:30 laptop-len NetworkManager[922]: [1758886350.6937] manager: sleep: sleep requested (sleeping: no enabled: yes)
set 26 13:32:30 laptop-len NetworkManager[922]: [1758886350.6938] device (wlan0): state change: disconnected → unmanaged (reason ‘unmanaged-sleeping’, managed-type: ‘full’)
set 26 13:32:30 laptop-len dbus-broker[806]: A security policy denied :1.39 to send method call /org/freedesktop/login1/seat/seat0:org.freedesktop.login1.Seat.Inhibit to org.freedesktop.login1.
set 26 13:32:30 laptop-len kwin_wayland[1151]: kwin_core: Failed to delay sleep: Sender is not authorized to send message
set 26 13:32:30 laptop-len NetworkManager[922]: [1758886350.7012] device (wlan0): set-hw-addr: reset MAC address to 74:E5:F9:63:C7:BB (unmanage)
set 26 13:32:30 laptop-len wpa_supplicant[932]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
set 26 13:32:30 laptop-len wpa_supplicant[932]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
set 26 13:32:30 laptop-len NetworkManager[922]: [1758886350.7050] device (p2p-dev-wlan0): state change: disconnected → unmanaged (reason ‘unmanaged-sleeping’, managed-type: ‘full’)
set 26 13:32:30 laptop-len NetworkManager[922]: [1758886350.7052] device (88:52:EB:2A:02:61): state change: disconnected → unmanaged (reason ‘unmanaged-sleeping’, managed-type: ‘full’)
set 26 13:32:30 laptop-len NetworkManager[922]: [1758886350.7053] manager: NetworkManager state is now ASLEEP
set 26 13:32:30 laptop-len wpa_supplicant[932]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
set 26 13:32:30 laptop-len firefox[1645]: [ERROR glean_core::metrics::ping] Invalid reason code idchange for ping sync
set 26 13:32:30 laptop-len wpa_supplicant[932]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
set 26 13:32:31 laptop-len systemd[1]: Reached target Sleep.
set 26 13:32:31 laptop-len systemd[1]: Starting NVIDIA system suspend actions…
set 26 13:32:31 laptop-len suspend[6652]: nvidia-suspend.service
set 26 13:32:31 laptop-len logger[6652]: <13>Sep 26 13:32:31 suspend: nvidia-suspend.service
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSource/ldac
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSink/aptx_hd
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSource/aptx_hd
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSink/aac
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSource/aac
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSink/opus_g
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSource/opus_g
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSink/sbc
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSource/sbc
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSource/aptx_ll_1
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSource/aptx_ll_0
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSource/faststream
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSource/faststream_duplex
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSink/opus_05
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSource/opus_05
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSink/opus_05_duplex
set 26 13:32:32 laptop-len bluetoothd[809]: Endpoint unregistered: sender=:1.123 path=/MediaEndpoint/A2DPSource/opus_05_duplex
set 26 13:32:32 laptop-len kernel: BUG: kernel NULL pointer dereference, address: 0000000000000000
set 26 13:32:32 laptop-len kernel: #PF: supervisor read access in kernel mode
set 26 13:32:32 laptop-len kernel: #PF: error_code(0x0000) - not-present page
set 26 13:32:32 laptop-len systemd[1]: nvidia-suspend.service: Main process exited, code=killed, status=9/KILL
set 26 13:32:32 laptop-len kernel: PGD 0 P4D 0
set 26 13:32:32 laptop-len systemd[1]: nvidia-suspend.service: Failed with result ‘signal’.
set 26 13:32:32 laptop-len kernel: Oops: Oops: 0000 [#1] SMP PTI
set 26 13:32:32 laptop-len systemd[1]: Failed to start NVIDIA system suspend actions.
