➜ ~ yay -Q | grep -E 'mesa|vlk|vulkan'
amdvlk 2024.Q2.1-1
lib32-amdvlk 2024.Q2.1-1
lib32-mesa 1:24.1.2-1
lib32-vulkan-icd-loader 1.3.279-1
mesa 1:24.1.2-1
mesa-utils 9.0.0-4
vulkan-headers 1:1.3.285-1
vulkan-icd-loader 1.3.285-1
vulkan-tools 1.3.269-1
➜ ~ VK_ICD_FILENAMES=/usr/share/vulkan/icd.d/nvidia_icd.json:/usr/share/vulkan/icd.d/nvidia_icd.json steam
steam.sh[37839]: Running Steam on endeavouros rolling 64-bit
steam.sh[37839]: STEAM_RUNTIME is enabled automatically
setup.sh[37904]: Steam runtime environment up-to-date!
steam.sh[37839]: Steam client's requirements are satisfied
Steam is already running, exiting (command line was forwarded).
➜ ~ WINEDLLOVERRIDES="xaudio2_7=n,b" PULSE_LATENCY_MSEC=90 %command%
fg: job not found: command%
steam.sh[38509]: Running Steam on endeavouros rolling 64-bit
steam.sh[38509]: STEAM_RUNTIME is enabled automatically
setup.sh[38576]: Steam runtime environment up-to-date!
steam.sh[38509]: Steam client's requirements are satisfied
[2024-10-02 02:20:12] Startup - updater built Sep 17 2024 20:02:19
[2024-10-02 02:20:12] Startup - Steam Client launched with: '/home/fj/.local/share/Steam/ubuntu12_32/steam' '-srt-l
ogger-opened'
10/02 02:20:12 minidumps folder is set to /tmp/dumps
10/02 02:20:12 Init: Installing breakpad exception handler for appid(steam)/version(1726604483)/tid(38635)
[2024-10-02 02:20:12] Loading cached metrics from disk (/home/fj/.local/share/Steam/package/steam_client_metrics.bi
n)
[2024-10-02 02:20:12] Using the following download hosts for Public, Realm steamglobal
[2024-10-02 02:20:12] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, sou
rce = 'update_hosts_cached.vdf'
[2024-10-02 02:20:12] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, sourc
[2024-10-02 02:20:12] 3. https://client-update.steamstatic.com, /, Realm 'steamglobal', weight was 1, source = 'bak
ed in'
[2024-10-02 02:20:12] Verifying installation...
[2024-10-02 02:20:12] Verification complete
UpdateUI: skip show logo
Steam logging initialized: directory: /home/fj/.local/share/Steam/logs
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xe05a1dc0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xe05a0500
steamwebhelper.sh[38668]: Using supervisor /home/fj/.local/share/Steam/ubuntu12_32/steam-runtime/amd64/usr/bin/stea
m-runtime-supervisor
steamwebhelper.sh[38668]: Starting steamwebhelper under bootstrap sniper steam runtime via /home/fj/.local/share/St
eam/ubuntu12_64/steam-runtime-sniper.sh
steamwebhelper.sh[38668]: Using CEF sandbox \(try with -no-cef-sandbox if this fails\)
steamwebhelper.sh[38668]: Starting steamwebhelper with Sniper steam runtime at /home/fj/.local/share/Steam/ubuntu12
_64/steam-runtime-sniper/_v2-entry-point
pressure-vessel-wrap[38695]: W: Failed to load Vulkan ICD #0 from /usr/share/vulkan/icd.d/nvidia_icd.json: openat(/
usr/share/vulkan/icd.d/nvidia_icd.json): No such file or directory
pressure-vessel-wrap[38695]: W: Failed to load Vulkan ICD #1 from /usr/share/vulkan/icd.d/nvidia_icd.json: openat(/
Steam Runtime Launch Service: starting steam-runtime-launcher-service
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 38760
bus_name=com.steampowered.PressureVessel.LaunchAlongsideSteam
exec ./steamwebhelper -lang=en_US -cachedir=/home/fj/.local/share/Steam/config/htmlcache -steampid=38635 -buildid=1
726604483 -steamid=0 -logdir=/home/fj/.local/share/Steam/logs -uimode=7 -startcount=0 -userdatadir=/home/fj/.local/
share/Steam/config/cefdata -steamuniverse=Public -realm=Global -clientui=/home/fj/.local/share/Steam/clientui -stea
mpath=/home/fj/.local/share/Steam/ubuntu12_32/steam -launcher=0 -no-restart-on-ui-mode-change --valve-enable-site-i
solation --enable-smooth-scrolling --password-store=basic --log-file=/home/fj/.local/share/Steam/logs/cef_log.txt -
-disable-quick-menu --enable-features=PlatformHEVCDecoderSupport --disable-features=SpareRendererForSitePerProcess,
DcheckIsFatal
Vulkan missing requested extension 'VK_KHR_surface'.
Vulkan missing requested extension 'VK_KHR_xlib_surface'.
BInit - Unable to initialize Vulkan!
