Hi,
i know arch-linux, because in the past i installed and configured my system with arch. In arch, the steps from installation to the Gnome/KDE/whatever UI are described.
Because i like to have a more-ready system after installation, i tried endeavourOS. At first, i have started installation, online-installation with gnome-shell. It ended with a terminal, without start of gnome-shell… but i could start the X-Envorionment with “startx”.
May be i’m a little bit stupid… but i don’t know, were i am; if i would be installed archlinux, it tells me, you’re at the step after installing xwindows and have to configure the gdm or whatever… i took a look in the endeavourOS Wiki but didn’t found anything what to do…
So i tried the endeavourOS Offline Installation with XFCE and all went very fine…
So my answer is… it’s right that Online-Installation end with terminal with gdm / or any Manager for Login in KDE / Gnome or i have made a failure and the online installation have to end with Gnome/KDE/Deepin Display?
Thank you very much…
Wolfgang
