Well, I did that. But the problem persists. I didn’t take that screenshot of the KDE website. It just appeared.
Is there another os or desktop environment installed on this system?
Yes, OpenSuse Tumbleweed with KDE Plasma (post #5). Spectacle works very well there.
As I said before. Add a new user and have a look if the problem persists.
Alternatively rename the folder ~/.config
to /.config.old
and have a look if the issue is resolved.
Preferably log out before renaming the folder. If the issue is resolved, just copy your needed configs from /.config.old
to /.config
I see you have Intel Iris Graphics. What does inxi -Ga show?
Edit: Maybe try system settings compositor vsync off
$ inxi -Ga
Device-1: Intel Iris Plus Graphics G1 vendor: Lenovo driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:8a56
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus ID: 1-6:3 chip ID: 13d3:56b2
Display: x11 server: X.org 1.20.10 compositor: kwin_x11 driver: intel
unloaded: fbdev,modesetting,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 20.3.2
direct render: Yes
With system settings compositor vsync off
It looks like it’s loading the correct modules for the Intel Iris. Does the vsync off make any difference?
Also did you try as @Trekkie00 suggested adding another user and then boot up to that new user and see and also his alternative suggestion?
Are you sharing a home partition with fedora and EndeavourOS?
No, I don’t.
I have OpenSuse Tumbleweed KDE, not Fedora.
Sorry then opensuse and endeavour
I’ve been reading the KDE web site, and the Arch forums too. Can’t find a solution for this. I need a screenshot sometimes for work, and as GIMP is doing the job, I can forget Spectacle. Usually the hand goes to the key to invoke screenshot, and that’s the problem. I might as well uninstall Spectacle to get used to not having it. But, what I worry is, maybe there’s some problem with EOS KDE. So, I informed.
Since it only seems to impact you, that seems unlikely.
Have you tried creating a new user and testing there as suggested above?
Retun:
inxi -Fxxxza --no-host
sudo parted -l
That is the letter l not a #1
I use EndeavourOS KDE and it’s never happened to me. Not seen any issues about this.
Yes, I did. To no avail. Spectacle gets stuck. Installed Flameshot too, and that too has the same problem.
$ inxi -Fxxxza --no-host
Kernel: 5.10.7-arch1-1 x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=3268aab1-568e-4707-9d9c-683e88391dea rw quiet loglevel=3
nowatchdog
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: EndeavourOS
Type: Laptop System: LENOVO product: 81VV v: Lenovo IdeaPad S340-14IIL
serial: <filter> Chassis: type: 10 v: Lenovo IdeaPad S340-14IIL
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <filter>
UEFI: LENOVO v: CUCN24WW(V1.13) date: 10/19/2020
Battery:
ID-1: BAT1 charge: 16.1 Wh condition: 44.6/52.5 Wh (85%)
volts: 11.0/11.2 model: Celxpert L18C3PF7 type: Li-ion
serial: <filter> status: Discharging cycles: 351
Info: Quad Core model: Intel Core i5-1035G1 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A0
L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 19048
Speed: 1005 MHz min/max: 400/3600 MHz Core speeds (MHz): 1: 1005
2: 1149 3: 1046 4: 1090 5: 1084 6: 1137 7: 1123 8: 1126
Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2
mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
direct render: Yes
Device-1: Intel Smart Sound Audio vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:34c8
Sound Server: ALSA v: k5.10.7-arch1-1
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel port: 3040 bus ID: 02:00.0
chip ID: 168c:0042
Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 1-10:4
chip ID: 0cf3:e500
Local Storage: total: 476.94 GiB used: 36.36 GiB (7.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8L
size: 476.94 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: C02C temp: 33.9 C
ID-1: / raw size: 58.78 GiB size: 56.86 GiB (96.73%)
used: 13.97 GiB (24.6%) fs: ext4 dev: /dev/nvme0n1p11 maj-min: 259:11
ID-2: /boot/efi raw size: 1024 MiB size: 1022 MiB (99.80%)
used: 189 MiB (18.5%) fs: vfat dev: /dev/nvme0n1p10 maj-min: 259:10
Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: file size: 1024 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 223 Uptime: 16m wakeups: 1 Memory: 7.46 GiB
used: 1.96 GiB (26.3%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: pacman: 1099 lib: 234 Shell: Bash v: 5.1.4
running in: konsole inxi: 3.2.01
And my other request please…
Model: INTEL SSDPEKNW512G8L (nvme)
Disk /dev/nvme0n1: 512GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 274MB 273MB fat32 EFI system partition boot, esp
2 274MB 290MB 16.8MB Microsoft reserved partition msftres
3 290MB 79.7GB 79.5GB ntfs Basic data partition msftdata
4 79.8GB 148GB 68.7GB ntfs Basic data partition msftdata
10 148GB 150GB 1074MB fat32 2NDBOOT boot, esp
5 150GB 182GB 32.2GB ext4 Basic data partition msftdata
6 182GB 240GB 58.5GB ext4 Basic data partition msftdata
8 240GB 321GB 80.7GB ext4
11 321GB 384GB 63.1GB ext4
7 384GB 511GB 127GB ext4
9 511GB 512GB 1049MB ntfs Basic data partition hidden, diag
Did you use sudo parted -l? This output looks different?
Edit: Okay i guess it’s the same. It just looks so weird outside the terminal.
Now return:
sudo lsblk -o name,mountpoint,label,size,uuid