set 26 13:32:32 laptop-len kernel: CPU: 7 UID: 0 PID: 6661 Comm: nvidia-sleep.sh Tainted: P OE 6.16.8-arch3-1 #1 PREEMPT(full) c3805c1210d56bc7a68d560dd9e968bb1cc9c38e
set 26 13:32:32 laptop-len systemd[1]: Starting System Suspend…
set 26 13:32:32 laptop-len kernel: Tainted: [P]=PROPRIETARY_MODULE, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
set 26 13:32:32 laptop-len kded6[1293]: org.kde.pulseaudio: No object for name “alsa_input.pci-0000_00_1f.3.analog-stereo”
set 26 13:32:32 laptop-len kernel: Hardware name: LENOVO 20HJS0Y703/20HJS0Y703, BIOS N1UET91W (1.65 ) 07/30/2024
set 26 13:32:32 laptop-len plasmashell[1348]: org.kde.pulseaudio: No object for name “alsa_input.pci-0000_00_1f.3.analog-stereo”
set 26 13:32:32 laptop-len kernel: RIP: 0010:_raw_q_schedule+0x2b/0xa0 [nvidia_uvm]
set 26 13:32:32 laptop-len plasmashell[1348]: qrc:/qt/qml/plasma/applet/org/kde/plasma/volume/main.qml :100: TypeError: Cannot read property ‘description’ of undefined
set 26 13:32:32 laptop-len kernel: Code: 1f 44 00 00 41 54 55 48 89 fd 48 83 c7 10 53 48 89 f3 48 83 ec 08 e8 44 bf 2c e2 48 89 c1 48 8b 03 48 39 c3 75 54 48 8b 75 08 <48> 3b 2e 0f 85 11 69 0e 00 48 39 f3 0f 84 08 69 0e 00 48 39 eb 0f
set 26 13:32:32 laptop-len kded6[1293]: org.kde.pulseaudio: No object for name “alsa_output.pci-0000_00_1f.3.analog-stereo”
set 26 13:32:32 laptop-len kernel: RSP: 0018:ffffcd3d449e3918 EFLAGS: 00010046
set 26 13:32:32 laptop-len kernel: RAX: ffffcd3d449e3940 RBX: ffffcd3d449e3940 RCX: 0000000000000296
set 26 13:32:32 laptop-len kded6[1293]: org.kde.pulseaudio: No object fo@DEFAULT_SINK name “@DEFAULT_SINK@”
set 26 13:32:32 laptop-len kernel: RDX: 0000000000000001 RSI: 0000000000000000 RDI: ffffcd3d434a02f8
set 26 13:32:32 laptop-len kded6[1293]: org.kde.pulseaudio: No object fo@DEFAULT_SOURCE name “@DEFAULT_SOURCE@”
set 26 13:32:32 laptop-len kernel: RBP: ffffcd3d434a02e8 R08: ffffffffc73de3c0 R09: 0000000000000001
set 26 13:32:32 laptop-len plasmashell[1348]: org.kde.pulseaudio: No object for name “alsa_output.pci-0000_00_1f.3.analog-stereo”
set 26 13:32:32 laptop-len kernel: R10: ffff8a65b8729b80 R11: 0000000000000000 R12: ffffcd3d434a02e8
set 26 13:32:32 laptop-len kernel: R13: ffffcd3d449e3968 R14: ffffcd3d449e3978 R15: ffff8a65428a8698
set 26 13:32:32 laptop-len kernel: FS: 00007f9b7fa9eb80(0000) GS:ffff8a6cda0da000(0000) knlGS:0000000000000000
set 26 13:32:32 laptop-len plasmashell[1348]: org.kde.pulseaudio: No object fo@DEFAULT_SINK name “@DEFAULT_SINK@”
set 26 13:32:32 laptop-len kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
set 26 13:32:32 laptop-len plasmashell[1348]: org.kde.pulseaudio: No object fo@DEFAULT_SOURCE name “@DEFAULT_SOURCE@”
set 26 13:32:32 laptop-len kernel: CR2: 0000000000000000 CR3: 000000029d63c005 CR4: 00000000003706f0
set 26 13:32:32 laptop-len kernel: Call Trace:
set 26 13:32:32 laptop-len kernel: nv_kthread_q_flush+0x7f/0x140 [nvidia_uvm 2812daaa9ffdfff4b3d4d0f85da3b0030ce6adc2]
set 26 13:32:32 laptop-len kernel: ? __pfx__q_flush_function+0x10/0x10 [nvidia_uvm 2812daaa9ffdfff4b3d4d0f85da3b0030ce6adc2]
set 26 13:32:32 laptop-len systemd-sleep[6692]: User sessions remain unfrozen on explicit request ($SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=0).