BRefreshApplicationsInLibrary 1: 1ms
Desktop state changed: desktop: { pos: 0, 0 size: 1920,1080 } primary: { pos: 0, 0 size: 1920,1080 }
BuildCompleteAppOverviewChange: 157 apps
RegisterForAppOverview 1: 1ms
RegisterForAppOverview 2: 1ms
chdir "/home/fj/.local/share/Steam/steamapps/common/Skyrim"
ERROR: ld.so: object '/home/fj/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be pre
loaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '/home/fj/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be pre
loaded (wrong ELF class: ELFCLASS64): ignored.
Adding process 39422 for gameID 72850
pressure-vessel-wrap[39423]: W: Failed to load Vulkan ICD #0 from /usr/share/vulkan/icd.d/nvidia_icd.json: openat(/
pressure-vessel-wrap[39423]: W: Failed to load Vulkan ICD #1 from /usr/share/vulkan/icd.d/nvidia_icd.json: openat(/
pressure-vessel-wrap[39423]: W: Not sharing path STEAM_COMPAT_TOOL_PATHS="...:/usr/share/steam/compatibilitytools.d
/proton-ge-custom:..." with container because "/usr" is reserved by the container framework
ProtonFixes[39517] INFO: Running protonfixes
ProtonFixes[39517] INFO: Running checks
ProtonFixes[39517] INFO: All checks successful
ProtonFixes[39517] INFO: Using global defaults for "The Elder Scrolls V: Skyrim" (72850)
ProtonFixes[39517] INFO: Using global protonfix for "The Elder Scrolls V: Skyrim" (72850)
fsync: up and running.
Setting breakpad minidump AppID = 72850
Steam_SetMinidumpSteamID: Caching Steam ID: 76561199127301898 [API loaded no]
pid 39521 != 39520, skipping destruction (fork without exec?)
Game 72850 created interface STEAMAPPLIST_INTERFACE_VERSION001 / AppList
Game 72850 created interface STEAMAPPS_INTERFACE_VERSION008 / Apps
Game 72850 created interface STEAMHTMLSURFACE_INTERFACE_VERSION_004 / HTMLSurface
Game 72850 created interface STEAMHTTP_INTERFACE_VERSION002 / HTTP
Game 72850 created interface STEAMINVENTORY_INTERFACE_V002 / Inventory
Game 72850 created interface STEAMMUSICREMOTE_INTERFACE_VERSION001 / MusicRemote
Game 72850 created interface STEAMMUSIC_INTERFACE_VERSION001 / Music
Game 72850 created interface STEAMPARENTALSETTINGS_INTERFACE_VERSION001 / ParentalSettings
Game 72850 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION014 / RemoteStorage
Game 72850 created interface STEAMSCREENSHOTS_INTERFACE_VERSION003 / Screenshots
Game 72850 created interface STEAMUGC_INTERFACE_VERSION010 / UGC
Game 72850 created interface STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
Game 72850 created interface STEAMVIDEO_INTERFACE_V002 / Video
Game 72850 created interface SteamController006 / Controller
Game 72850 created interface SteamFriends015 / Friends
Game 72850 created interface SteamMatchMaking009 / Matchmaking
Game 72850 created interface SteamMatchMakingServers002 / MatchmakingServers
Game 72850 created interface SteamNetworking005 / Networking
Game 72850 created interface SteamUser019 / User
Game 72850 created interface SteamUtils009 / Utils
Game 72850 method call count for IClientAppManager::GetCurrentLanguage : 1
Game 72850 method call count for IClientAppManager::GetAvailableLanguages : 1
Game 72850 method call count for IClientAppManager::GetAppInstallState : 2
Game 72850 method call count for IClientUtils::RecordSteamInterfaceCreation : 22
Game 72850 method call count for IClientUtils::GetSteamUILanguage : 1
Game 72850 method call count for IClientUtils::GetAppID : 24
Game 72850 method call count for IClientUser::GetSteamID : 1
Uploaded AppInterfaceStats to Steam
Removing process 39422 for gameID 72850
Adding process 40076 for gameID 72850
pressure-vessel-wrap[40077]: W: Failed to load Vulkan ICD #0 from /usr/share/vulkan/icd.d/nvidia_icd.json: openat(/
pressure-vessel-wrap[40077]: W: Failed to load Vulkan ICD #1 from /usr/share/vulkan/icd.d/nvidia_icd.json: openat(/
pressure-vessel-wrap[40077]: W: Not sharing path STEAM_COMPAT_TOOL_PATHS="...:/usr/share/steam/compatibilitytools.d
ProtonFixes[40171] INFO: Running protonfixes
ProtonFixes[40171] INFO: Running checks
ProtonFixes[40171] INFO: All checks successful
ProtonFixes[40171] INFO: Using global defaults for "The Elder Scrolls V: Skyrim" (72850)
ProtonFixes[40171] INFO: Using global protonfix for "The Elder Scrolls V: Skyrim" (72850)
pid 40175 != 40174, skipping destruction (fork without exec?)
Removing process 40076 for gameID 72850
that probably doesn’t help but when i launch skyrim i get that in the terminal idk probably not helpful but i wanted to get you as much info as possible
