When launching steam from the terminal, the logs that I can read indicate there are no obvious errors. The key factor here is that the window works as intended within XFCE and this error only occurs in hyprland so I assume it must be related to the Wayland. That being said I have tried to launch it forcing x11, and removing various caches from the app with no results. I have also already tried uninstalling and reinstalling the package.
*Edit an additional problem that I have noticed is the Heroic Games Launcher not launching, the specific package is the heroic-launcher-bin package in the chaotic-aur. I feel as this problem may be related to the steam issue
Steam and games work perfectly for me in Hyprland, while games may not launch or play correctly in x11, so not a Wayland issue.
You said you tried forcing x11? Do you mean in Hyprland? How?
How is Steam installed for you? Official Repo, AUR, Flatpak, Snap?
I can confirm that Wayland + Steam works on my machine also. Running EOS with Gnome.
By the way, why are you running Steam from terminal? Did you do so only for testing purposes or do you intend to do so everytime you run it?
I am using the official arch repo package. I did try to force x11 using the terminal with no change to the bug. I say that ai believe it to be something going on with hyprland/wayland because i tried logging out and testing it in xfce and worked as intended.
I was running from the terminal to get a better look at debugging logs and see if i could start it in a cpuple ways to alleviate the issue.
I am little bit lost. So did you try forcing X11 on Wayland? Because I am pretty sure that wont work.
Err… Let’s see what you got installed. Please post the outputs of the following commands:
inxi -Fxxc0z
pacman -Q | grep -A 0 -E "(steam|mango|game|vulk|vlk|nvidia|amd|hypr|wayland|linux|headers)"
Thing is, that is not supposed to work, so there is no error there. What I’m wondering, is where you got that idea from, because that is impossible to achieve. X11 and Wayland are completely different systems.
export STEAM_RUNTIME_FORCE_X11=1
steam
this is how I did it
here are the relevant packages
amd-ucode 20241210.b00a7f7e-1
amdvlk 2024.Q4.3-1
archlinux-keyring 20241203-1
gamehub 0.16.3.2-2.5
heroic-games-launcher-bin 2.15.2-1
hyprcursor 0.1.11-1
hyprgraphics 0.1.1-3
hypridle 0.1.5-2
hyprland 0.46.2-5
hyprland-qtutils 0.1.2-1
hyprlang 0.6.0-3
hyprlock 0.6.1-1
hyprutils 0.3.3-1
hyprwayland-scanner 0.4.4-1
lib32-amdvlk 2024.Q4.3-1
lib32-util-linux 2.40.2-1
lib32-vulkan-icd-loader 1.4.303-1
lib32-wayland 1.23.1-1
linux 6.12.8.arch1-1
linux-api-headers 6.10-1
linux-firmware 20241210.b00a7f7e-1
linux-firmware-whence 20241210.b00a7f7e-1
linux-headers 6.12.8.arch1-1
linux-lts 6.6.69-1
linux-lts-headers 6.6.69-1
python-steam 1.6.1-1.1
python-steamgriddb 1.0.5-4
qt6-wayland 6.8.1-1
rofi-wayland 1.7.7.1-1
steam 1.0.0.81-2
util-linux 2.40.2-3
util-linux-libs 2.40.2-3
vulkan-headers 1:1.4.303-1
vulkan-radeon 1:24.3.3-1
wayland 1.23.1-1
wayland-protocols 1.39-1
xdg-desktop-portal-hyprland 1.3.9-3
xf86-video-amdgpu 23.0.0-2
xorg-xwayland 24.1.4-1
system information
Kernel: 6.12.8-arch1-1 arch: x86_64 bits: 64 compiler: gcc
v: 14.2.1
Desktop: Hyprland v: 0.46.2 dm: 1: LightDM note: stopped
2: SDDM Distro: EndeavourOS base: Arch Linux
Type: Desktop Mobo: Gigabyte model: A620I AX v: x.x
serial: <superuser required> UEFI: American Megatrends LLC.