set 26 13:32:32 laptop-len kernel: ? thread_context_current+0x75/0x140 [nvidia_uvm 2812daaa9ffdfff4b3d4d0f85da3b0030ce6adc2]
set 26 13:32:32 laptop-len systemd-sleep[6692]: This is not recommended, and might result in unexpected behavior, particularly
set 26 13:32:32 laptop-len kernel: uvm_suspend.isra.0+0x92/0x190 [nvidia_uvm 2812daaa9ffdfff4b3d4d0f85da3b0030ce6adc2]
set 26 13:32:32 laptop-len systemd-sleep[6692]: in suspend-then-hibernate operations or setups with encrypted home directories.
set 26 13:32:32 laptop-len kernel: uvm_suspend_entry+0x7e/0xa0 [nvidia_uvm 2812daaa9ffdfff4b3d4d0f85da3b0030ce6adc2]
set 26 13:32:32 laptop-len systemd-sleep[6692]: Performing sleep operation ‘suspend’…
set 26 13:32:32 laptop-len kernel: nv_uvm_suspend+0x2e/0x50 [nvidia d2d76e749c7dcbf377112d5c5b2f2fe77e23292d]
set 26 13:32:32 laptop-len kernel: nv_set_system_power_state+0x418/0x4d0 [nvidia d2d76e749c7dcbf377112d5c5b2f2fe77e23292d]
set 26 13:32:32 laptop-len kernel: nv_procfs_write_suspend+0xee/0x170 [nvidia d2d76e749c7dcbf377112d5c5b2f2fe77e23292d]
set 26 13:32:32 laptop-len kernel: proc_reg_write+0x57/0xb0
set 26 13:32:32 laptop-len kernel: vfs_write+0xcb/0x480
set 26 13:32:32 laptop-len kernel: ? __do_sys_newfstat+0x44/0x70
set 26 13:32:32 laptop-len kernel: ksys_write+0x73/0xf0
set 26 13:32:32 laptop-len kernel: do_syscall_64+0x81/0x970
set 26 13:32:32 laptop-len kernel: ? do_syscall_64+0x81/0x970
set 26 13:32:32 laptop-len kernel: ? do_filp_open+0xd8/0x180
set 26 13:32:32 laptop-len kernel: ? alloc_fd+0x12e/0x190
set 26 13:32:32 laptop-len kernel: ? filp_flush+0x61/0xa0
set 26 13:32:32 laptop-len kernel: ? filp_close+0x25/0x40
set 26 13:32:32 laptop-len kernel: ? do_dup2+0xae/0x160
set 26 13:32:32 laptop-len kernel: ? ksys_dup3+0x67/0xf0
set 26 13:32:32 laptop-len kernel: ? __x64_sys_dup2+0x24/0xf0
set 26 13:32:32 laptop-len kernel: ? exc_page_fault+0x7e/0x1a0
set 26 13:32:32 laptop-len kernel: entry_SYSCALL_64_after_hwframe+0x76/0x7e
set 26 13:32:32 laptop-len kernel: RIP: 0033:0x7f9b7f8931ce
set 26 13:32:32 laptop-len kernel: Code: 4d 89 d8 e8 64 be 00 00 4c 8b 5d f8 41 8b 93 08 03 00 00 59 5e 48 83 f8 fc 74 11 c9 c3 0f 1f 80 00 00 00 00 48 8b 45 10 0f 05 c3 83 e2 39 83 fa 08 75 e7 e8 13 ff ff ff 0f 1f 00 f3 0f 1e fa
set 26 13:32:32 laptop-len kernel: RSP: 002b:00007ffebc540210 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
set 26 13:32:32 laptop-len kernel: RAX: ffffffffffffffda RBX: 00007f9b7fa0a5c0 RCX: 00007f9b7f8931ce
set 26 13:32:32 laptop-len kernel: RDX: 0000000000000008 RSI: 000055806b65a7c0 RDI: 0000000000000001
set 26 13:32:32 laptop-len kernel: RBP: 00007ffebc540220 R08: 0000000000000000 R09: 0000000000000000
set 26 13:32:32 laptop-len kernel: R10: 0000000000000000 R11: 0000000000000202 R12: 0000000000000008
