Stuck on grub rescue after timeshift restore
Hello, this is my first post here
Did a system restore earlier today using timeshift and it booted my into grub rescue
booted into a live usb version of EndeavourOS and followed the guide here:
https://discovery.endeavouros.com/system-rescue/repair-a-non-booting-grub/2021/03/
tried several times but with no luck, everytime I reboot I still end up on grub rescue
output of fdisk -l:
Device Start End Sectors Size Type
/dev/nvme0n1p1 4096 618495 614400 300M EFI System
/dev/nvme0n1p2 618496 1953520064 1952901569 931.2G Linux filesystem
mounted with:
sudo mount /dev/nvme0n1p2 /mnt
sudo mount /dev/nvme0n1p1 /mnt/boot/efi
access arch-chroot and I run these as well:
grub-install --target=i386-pc /dev/nvme0n1
note after mounting I can see my files and folders in /boot/grub
Currently typing this from a live usb version
Any help is appreciated
That’s not quite right.
It should look more like the line below.
After arch-chroot:
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=EndeavourOS-grub
for a UEFI install.
So all the steps:
sudo arch-chroot /mnt
tried this way as well
returns this:
Installing for x86_64-efi platform.
Installation finished. No error reported.
but after reboot I return to grub rescue
output of grub-mkconfig -o /boot/grub/grub.cfg
Generating grub configuration file …
Found linux image: /boot/vmlinuz-linux
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot: amd-ucode.img initramfs-linux-fallback.img
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
Adding boot menu entry for UEFI Firmware Settings …
done
If the output of the fdisk -l shows the only disk in the system, try the following at the grub rescue prompt and see if you can get to boot up your system:
grub rescue> set prefix=(hd0,2)/boot/grub
grub rescue> set root=(hd0,2)
grub rescue> insmod normal
grub rescue> normal
grub rescue> insmod linux
grub rescue> linux /boot/vmlinuz-linux root=/dev/nvme0n1p2 rw
grub rescue> initrd /boot/initramfs-linux.img
grub rescue> boot
It shows my hdd at sda and the live usb and sdb
Please post the entire output of
sudo parted -l
and also:
efibootmgr -v
sudo parted -l
Model: ATA ST2000DM008-2UB1 (scsi)
Disk /dev/sda: 2000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 2000GB 2000GB ext4
Model: Generic Flash Disk (scsi)
Disk /dev/sdb: 8054MB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 1833MB 1940MB 107MB primary fat16 esp
Model: Samsung SSD 980 1TB (nvme)
Disk /dev/nvme0n1: 1000GB
Disk Flags:
1 2097kB 317MB 315MB fat32 boot, esp
2 317MB 1000GB 1000GB ext4 root
efibootmgr -v:
BootCurrent: 0004
Timeout: 1 seconds
BootOrder: 0004,0001,0000,0002,0003
Boot0000* endeavouros HD(1,GPT,fa557538-32ae-6348-95d3-35d1a47c1bed,0x1000,0x96000)/File(\EFI\ENDEAVOUROS\GRUBX64.EFI)
Boot0001* UEFI OS HD(1,GPT,fa557538-32ae-6348-95d3-35d1a47c1bed,0x1000,0x96000)/File(\EFI\BOOT\BOOTX64.EFI)…BO
Boot0002* EndeavourOS-grub HD(1,GPT,fa557538-32ae-6348-95d3-35d1a47c1bed,0x1000,0x96000)/File(\EFI\ENDEAVOUROS-GRUB\GRUBX64.EFI)
Boot0003* UEFI: Generic Flash Disk 8.07 PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/USB(6,0)/CDROM(1,0x369fc0,0x33298)…BO
Boot0004* UEFI: Generic Flash Disk 8.07, Partition 2 PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/USB(6,0)/HD(2,MBR,0xab3ab792,0x369fc0,0x33000)…BO
Like I said these are outputs from the live usb
We could try to set Boot0002 first in order and see if the system will boot up:
In the live session (no chroot needed)
sudo efibootmgr -o 0002,0004,0001,0000,0003
If that would not work, try the following at grub rescue prompt:
grub rescue> set prefix=(hd1,2)/boot/grub
grub rescue> set root=(hd1,2)
grub rescue> normal
grub rescue> boot
Edit:
Perhaps
should be:
grub rescue> initrd /boot/amd-ucode.img /boot/initramfs-linux.img
The syntax for partitions is different. For MBR it is (hdX,msdosY), for GPT it is (hdX,gptY)
IMG_20220805_221610
Tried it but still no luck
This is what the grub rescue looks like
Try replacing (hd1,2) with (hd1,gpt2) on both commands
Same output still not working
Is there a way to reinstall the os but keep/recover my files, gamesaves etc?
Or reinstall grub?
I would start in the live USB and first of all try to clean up some EFI boot entries.
Then we can build up the Grub environment from scratch.
Use the following pattern to remove EnOS’ boot entries (no chroot needed):
sudo efibootmgr -b nnnn -B ## replace nnnn with the actual boot number.
(They are: 0000, 0002)
Next do an arch-chroot:
Now we can rebuild the Grub environment:
 1. mv /etc/default/grub /etc/default/grub.old
 2. mv /etc/grub.d /etc/grub.d.old
 3. rm /boot/grub/grubenv
 4. grub-editenv /boot/grub/grubenv create
 5. pacman -S grub
 6. grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=EndeavourOS-new
 7. grub-mkconfig -o /boot/grub/grub.cfg
output of grub-mkconfig -o /boot/grub/grub.cfg:
after doing the above commands
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
done
sudo efibootmgr -v
BootCurrent: 0003
Timeout: 1 seconds
BootOrder: 0003,0001,0002
Boot0002* UEFI: Generic Flash Disk 8.07 PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/USB(5,0)/USB(3,0)/CDROM(1,0x369fc0,0x33298)…BO
Boot0003* UEFI: Generic Flash Disk 8.07, Partition 2 PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/USB(5,0)/USB(3,0)/HD(2,MBR,0xab3ab792,0x369fc0,0x33000)…BO
Still no success
End up in grub rescue after reboot
I am not seeing any EFI boot entry for EnOS ( bootloader-id=EndeavourOS-new) in the output of
efibootmgr -v
I don’t know why. My last suggestion would be to try installing the bootloader again with a couple of added options to see if it will work.
Do an arch-chroot as before and run the following
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=EnOS-Grub1 --force
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=EnOS-Grub2 --force --removable
When done, type exit to quit chroot. Open a terminal and check again with:
efibootmgr -v
to see if you get any boot entries with those bootloader id:s above.
If that won’t work, I’m afraid I am out of ideas.
output of efibootmgr -v:
after doing what you just mentioned
BootCurrent: 0003
Timeout: 1 seconds
BootOrder: 0004,0003,0001,0000,0002
Boot0000* EndeavourOS-new HD(1,GPT,fa557538-32ae-6348-95d3-35d1a47c1bed,0x1000,0x96000)/File(\EFI\ENDEAVOUROS-NEW\GRUBX64.EFI)
Boot0004* EnOS-Grub1 HD(1,GPT,fa557538-32ae-6348-95d3-35d1a47c1bed,0x1000,0x96000)/File(\EFI\EnOS-Grub1\grubx64.efi)
Looks like it got installed. Could you reboot now and see if this would work?
It worked! Im currently in my Operating system, thank you very much.
I will be sure to make a donation to EndeavourOS for having such a wonderful community and to show my gratitude.
