Complete newbie here.
After managing to get steam set up, I came across a problem where when I am trying to run certain games, the play button turns green again. I ran steam through the terminal and this is what it gave me:
I tried using the script from [Script] Fix permissions when copying from a non Linux filesystem since I migrated from windows just recently so I assumed that my second drive, where all my games are, just has some weird permissions that needed fixing. That did not work, and the output from the terminal (at a glance) did not change.
If needed here is output from inxi -Fxz:
Kernel: 6.1.54-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 5.27.8 Distro: EndeavourOS base: Arch Linux
Type: Desktop System: Dell product: XPS 8940 v: N/A
serial: <superuser required>
Mobo: Dell model: 0427JK v: A00 serial: <superuser required> UEFI: Dell
v: 2.10.0 date: 09/14/2022
Info: 8-core model: 11th Gen Intel Core i7-11700 bits: 64 type: MT MCP
arch: Rocket Lake rev: 1 cache: L1: 640 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4800:4900 cores: 1: 800
2: 801 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800
12: 800 13: 800 14: 800 15: 800 16: 800 bogomips: 79888
Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: Dell
driver: i915 v: kernel arch: Gen-12.1 bus-ID: 00:02.0
Device-2: NVIDIA GA104 [GeForce RTX 3060 Ti] vendor: Dell driver: nvidia
v: 535.104.05 arch: Ampere bus-ID: 02:00.0
Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB bus-ID: 1-12:5
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting,nvidia
dri: iris gpu: nvidia,nvidia-nvswitch resolution: 1: 1920x1080~60Hz
2: 1050x1400~60Hz
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce RTX 3060
Ti/PCIe/SSE2 direct-render: Yes
Device-1: Intel vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA GA104 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 02:00.1
Device-4: C-Media TONOR TC-777 Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 1-13:6
API: ALSA v: k6.1.54-1-lts status: kernel-api
Server-1: PipeWire v: 0.3.80 status: active
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3
Device-2: Realtek vendor: Rivet Networks driver: r8169 v: kernel
port: 3000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-14:7
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11
Local Storage: total: 1.38 TiB used: 773.39 GiB (54.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: PM991a NVMe 512GB
size: 476.94 GiB temp: 47.9 C
ID-2: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
ID-1: / size: 166.91 GiB used: 63.31 GiB (37.9%) fs: ext4
dev: /dev/nvme0n1p7
ID-2: /boot/efi size: 146 MiB used: 30.3 MiB (20.7%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 53.0 C pch: 54.0 C mobo: 50.0 C gpu: nvidia
temp: 42 C
Fan Speeds (rpm): cpu: 1000 fan-1: 800 gpu: nvidia fan: 0%
Processes: 349 Uptime: 2h 22m Memory: total: 16 GiB note: est.
available: 15.27 GiB used: 6.62 GiB (43.4%) Init: systemd Compilers:
gcc: 13.2.1 Packages: 1126 Shell: Bash v: 5.1.16 inxi: 3.3.29