set 26 13:32:32 laptop-len kernel: R13: 0000000000000008 R14: 000055806b65a7c0 R15: 000055806b659360
set 26 13:32:32 laptop-len kernel: Modules linked in: uhid ccm rfcomm nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nft_ct nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nf_tables cmac algif_hash algif_skcipher af_alg bnep dm_crypt encrypted_keys trusted asn1_encoder tee snd_hda_codec_realtek snd_hda_codec_generic snd_hda_scodec_component intel_rapl_msr intel_rapl_common intel_uncore_frequency intel_uncore_frequency_common intel_pmc_core_pltdrv intel_pmc_core pmt_telemetry pmt_class intel_pmc_ssram_telemetry snd_soc_avs intel_vsec snd_soc_hda_codec intel_tcc_cooling snd_hda_ext_core x86_pkg_temp_thermal intel_powerclamp snd_soc_core iwlmvm coretemp iTCO_wdt snd_compress vfat intel_pmc_bxt ac97_bus ee1004 mei_hdcp mei_pxp mei_wdt iTCO_vendor_support snd_hda_codec_hdmi snd_pcm_dmaengine fat mac80211 uvcvideo videobuf2_vmalloc kvm_intel uvc libarc4 videobuf2_memops i915 snd_hda_intel videobuf2_v4l2 btusb videobuf2_common btrtl snd_intel_dspcfg btintel snd_intel_sdw_acpi
set 26 13:32:32 laptop-len kernel: rapl btbcm videodev intel_cstate snd_hda_codec btmtk e1000e iwlwifi think_lmi snd_ctl_led i2c_i801 mc snd_hda_core bluetooth ptp drm_buddy intel_uncore intel_wmi_thunderbolt pcspkr firmware_attributes_class wmi_bmof mei_me i2c_algo_bit i2c_smbus snd_hwdep cfg80211 pps_core thinkpad_acpi i2c_mux drm_display_helper mei snd_pcm platform_profile cec sparse_keymap intel_gtt snd_timer rfkill intel_pch_thermal snd soundcore acpi_pad joydev mousedev mac_hid loop nfnetlink ip_tables x_tables vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) kvm irqbypass pkcs8_key_parser nvidia_drm(POE) nvidia_uvm(POE) nvidia_modeset(POE) rtsx_pci_sdmmc mmc_core nvme polyval_clmulni ghash_clmulni_intel intel_lpss_pci nvme_core sha512_ssse3 drm_ttm_helper intel_lpss sha1_ssse3 nvme_keyring rtsx_pci aesni_intel idma64 psmouse ttm nvme_auth video i2c_hid_acpi intel_oc_wdt i2c_hid wmi pinctrl_sunrisepoint serio_raw nvidia(POE) dm_mirror dm_region_hash dm_log dm_mod i2c_dev crypto_user acpi_call(OE)
set 26 13:32:32 laptop-len kernel: Unloaded tainted modules: thinkpad_ec(OE):5
set 26 13:32:32 laptop-len kernel: —[ end trace 0000000000000000 ]—
set 26 13:32:32 laptop-len kernel: note: nvidia-sleep.sh[6661] exited with irqs disabled
set 26 13:32:32 laptop-len kernel: note: nvidia-sleep.sh[6661] exited with preempt_count 1
set 26 13:32:32 laptop-len kernel: PM: suspend entry (deep)
set 26 13:32:32 laptop-len kernel: Filesystems sync: 0.010 seconds
set 26 13:32:32 laptop-len kwin_wayland_wrapper[1240]: Key repeat discarded, Wayland compositor doesn’t seem to be processing events fast enough!
