Hi,
I’m new to EndeavourOS. When I use the command "ip a " to have a look to the network adapters I see "enp4s0f1 "for the ethernet adapter (which is the standard convention name for eth adapters) but I see the generic “wlan0” for the wireless name adapter. This is (in my opinion) a little bit weird because this was the old name convention for wireless adapter. When I used other distributions the name for the wireless network adapter was something like “wl…”.
Is that normal?
Thank you very much in advance for your help and your patience.
Roberto
It seems to depend on the driver and how the device is connected. For example, I have a PCI-attached device and it’s listed as wlp7s0. Perhaps yours is USB-attached?
on mine it sees 2 adapters for the same connection, wlan0 and wlan1
Thank you for your replay.
No my device is an internal device. This strange phenomenon appears on all my 3 laptopos where I have installed EndeavourOS. They are three different machines. Before EndeavourOS on all the machines was installed Manjaro and the names of the devices where correct (wl…).
Any other idea?
Tank you,
Roberto
hello @porcaror and welcome to the community
That doesn’t mean it’s not USB-connected.
https://wiki.archlinux.org/index.php/Network_configuration#Revert_to_traditional_interface_names
Thank you for your reply.
So this behaviour is not only mine.
Before these I had Manjaro installed and the device names were appropriate.
I think it is weirs.
Thank you,
Roberto
You are right, but why did it work properly in Manjaro?
Thanks for the link, I will read it.
Roberto
In Manjaro my device was wlp2s0 , on EOS it’s wlan0. Ethernet being the same .
Off topic
Veracrypt mounted volumes on /mnt by default on Mj , but on EOS it’s mounted on /media
Exactly the same for me.
This is strange in my opinion.
