Hello there,
I will try my luck here in Forum, maybe someone can help me, here’s my issue:
GRUB is booting in blind mode after a clean install, GRUB file looks good, and it should work, but it doesn’t, if I ad the following line GRUB_TERMINAL=console I do get to see Grub but only in console mode.
In Grub, if I type c and videoinfo no adapters or resolution are shown.
The same happens to other Arch based distros like ArcoLinux.
I always run Gparted 1st and install after.
I thought it could be something related to HW issues and installed a Debian based distro, the GRUB works just like it should.
In Debian GRUB I get adapter info: EFI GOP Driver and possible resolutions.
Im OK using the console mode for now but would like to have it like it should, maybe someone of guys can help me to sort it out.
@ricklinux@DocLeo
I don’t have the answer, but your issue is not related to that one in the referred post. It is a fresh install, so it doesn’t have the old Grub-install issue.
Thank you, I am on Grub 2:2.06.r322.gd9b4638c5-4, came with fresh install.
Didnt made any changes to Grub except adding this line GRUB_TERMINAL=console and sudo grub-mkconfig -o /boot/grub/grub.cfg, this way i’m able to see grub when booting.
No, I said that this particular issue isn’t related to the known Grub issue, since it is a fresh install.
The post unpinned itself, there was a time limit to be pinned on that particular post.
