The journalctl output after first startup without crash after OFFLINE installation.
[xxx@yyy ~]$ journalctl -b -p 3
Sep 05 20:15:07 yyy kernel: x86/cpu: SGX disabled by BIOS.
Sep 05 20:15:22 yyy kernel: ath10k_pci 0000:02:00.0: AER: Error of this Agent is reported first
Sep 05 20:15:23 yyy kernel: ath10k_pci 0000:02:00.0: AER: Error of this Agent is reported first
Sep 05 20:15:26 yyy kernel: ath10k_pci 0000:02:00.0: AER: Error of this Agent is reported first
Sep 05 20:15:31 yyy kernel: ath10k_pci 0000:02:00.0: AER: Error of this Agent is reported first
Sep 05 20:16:04 yyy kernel: ath10k_pci 0000:02:00.0: AER: Error of this Agent is reported first
[xxx@yyy ~]$
Next, mentioned update suggestion from @BluishHumility with LTS kernel…
One thing that I noticed in the update protocol are all those dracut releated messages about missing dracut modules - are these messages normal?
(180/181) Installiert wird gtk-layer-shell [--------------------------------------] 100%
(181/181) Aktualisiert wird xfce4-whiskermenu-plugin [--------------------------------------] 100%
:: Post-transaction-Hooks werden gestartet …
( 1/23) Creating system user accounts...
( 2/23) Updating journal message catalog...
( 3/23) Reloading system manager configuration...
( 4/23) Updating udev hardware database...
( 5/23) Applying kernel sysctl settings...
( 6/23) Creating temporary files...
( 7/23) Reloading device manager configuration...
( 8/23) Arming ConditionNeedsUpdate...
( 9/23) Updating the MIME type database...
(10/23) Updating module dependencies...
(11/23) Updating initramfs...
:: Building initramfs for linux-lts (6.1.51-1-lts)
dracut: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline /usr/lib/modules/6.1.51-1-lts/initrd 6.1.51-1-lts
dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
dracut: dracut module 'dbus-broker' will not be installed, because command 'dbus-broker' could not be found!
dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmand' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmanctl' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmand-wait-online' could not be found!
dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
dracut: dracut module 'dmraid' will not be installed, because command 'kpartx' could not be found!
dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
dracut: dracut module 'biosdevname' will not be installed, because command 'biosdevname' could not be found!
dracut: dracut module 'memstrack' will not be installed, because command 'memstrack' could not be found!
dracut: memstrack is not available
dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
dracut: dracut module 'squash' will not be installed, because command 'mksquashfs' could not be found!
dracut: dracut module 'squash' will not be installed, because command 'unsquashfs' could not be found!
dracut: *** Including module: systemd ***
dracut: *** Including module: systemd-initrd ***
dracut: *** Including module: i18n ***
dracut: *** Including module: kernel-modules ***
dracut: *** Including module: kernel-modules-extra ***
dracut: *** Including module: rootfs-block ***
dracut: *** Including module: terminfo ***
dracut: *** Including module: udev-rules ***
dracut: Skipping udev rule: 40-redhat.rules
dracut: Skipping udev rule: 50-firmware.rules
dracut: Skipping udev rule: 50-udev.rules
dracut: Skipping udev rule: 91-permissions.rules
dracut: Skipping udev rule: 80-drivers-modprobe.rules
dracut: Skipping udev rule: 70-persistent-net.rules
dracut: *** Including module: dracut-systemd ***
dracut: *** Including module: usrmount ***
dracut: *** Including module: base ***
dracut: *** Including module: fs-lib ***
dracut: *** Including module: shutdown ***
dracut: *** Including modules done ***
dracut: *** Installing kernel module dependencies ***
dracut: *** Installing kernel module dependencies done ***