set 26 13:32:32 laptop-len kded6[1293]: org.kde.pulseaudio: No object for name “auto_null.monitor”
set 26 13:32:32 laptop-len plasmashell[1348]: org.kde.pulseaudio: No object for name “auto_null.monitor”
set 26 13:32:32 laptop-len kwin_wayland[1151]: kwin_core: Failed to open drm node: “/dev/dri/card1”
set 26 13:32:33 laptop-len kernel: Freezing user space processes
set 26 13:32:33 laptop-len kernel: Freezing user space processes completed (elapsed 0.002 seconds)
set 26 13:32:33 laptop-len kernel: OOM killer disabled.
set 26 13:32:33 laptop-len kernel: Freezing remaining freezable tasks
set 26 13:32:33 laptop-len kernel: Freezing remaining freezable tasks completed (elapsed 0.000 seconds)
set 26 13:32:33 laptop-len kernel: printk: Suspending console(s) (use no_console_suspend to debug)
set 26 13:32:33 laptop-len kernel: e1000e: EEE TX LPI TIMER: 00000011
set 26 13:32:33 laptop-len kernel: NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set. System Power Management attempted without driver procfs suspend interface. Please refer to the ‘Configuring Power Management Support’ section in the driver README.
set 26 13:32:33 laptop-len kernel: nvidia 0000:01:00.0: PM: pci_pm_suspend(): nv_pmops_suspend [nvidia] returns -5
set 26 13:32:33 laptop-len kernel: nvidia 0000:01:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -5
set 26 13:32:33 laptop-len kernel: nvidia 0000:01:00.0: PM: failed to suspend async: error -5
set 26 13:32:33 laptop-len kernel: PM: Some devices failed to suspend, or early wake event detected
set 26 13:32:33 laptop-len kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
set 26 13:32:33 laptop-len kernel: OOM killer enabled.
set 26 13:32:33 laptop-len kernel: Restarting tasks: Starting
set 26 13:32:33 laptop-len kernel: Restarting tasks: Done
set 26 13:32:33 laptop-len kernel: random: crng reseeded on system resumption
set 26 13:32:33 laptop-len bluetoothd[809]: Controller resume with wake event 0x0
set 26 13:32:33 laptop-len kernel: PM: suspend exit
set 26 13:32:33 laptop-len kernel: PM: suspend entry (s2idle)
set 26 13:32:33 laptop-len kernel: Filesystems sync: 0.006 seconds
set 26 13:32:34 laptop-len kernel: Freezing user space processes
set 26 13:32:34 laptop-len kernel: Freezing user space processes completed (elapsed 0.001 seconds)
set 26 13:32:34 laptop-len kernel: OOM killer disabled.
set 26 13:32:34 laptop-len kernel: Freezing remaining freezable tasks
set 26 13:32:34 laptop-len kernel: Freezing remaining freezable tasks completed (elapsed 0.002 seconds)
set 26 13:32:34 laptop-len kernel: printk: Suspending console(s) (use no_console_suspend to debug)
set 26 13:32:34 laptop-len kernel: e1000e: EEE TX LPI TIMER: 00000011
set 26 13:32:34 laptop-len kernel: NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set. System Power Management attempted without driver procfs suspend interface. Please refer to the ‘Configuring Power Management Support’ section in the driver README.