v: F2 date: 06/06/2023
Info: 6-core model: AMD Ryzen 5 7600 bits: 64 type: MT MCP
arch: Zen 4 rev: 2 cache: L1: 384 KiB L2: 6 MiB L3: 32 MiB
Speed (MHz): avg: 3541 min/max: 400/5170 boost: enabled
cores: 1: 3541 2: 3541 3: 3541 4: 3541 5: 3541 6: 3541
7: 3541 8: 3541 9: 3541 10: 3541 11: 3541 12: 3541
bogomips: 91056
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2
sse4a ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon
RX 7700 XT / 7800 XT] vendor: Tul / PowerColor
driver: amdgpu v: kernel arch: RDNA-3 pcie: speed: 16 GT/s
lanes: 16 ports: active: DP-2 empty: DP-1, DP-3,
HDMI-A-1, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:747e
Device-2: Advanced Micro Devices [AMD/ATI] Raphael
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 pcie:
speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4,
DP-5, DP-6, HDMI-A-2, Writeback-2 bus-ID: 11:00.0
chip-ID: 1002:164e temp: 45.0 C
Device-3: Logitech QuickCam Pro 9000
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 7-1:2 chip-ID: 046d:0990
Display: wayland server: X.org v: 1.21.1.15 with: Xwayland
v: 24.1.4 compositor: Hyprland v: 0.46.2 driver: X:
loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
display-ID: 1
Monitor-1: DP-2 model: Viewteck GNV34DB res: 3440x1440
dpi: 111 diag: 856mm (33.7")
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi
device: 1 drv: radeonsi device: 2 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: radeonsi wayland:
drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa
v: 24.3.3-arch1.1 glx-v: 1.4 direct-render: yes renderer: AMD
Radeon RX 7700 XT (radeonsi navi32 LLVM 18.1.8 DRM 3.59
6.12.8-arch1-1) device-ID: 1002:747e
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP
Audio driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s
lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt
Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: 11:00.1
chip-ID: 1002:1640
Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah
HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
pcie: speed: 16 GT/s lanes: 16 bus-ID: 11:00.6
chip-ID: 1022:15e3
Device-4: Focusrite-Novation Scarlett Solo USB
driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 bus-ID: 1-4:4 chip-ID: 1235:8205
Device-5: Logitech QuickCam Pro 9000
API: ALSA v: k6.12.8-arch1-1 status: kernel-api
Server-2: PipeWire v: 1.2.7 status: active with:
1: pipewire-pulse status: active 2: wireplumber
status: active 3: pipewire-alsa type: plugin 4: pw-jack
type: plugin
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte
driver: r8169 v: kernel pcie: speed: 5 GT/s lanes: 1
port: d000 bus-ID: 08:00.0 chip-ID: 10ec:8125
IF: enp8s0 state: down mac: <filter>
Device-2: Realtek RTL8852CE PCIe 802.11ax Wireless Network
driver: rtw89_8852ce v: kernel pcie: speed: 5 GT/s lanes: 1
port: c000 bus-ID: 09:00.0 chip-ID: 10ec:c852
Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8
type: USB rev: 1.0 speed: 12 Mb/s lanes: 1 bus-ID: 1-10:6
chip-ID: 0bda:0852
Report: btmgmt ID: hci0 rfk-id: 0 state: up
address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 5.46 TiB used: 1.17 TiB (21.4%)
ID-1: /dev/nvme0n1 vendor: A-Data model: LEGEND 800
size: 1.82 TiB speed: 63.2 Gb/s lanes: 4 serial: <filter>
temp: 35.9 C
ID-2: /dev/sda vendor: Seagate model: ST4000DM004-2CV104
size: 3.64 TiB speed: 6.0 Gb/s serial: <filter>
ID-1: / size: 1.77 TiB used: 204.65 GiB (11.3%) fs: ext4
dev: /dev/nvme0n1p2
ID-1: swap-1 type: partition size: 16.26 GiB
used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
System Temperatures: cpu: 48.8 C mobo: 35.0 C
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 45.0 C device: amdgpu
temp: 47.0 C mem: 56.0 C fan: 0
Memory: total: 16 GiB note: est. available: 14.78 GiB
used: 4.28 GiB (29.0%)
Processes: 334 Power: uptime: 13m wakeups: 0 Init: systemd
v: 257 default: graphical
Packages: pm: pacman pkgs: 1355 Compilers: clang: 18.1.8
gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: kitty
inxi: 3.3.36
Apart from your BIOS possibly needing an update, I can’t see anything wrong with your system or apps at the moment.
So, a suggestion would be to update your BIOS and/or try using linux-lts in Hyprland instead of the current kernel.
Another option, is to not just uninstall Steam, but to also rename/remove the Steam folder.
Once you do this, you’d launch and sign in to Steam again.
mv .local/share/Steam .local/share/Steam-bkp
And a third option is to create a new user account, log in to it, launch and sign in to Steam, then see if you have the same issue. If you don’t have the issue anymore, then your current user settings is causing some unknown issue.
PS: I just updated my device and launched Steam just fine like before. Currently playing a game. Toodles.
lts kernel had the same results,
I tried removing it previously with pacman -Rns for the steam package previously but I will also try your method.
When I tried your above command to delete the files and reinstalling the package, it showed promise where the login window did the loop once before sticking around to be logged into as normal, and then the standard client window did the exact same behavior as before.
As I said in the above steam and heroic work as intended in an XFCE session so I don’t think it should be the steam package itself. The only other thing I can think of is using a timeshift rollback I have for the 3rd.
Try updating your BIOS then: https://www.gigabyte.com/Motherboard/A620I-AX-rev-10/support#support-dl-bios
Latest available update is Dec. 19 2024.
Arch Wiki: https://wiki.archlinux.org/title/Flashing_BIOS_from_Linux
Fwupd: https://wiki.archlinux.org/title/Fwupd
BIOS updates for the most part help your device internals and peripherals to work better with the Linux kernel, but of course, help with security as well.
I was able to flash the new bios
Okay. Now try it with both kernels and/or a combination of the other suggestions.
Not sure if you tried the new user suggestion, but that one lets you know if something is wrong with your whole setup, like a package issue, or if it’s just your user settings.
After trying everything I found the load-bearing wire, I had changed my gtk theme from adwaita to kali dark. I am not kidding I changed it back to adwaita and this fixed it.
That’s a Gnome-like error. Do you have it installed?
I don’t use Adwaita anything and I don’t have this issue.
I have gtk theming installed for my hyprland setup