dracut: *** Resolving executable dependencies ***
dracut: *** Resolving executable dependencies done ***
dracut: *** Hardlinking files ***
dracut: Mode: real
dracut: Method: memcmp
dracut: Files: 765
dracut: Linked: 2 files
dracut: Compared: 0 xattrs
dracut: Compared: 35 files
dracut: Saved: 356.65 KiB
dracut: Duration: 0.006314 seconds
dracut: *** Hardlinking files done ***
dracut: *** Generating early-microcode cpio image ***
dracut: *** Using microcode found in '/boot/intel-ucode.img' ***
dracut: *** Store current command line parameters ***
dracut: *** Stripping files ***
dracut: *** Stripping files done ***
dracut: *** Creating image file '/usr/lib/modules/6.1.51-1-lts/initrd' ***
dracut: *** Creating initramfs image file '/usr/lib/modules/6.1.51-1-lts/initrd' done ***
:: Building fallback initramfs for linux-lts (6.1.51-1-lts)
dracut: Executing: /usr/bin/dracut --force --no-hostonly /boot/initramfs-linux-lts-fallback.img 6.1.51-1-lts
dracut: dracut module 'multipath' will not be installed, because command 'multipath' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoemon' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoeadm' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'nbd' depends on 'network', which can't be installed
dracut: *** Including module: modsign ***
dracut: *** Including module: btrfs ***
dracut: *** Including module: crypt ***
dracut: *** Including module: dm ***
dracut: Skipping udev rule: 64-device-mapper.rules
dracut: Skipping udev rule: 60-persistent-storage-dm.rules
dracut: Skipping udev rule: 55-dm.rules
dracut: *** Including module: lvm ***
dracut: Skipping udev rule: 56-lvm.rules
dracut: Skipping udev rule: 60-persistent-storage-lvm.rules
dracut: *** Including module: mdraid ***
dracut: Skipping udev rule: 64-md-raid.rules
dracut: *** Including module: nvdimm ***
dracut: *** Including module: qemu ***
dracut: *** Including module: qemu-net ***
dracut: *** Including module: btrfs-snapshot-overlay ***
dracut: *** Including module: lunmask ***
dracut: *** Including module: resume ***
dracut: *** Including module: virtiofs ***
dracut: Mode: real
dracut: Files: 1981
dracut: Linked: 8 files
dracut: Compared: 451 files
dracut: Saved: 1.42 MiB
dracut: Duration: 0.045248 seconds
dracut: *** Constructing AuthenticAMD.bin ***
dracut: *** Creating image file '/boot/initramfs-linux-lts-fallback.img' ***
dracut: *** Creating initramfs image file '/boot/initramfs-linux-lts-fallback.img' done ***
:: Building initramfs for linux (6.4.12-arch1-1)
dracut: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline /usr/lib/modules/6.4.12-arch1-1/initrd 6.4.12-arch1-1
dracut: Mode: real
dracut: Files: 777
dracut: Duration: 0.006880 seconds
dracut: *** Creating image file '/usr/lib/modules/6.4.12-arch1-1/initrd' ***
dracut: *** Creating initramfs image file '/usr/lib/modules/6.4.12-arch1-1/initrd' done ***
:: Building fallback initramfs for linux (6.4.12-arch1-1)
dracut: Executing: /usr/bin/dracut --force --no-hostonly /boot/initramfs-linux-fallback.img 6.4.12-arch1-1
dracut: Mode: real
dracut: Files: 1996
dracut: Compared: 449 files
dracut: Duration: 0.018931 seconds
dracut: *** Creating image file '/boot/initramfs-linux-fallback.img' ***
dracut: *** Creating initramfs image file '/boot/initramfs-linux-fallback.img' done ***
(12/23) Reloading system bus configuration...
(13/23) Warn about old perl modules
(14/23) Check if user should be informed about rebooting after certain system package upgrades.
(15/23) Updating fontconfig cache...
(16/23) Probing GDK-Pixbuf loader modules...
(17/23) Updating GIO module cache...
(18/23) Compiling GSettings XML schema files...
(19/23) Updating icon theme caches...
(20/23) Reloading GVFS config...
(21/23) Checking which packages need to be rebuilt
(22/23) Updating the info directory file...
(23/23) Updating the desktop file MIME type cache...
[daniel@dachstein ~]$
