I did a fresh install of EndeavourOS and installed steam after installing the 390xx nvidia drivers but it won’t open.
Specs: GF117M, Intel Haswell-ULT, intel i7-4500U
Have you tried to run
steam --reset
Also check to see if you have any updates
I tried steam --reset but it still gave me the same output
and I have updated and reboot still won’t open.
Does it work with the nouveau drivers?
All the issues I have found that are similar to yours are related to nvidia drivers
It does work with nouveau but when I try running a game, the game won’t open.
Which game? Is it using Proton or running natively? If its using proton have you checked protondb to see how well the game runs or if there are any workarounds needed to run it?
Did you also install lib32-nvidia-390xx-utils ? This is needed for 32-bit applications.
Im going to try everything again but my internet is not cooperating. The game was flowers le volume sur ete. I ran it before on another machine with the latest nvidia driver and it worked perfectly and protondb said so too.
I did but it still doesn’t work
launch steam in a terminal and post the output here. COPY AND PASTE not pastebin it is firewalled here.
I see, im sorry I didn’t know that.
$ steam
steam.sh[10924]: Running Steam on endeavouros rolling 64-bit
steam.sh[10924]: STEAM_RUNTIME is enabled automatically
setup.sh[10999]: Steam runtime environment up-to-date!
steam.sh[10924]: Steam client’s requirements are satisfied
[2022-06-15 22:43:00] Startup - updater built Jun 7 2022 03:18:19
Installing breakpad exception handler for appid(steam)/version(1654574690)
Looks like steam didn’t shutdown cleanly, scheduling immediate update check
[2022-06-15 22:43:00] Loading cached metrics from disk (/home/(username)/.local/share/Steam/package/steam_client_metrics.bin)
[2022-06-15 22:43:00] Failed to load cached hosts file (File ‘update_hosts_cached.vdf’ not found), using defaults
[2022-06-15 22:43:00] Using the following download hosts for Public, Realm steamglobal
[2022-06-15 22:43:00] 1. http://media.steampowered.com, /client/, Realm ‘steamglobal’, weight was 1, source = ‘baked in’
[2022-06-15 22:43:00] Checking for update on startup
[2022-06-15 22:43:00] Checking for available updates…
[2022-06-15 22:43:00] Downloading manifest: http://media.steampowered.com/client/steam_client_ubuntu12
[2022-06-15 22:43:00] Manifest download: send request
[2022-06-15 22:43:00] Manifest download: waiting for download to finish
[2022-06-15 22:43:00] Manifest download: finished
[2022-06-15 22:43:00] Download skipped: /client/steam_client_ubuntu12 version 1654574690, installed version 1654574690, existing pending version 0
[2022-06-15 22:43:00] Nothing to do
[2022-06-15 22:43:00] Verifying installation…
[2022-06-15 22:43:00] Performing checksum verification of executable files
[2022-06-15 22:43:01] Verification complete
Loaded SDL version 2.0.22-7215337
OpenGL GLX extension not supported by display
OpenGL GLX extension not supported by displaysrc/steamUI/Main.cpp (387) : Assertion Failed: Error: OpenGL GLX extension not supported by display
assert_20220615224301_6.dmp[11080]: Uploading dump (out-of-process)
/tmp/dumps/assert_20220615224301_6.dmp
/usr/share/themes/Breeze/gtk-2.0/widgets/entry:70: error: unexpected identifier direction', expected character }’
(steam:11056): Gtk-WARNING **: Unable to locate theme engine in module_path: “adwaita”,
/usr/share/themes/Breeze/gtk-2.0/widgets/styles:36: error: invalid string constant “combobox_entry”, expected valid string constant
Fontconfig warning: line 5: unknown element “description”
steamwebhelper.sh[11085]: Runtime for steamwebhelper: defaulting to /home/(username)/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
Fontconfig warning: “/etc/fonts/conf.d/10-hinting-slight.conf”, line 4: unknown element “description”
Fontconfig warning: “/etc/fonts/conf.d/10-scale-bitmap-fonts.conf”, line 4: unknown element “description”
Fontconfig error: “/etc/fonts/conf.d/10-scale-bitmap-fonts.conf”, line 72: non-double matrix element
Fontconfig warning: “/etc/fonts/conf.d/10-scale-bitmap-fonts.conf”, line 80: saw unknown, expected number
Fontconfig warning: “/etc/fonts/conf.d/11-lcdfilter-default.conf”, line 4: unknown element “description”
Fontconfig warning: “/etc/fonts/conf.d/20-unhint-small-vera.conf”, line 4: unknown element “description”
Fontconfig warning: “/etc/fonts/conf.d/30-metric-aliases.conf”, line 4: unknown element “description”
Fontconfig warning: “/etc/fonts/conf.d/40-nonlatin.conf”, line 4: unknown element “description”
Fontconfig warning: “/etc/fonts/conf.d/45-generic.conf”, line 4: unknown element “description”
Fontconfig warning: “/etc/fonts/conf.d/45-latin.conf”, line 4: unknown element “description”
Fontconfig warning: “/etc/fonts/conf.d/48-spacing.conf”, line 4: unknown element “description”
Fontconfig warning: “/etc/fonts/conf.d/49-sansserif.conf”, line 4: unknown element “description”
Fontconfig warning: “/etc/fonts/conf.d/50-user.conf”, line 4: unknown element “description”
Fontconfig warning: “/etc/fonts/conf.d/51-local.conf”, line 4: unknown element “description”
Fontconfig warning: “/etc/fonts/conf.d/60-generic.conf”, line 4: unknown element “description”
Fontconfig warning: “/etc/fonts/conf.d/60-latin.conf”, line 4: unknown element “description”
Fontconfig warning: “/etc/fonts/conf.d/65-nonlatin.conf”, line 4: unknown element “description”
glXChooseVisual failed
glXChooseVisual failedsrc/steamUI/Main.cpp (387) : Assertion Failed: Error: glXChooseVisual failed
steamwebhelper.sh[11085]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
crash_20220615224301_8.dmp[11109]: Uploading dump (out-of-process)
/tmp/dumps/crash_20220615224301_8.dmp
/home/(username)/.local/share/Steam/steam.sh: line 794: 11056 Segmentation fault (core dumped) “$STEAMROOT/$STEAMEXEPATH” “$@”
$ assert_20220615224301_6.dmp[11080]: Finished uploading minidump (out-of-process): success = no
assert_20220615224301_6.dmp[11080]: error: HTTP response code said error
assert_20220615224301_6.dmp[11080]: file ‘’/tmp/dumps/assert_20220615224301_6.dmp’’, upload no: ‘‘HTTP response code said error’’
crash_20220615224301_8.dmp[11109]: Finished uploading minidump (out-of-process): success = yes
crash_20220615224301_8.dmp[11109]: response: CrashID=bp-06dab48b-c829-4e4a-bf86-1f0292220615
crash_20220615224301_8.dmp[11109]: file ‘’/tmp/dumps/crash_20220615224301_8.dmp’’, upload yes: ‘‘CrashID=bp-06dab48b-c829-4e4a-bf86-1f0292220615’’
Ok after looking up that game and accidently mistyping it the first time it looks like you may need to do a workaround. There are only 3 reports on that game, in the first they have used proton-ge, in the 2nd they had to install gstreamer bad plugins. And the last report they needed to use proton experimental.
I see, I’ll try running it on protonge and experimental once my internet decides to work. Thank you!
You’re welcome, I always check out there and Lutris to see how a game will run.