set 26 13:32:34 laptop-len kernel: nvidia 0000:01:00.0: PM: pci_pm_suspend(): nv_pmops_suspend [nvidia] returns -5
set 26 13:32:34 laptop-len kernel: nvidia 0000:01:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -5
set 26 13:32:34 laptop-len kernel: nvidia 0000:01:00.0: PM: failed to suspend async: error -5
set 26 13:32:34 laptop-len kernel: PM: Some devices failed to suspend, or early wake event detected
set 26 13:32:34 laptop-len kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
set 26 13:32:34 laptop-len kernel: OOM killer enabled.
set 26 13:32:34 laptop-len kernel: Restarting tasks: Starting
set 26 13:32:34 laptop-len kernel: Restarting tasks: Done
set 26 13:32:34 laptop-len kernel: random: crng reseeded on system resumption
set 26 13:32:34 laptop-len bluetoothd[809]: Controller resume with wake event 0x0
set 26 13:32:34 laptop-len systemd-sleep[6692]: Failed to put system to sleep. System resumed again: Input/output error
set 26 13:32:34 laptop-len kernel: PM: suspend exit
set 26 13:32:50 laptop-len kwin_wayland[1151]: kwin_core: Failed to open /dev/dri/card1 device (Device or resource busy)
set 26 13:32:50 laptop-len kwin_wayland[1151]: kwin_wayland_drm: failed to open drm device at “/dev/dri/card1”
set 26 13:32:50 laptop-len wireplumber[1077]: spa.bluez5.midi: org.bluez.GattManager1.RegisterApplication() failed: GDBus.Error:org.bluez.Error.AlreadyExists: Already Exists
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSource/ldac
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSink/aptx_hd
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSource/aptx_hd
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSink/aac
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSource/aac
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSink/opus_g
set 26 13:32:50 laptop-len kded6[1293]: org.kde.pulseaudio: No object for name “auto_null”
set 26 13:32:50 laptop-len kded6[1293]: org.kde.pulseaudio: No object for name “auto_null.monitor”
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSource/opus_g
set 26 13:32:50 laptop-len plasmashell[1348]: org.kde.pulseaudio: No object for name “auto_null”
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSink/sbc
set 26 13:32:50 laptop-len plasmashell[1348]: org.kde.pulseaudio: No object for name “auto_null.monitor”
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSource/sbc
set 26 13:32:50 laptop-len kded6[1293]: org.kde.pulseaudio: No object fo@DEFAULT_SINK name “@DEFAULT_SINK@”
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSource/aptx_ll_1
set 26 13:32:50 laptop-len kded6[1293]: org.kde.pulseaudio: No object fo@DEFAULT_SOURCE name “@DEFAULT_SOURCE@”
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSource/aptx_ll_0
set 26 13:32:50 laptop-len plasmashell[1348]: org.kde.pulseaudio: No object fo@DEFAULT_SINK name “@DEFAULT_SINK@”
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
set 26 13:32:50 laptop-len plasmashell[1348]: org.kde.pulseaudio: No object fo@DEFAULT_SOURCE name “@DEFAULT_SOURCE@”
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSource/faststream
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSource/faststream_duplex
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSink/opus_05
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSource/opus_05
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSink/opus_05_duplex
set 26 13:32:50 laptop-len bluetoothd[809]: Endpoint registered: sender=:1.129 path=/MediaEndpoint/A2DPSource/opus_05_duplex
set 26 13:32:50 laptop-len kded6[1293]: org.kde.pulseaudio: No object for name “alsa_input.pci-0000_00_1f.3.analog-stereo”
set 26 13:32:50 laptop-len plasmashell[1348]: org.kde.pulseaudio: No object for name “alsa_input.pci-0000_00_1f.3.analog-stereo”
set 26 13:32:50 laptop-len systemd[1036]: eos-update-notifier.service: Main process exited, code=exited, status=1/FAILURE
set 26 13:32:50 laptop-len systemd[1036]: eos-update-notifier.service: Failed with result ‘exit-code’.
