How can I enable spell check in Plasma settings? It seems I can’t add any other language than is already there?
And also a question about Plasma Translations (Regional Settings → Language). How and where can I configure what is getting translated? I added some languages to the list and now terminal output and some apps UIs are seemingly randomly translated, it doesn’t look consistent.
I’d probably be able to tell if at least the Help button was working there I am new to Plasma, just exploring the settings and trying to configure it to my liking…
Was it working for you out of the box or did you do/install something extra?
I probably should have mentioned this from the beginning, but I don’t have the full Plasma install. It is a minimal installation, according to @dalto’s recommendation, which normally works very well, but some missing functionality can be expected. I am still only discovering what I’ll eventually need, so I may need to install some package(s) to get it working.
Thank you! That did it. I initially just installed aspell package, but didn’t install any dictionaries After installing them I can choose the spell checker in the menu. No additional package from the Plasma group was needed.
