Surface pro - very impressed
Picked up a used Surface Pro7 for just shy of £250 on eBay, very impressed, wiped and installed Plasma, pretty much everything works out of the box. It is very HiRes, with an odd 3:2 screen resolution, so the systemd boot menu is really small, tried a couple of things on here, but it made no difference :frowning: Oh and the touchpad is a bit odd (jumpy or not moving at all) when charging off the usb c port, but OK other than that.
It is light, small and fits in my bag, going to pick up a case, but thats all I need.
In case you haven’t done so already, you might want to install the custom linux-surface kernel:
Depending on you model this might solve some smaller issues :+1:
