Hi,
While trying to upgrade my SSD from 500GB to 1TB. I kinda broke my System. When I try to boot, I only get grub shell when booting.
When booting from there with:
set root=(hd2,gpt2)
linux /boot/vmlinuz-linux root=/dev/nvme0n1p2
initrd /boot/initramfs-linux.img
boot
Then I can reach an emergency shell
Journal only gives one error:
controlC3: Process '/usr/bin/alsactl restore 3' failed with exit code 99.
When checking / and /boot/efi partitions are mounted. I can mount /var and /home manually though. But I cannot reach a graphical environment. startx only gives me weird graphical issues.
Booting via LiveUSB and using arch-chroot is working fine, but running mkinitcpio -P and reinstall grub doesn’t bring any success. I’m still stuck on grub shell after reboot.
Any Idea how to fix this?
Edit Inxi information & Fstab - From Chroot:
[root@EndeavourOS ~]# inxi -Fxxc0z
Kernel: 6.4.8-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 Console: N/A wm: xfwm
DM: startx Distro: EndeavourOS base: Arch Linux
Type: Desktop System: Gigabyte product: AX370-Gaming 3 v: N/A serial: N/A
Mobo: Gigabyte model: AX370-Gaming 3-CF serial: N/A UEFI: American Megatrends LLC. v: F51f
date: 04/28/2022
Info: 8-core model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ rev: 2 cache:
L1: 512 KiB L2: 4 MiB L3: 32 MiB
Speed (MHz): avg: 2425 high: 3400 min/max: 2200/4662 boost: enabled cores: 1: 3400 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 3400 10: 2200 11: 2200 12: 2200 13: 2200
14: 3400 15: 2200 16: 2200 bogomips: 108837
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: Sapphire driver: amdgpu
v: kernel arch: RDNA-1 pcie: speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
empty: HDMI-A-1,HDMI-A-2 bus-ID: 0b:00.0 chip-ID: 1002:731f
Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 1-9.2:3 chip-ID: 046d:082d
Display: server: X.org v: 1.21.1.9 compositor: xfwm driver: X: loaded: amdgpu
unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi gpu: amdgpu display-ID: :0.0
Monitor-1: DP-1 model: Huawei ZQE-CAA res: 3440x1440 dpi: 110 diag: 864mm (34")
Monitor-2: DP-2 model: LG (GoldStar) ULTRAWIDE res: 3440x1440 dpi: 109 diag: 869mm (34.2")
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast surfaceless:
drv: radeonsi inactive: gbm,wayland,x11
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 23.2.1-arch1.2 note: incomplete (EGL sourced)
renderer: AMD Radeon RX 5700 XT (navi10 LLVM 16.0.6 DRM 3.52 6.4.8-arch1-1), llvmpipe (LLVM
16.0.6 256 bits)
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: 0b:00.1 chip-ID: 1002:ab38
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
speed: 16 GT/s lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487
Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
Device-4: SteelSeries ApS [] driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 1-9.4.1.1:10 chip-ID: 1038:220a
API: ALSA v: k6.4.8-arch1-1 status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.83 status: n/a (root, process) with: pipewire-media-session
status: off
Server-3: PulseAudio v: 16.1 status: off
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
IF: eno1 state: down mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 bus-ID: 1-9.4.4:8 chip-ID: 0bda:8153
IF: enp2s0f0u9u4u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.74 TiB used: 246.8 GiB (8.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB speed: 63.2 Gb/s
lanes: 4 serial: <filter> temp: 38.9 C
ID-2: /dev/sda vendor: Western Digital model: WD20EZRZ-00Z5HB0 size: 1.82 TiB speed: 6.0 Gb/s
serial: <filter>
ID-3: /dev/sdb vendor: Intenso model: Ul tra Line size: 14.56 GiB type: USB rev: 3.1
spd: 5 Gb/s lanes: 1 serial: <filter>
ID-1: / size: 50 GiB used: 17.12 GiB (34.2%) fs: btrfs dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 1022 MiB used: 63.5 MiB (6.2%) fs: vfat dev: /dev/nvme0n1p1
ID-3: /home size: 850.51 GiB used: 222.86 GiB (26.2%) fs: btrfs dev: /dev/nvme0n1p4
ID-4: /var size: 30 GiB used: 6.76 GiB (22.5%) fs: btrfs dev: /dev/nvme0n1p3
System Temperatures: cpu: 35.9 C mobo: 27.0 C gpu: amdgpu temp: 56.0 C mem: 58.0 C
Fan Speeds (rpm): cpu: 0 fan-1: 0 fan-3: 0 gpu: amdgpu fan: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.25
Processes: 380 Uptime: 13m Memory: total: 32 GiB available: 31.27 GiB used: 2.3 GiB (7.3%)
Init: systemd v: 254 default: graphical Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1750 Client: Unknown Client: systemd inxi: 3.3.30
[root@EndeavourOS ~]# cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=9C59-C90D /boot/efi vfat umask=0077 0 2
UUID=77736a98-1674-4f5a-9fd5-79726bc408e5 / ext4 defaults,noatime 0 1
UUID=ff7d751d-e2c2-404a-a368-aeda2eed4ba1 /var ext4 defaults,noatime 0 2
UUID=b2bbbfc7-a82a-4a9f-8570-21a5cd6818ee /home ext4 defaults,noatime 0 2
UUID=655883e2-7dfe-4bb4-a88b-ade8768ee7b4 /mnt/data ext4 defaults,noatime 0 2