set 26 13:32:50 laptop-len systemd[1036]: Failed to start EOS update notifier service.
set 26 13:32:50 laptop-len systemd[1036]: eos-update-notifier.service: Consumed 4.818s CPU time, 5.3M memory peak.
set 26 13:32:53 laptop-len kwin_wayland_wrapper[6624]: warning: queue “mesa egl surface queue” 0x7eff84ef3480 destroyed while proxies still attached:
set 26 13:32:53 laptop-len kwin_wayland_wrapper[6624]: wp_presentation#37 still attached
set 26 13:32:53 laptop-len kscreenlocker_greet[6624]: qt.qpa.wayland: Could not create EGL surface (EGL error 0x3000)
set 26 13:32:53 laptop-len kscreenlocker_greet[6624]: Failed to write to the pipe: Descrittore di file errato.
set 26 13:32:55 laptop-len systemd[1036]: Started Konsole - Terminale.
set 26 13:32:55 laptop-len systemd[1036]: Started app-org.kde.konsole-7116.scope.
set 26 13:33:09 laptop-len blender[6310]: Terminato __NV_PRIME_RENDER_OFFLOAD=1 __VK_LAYER_NV_optimus=NVIDIA_only __GLX_VENDOR_LIBRARY_NAME=nvidia “$@”
set 26 13:33:17 laptop-len sudo[7262]: disgrace : TTY=pts/0 ; PWD=/home/disgrace ; USER=root ; COMMAND=/usr/bin/journalctl -b
set 26 13:33:17 laptop-len sudo[7262]: pam_unix(sudo:session): session opened for user root(uid=0) by disgrace(uid=1000)
set 26 13:33:18 laptop-len kernel: input: HP Travel Mouse as /devices/virtual/misc/uhid/0005:03F0:504A.0004/input/input28
set 26 13:33:18 laptop-len kernel: input: HP Travel Mouse Keyboard as /devices/virtual/misc/uhid/0005:03F0:504A.0004/input/input29
set 26 13:33:18 laptop-len kernel: input: HP Travel Mouse as /devices/virtual/misc/uhid/0005:03F0:504A.0004/input/input30
set 26 13:33:18 laptop-len kernel: hid-generic 0005:03F0:504A.0004: input,hidraw1: BLUETOOTH HID v1.10 Mouse [HP Travel Mouse] on 74:e5:f9:63:c7:bf
I checked if NVreg_PreserveVideoMemoryAllocations and NVreg_TemporaryFilePath were set correctly, as suggested in other similar posts, and they are. Here is the modproble conf
/lib/modprobe.d/nvidia-sleep.conf
# ``https://download.nvidia.com/XFree86/Linux-x86_64/560.35.03/README/powermanagement.html#PreserveAllVide719f0``
# Save and restore all video memory allocations.
options nvidia NVreg_PreserveVideoMemoryAllocations=1
# The destination should not be using tmpfs, so we prefer
# /var/tmp instead of /tmp
options nvidia NVreg_TemporaryFilePath=/var/tmp
And here is the GPU setup
lspci -nn | grep '\\\[03\[02\]'
00:02.0 VGA compatible controller [0300]: Intel Corporation HD Graphics 630 [8086:591b] (rev 04)
01:00.0 3D controller [0302]: NVIDIA Corporation GM206GLM [Quadro M2200 Mobile] [10de:1436] (rev a1)
Does anybody have any insight on this?
I can’t really figure it out
Nvidia recommends driver package nvidia-open or nvidia-open-dkms for that card.
I’m not sure if that helps, but worth a try if you haven’t done so.
Other than that, I think those additional settings are not necessary, so removing them is worth a shot too.
I can’t run on nvidia-open since I make extensive use of blender and it works best with the proprietary drivers.
Actually installing the open drivers kinda messed with the blender installation
Any other ideas to troubleshoot/fix this? I guess it has to do with power management, but wouldn’t really know what to change to improve or fix the problem
