Stuttering when using most media
Complete noob here, I am just clueless on where to start to look for a fix
Basicly my system stutters often when playing youtube videos, listening to spotify music and gaming. None of this tasks are hardcore for my system.
inxi -Fxxc0z | eos-sendlog general system specs and info
inxi -Gaz hardware info on GPU and used drivers
To start with we need some info about your setup and hardware.
Most issues are caused by faulty setup.
Summary
  Kernel: 6.11.6-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 dm: LightDM
  Type: Desktop System: Hewlett-Packard product: HP Compaq Elite 8300 CMT
    v: N/A serial: <superuser required> Chassis: type: 3
  Mobo: Hewlett-Packard model: 3396 serial: <superuser required>
    part-nu: QV993AV UEFI: Hewlett-Packard v: K01 v03.08 date: 04/10/2019
  Info: quad core model: Intel Xeon E3-1245 V2 bits: 64 type: MT MCP
    arch: Ivy Bridge rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
  Speed (MHz): avg: 3614 min/max: 1600/3800 cores: 1: 3614 2: 3614 3: 3614
    4: 3614 5: 3614 6: 3614 7: 3614 8: 3614 bogomips: 54298
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Micro-Star MSI
    driver: nvidia v: 565.57.01 arch: Turing pcie: speed: 2.5 GT/s lanes: 16
    ports: active: none off: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0
    chip-ID: 10de:1f82
  Display: x11 server: X.Org v: 21.1.14 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
    gpu: nvidia,nvidia-nvswitch display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96
  Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,right
    model: HP E232 res: 1920x1080 dpi: 96 diag: 584mm (23")
  Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: left model: HP E232
  API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 2 drv: swrast
    gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 565.57.01
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1e20
  Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
    pcie: speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
  Device-3: SAVITECH SA9023 audio controller
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 bus-ID: 1-1.5:5 chip-ID: 262a:9023
  Device-4: C-Media TONOR TC-777 Audio Device
    lanes: 1 bus-ID: 3-4:4 chip-ID: 0d8c:0134
  API: ALSA v: k6.11.6-arch1-1 status: kernel-api
  Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin
  Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
    driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502
  IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie:
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723
Bluetooth:
  Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 bus-ID: 2-1.6:3 chip-ID: 8087:0029
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
    lmp-v: 11
  Local Storage: total: 5.92 TiB used: 182.77 GiB (3.0%)
  ID-1: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
    speed: 6.0 Gb/s serial: <filter>
  ID-2: /dev/sdb vendor: Kingston model: SA400S37240G size: 223.57 GiB
  ID-3: /dev/sdc vendor: Seagate model: ST2000VN000-1HJ164 size: 1.82 TiB
    speed: 3.0 Gb/s serial: <filter>
  ID-4: /dev/sdd vendor: Western Digital model: WD20EZBX-00AYRA0
    size: 1.82 TiB speed: 3.0 Gb/s serial: <filter>
  ID-5: /dev/sde vendor: SanDisk model: SanDisk 3.2 Gen1 size: 233.13 GiB
    type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 serial: <filter>
  ID-6: /dev/sdf vendor: Dogfish Technology model: Sharkoon Flexi-Drive EC1
    size: 15.5 GiB type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 serial: <filter>
  ID-1: / size: 218.71 GiB used: 182.77 GiB (83.6%) fs: ext4 dev: /dev/sdb2
  ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
    dev: /dev/sdb1
  System Temperatures: cpu: 40.0 C mobo: N/A gpu: nvidia temp: 28 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 35%
  Memory: total: 16 GiB available: 15.57 GiB used: 2.79 GiB (17.9%)
  Processes: 272 Power: uptime: 7m wakeups: 0 Init: systemd v: 256
    default: graphical
  Packages: 1412 pm: pacman pkgs: 1393 pm: flatpak pkgs: 19 Compilers:
    gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.36
Summary
    driver: nvidia v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
    off: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0 chip-ID: 10de:1f82
    class-ID: 0300
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
    s-diag: 1055mm (41.55")
    model: HP E232 serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 96
    gamma: 1.2 size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9
    modes: max: 1920x1080 min: 640x480
    serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
    size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    memory: 3.91 GiB
This looks all fine… nvidia drivers are used and it renders correctly on the Nvidia GPU.
You installed using nvidia boot option i bet? or installed nvidia drivers manually after initial install?
is there a newer Bios version available?
https://support.hp.com/de-de/drivers/hp-compaq-elite-8300-convertible-minitower-pc/model/5232846?sku=QV993AV
does glances in a terminal showing any high loads?
At boot
I did upgrade to the latest 3-4 years ago, I doubt theres any newer
Nope, barely, I have to test at a time when the system starts freezing though.
journal can show also issues could be some service or app goes nuts…
journalctl -f would live output kernel messages…
also boot journal could show something:
journalctl -k -b -0 | eos-sendlog but if you want me to look on this send me the resulting url in a p.m. not posting public… it can include personal serials or uuids and stuff…
