inxi -Fx
Host: aspirem1470 Kernel: 7.2.2-arch1-1 arch: x86_64 bits: 64
compiler: gcc v: 16.2.1
Desktop: KDE Plasma v: 6.7.4 Distro: EndeavourOS base: Arch Linux
Type: Desktop Mobo: Acer model: Aspire M1470 serial: <superuser required>
Firmware: UEFI vendor: American Megatrends v: P11-A1 date: 11/09/2012
Info: quad core model: AMD A6-3620 APU with Radeon HD Graphics bits: 64
type: MCP arch: K12 Fusion rev: 0 cache: L1: 512 KiB L2: 4 MiB
Speed (MHz): avg: 800 min/max: 800/2200 boost: enabled cores: 1: 800
2: 800 3: 800 4: 800 bogomips: 17567
Flags-basic: ht lm nx pae sse sse2 sse3 sse4a svm
Device-1: Advanced Micro Devices [AMD/ATI] Sumo [Radeon HD 6530D]
vendor: Acer Incorporated ALI driver: radeon v: kernel arch: TeraScale-2
bus-ID: 00:01.0
Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
compositor: kwin_wayland driver: X: loaded: radeon unloaded: modesetting
dri: r600 gpu: radeon resolution: 1024x768~60Hz
API: EGL v: 1.5 drivers: kms_swrast,r600,swrast platforms:
active: gbm,wayland,x11,surfaceless,device inactive: N/A
API: OpenGL v: 4.6 vendor: mesa v: 26.2.1-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD SUMO (DRM 2.51.0 / 7.2.2-arch1-1)
de: kscreen-console,kscreen-doctor wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] BeaverCreek HDMI Audio [Radeon
HD 6500D and 6400G-6600G series] vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:01.1
Device-2: Advanced Micro Devices [AMD] FCH Azalia
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:14.2
API: ALSA v: k7.2.2-arch1-1 status: kernel-api
Server-2: PipeWire v: 1.6.8 status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: e000
bus-ID: 01:00.0
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: f8:0f:41:6d:09:11
Local Storage: total: 275.74 GiB used: 49.81 GiB (18.1%)
ID-1: /dev/sda vendor: Samsung model: SSD 830 Series size: 238.47 GiB
ID-2: /dev/sdb vendor: Micron model: P300-MTFDDAC050SAL size: 37.26 GiB
ID-1: / size: 232.68 GiB used: 49.61 GiB (21.3%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 28.1 C mobo: N/A gpu: radeon temp: 26.0 C
Fan Speeds (rpm): N/A
Memory: total: 8 GiB note: est. available: 7.21 GiB used: 1.64 GiB (22.7%)
Processes: 206 Uptime: 3m Init: systemd
Packages: 1380 Compilers: gcc: 16.2.1 Shell: Bash v: 5.3.15 inxi: 3.3.41
wpctl status
PipeWire 'pipewire-0' [1.6.8, aspirem1470, cookie:3176846]
└─ Clients:
32. WirePlumber [1.6.8, aspirem1470, pid:703]
33. pipewire [1.6.8, aspirem1470, pid:705]
43. WirePlumber [client] [1.6.8, aspirem1470, pid:703]
59. kwin_wayland [1.6.8, aspirem1470, pid:768]
60. libcanberra [1.6.8, aspirem1470, pid:834]
61. [1.6.8, aspirem1470, pid:834]
62. xdg-desktop-portal [1.6.8, aspirem1470, pid:1013]
63. plasmashell [1.6.8, aspirem1470, pid:845]
64. libcanberra [1.6.8, aspirem1470, pid:845]
65. [1.6.8, aspirem1470, pid:845]
66. wpctl [1.6.8, aspirem1470, pid:3337]
Audio
├─ Devices:
│ 51. Internes Audio [alsa]
│ 52. Internes Audio [alsa]
├─ Sinks:
│ * 56. Internes Audio Analoges Stereo [vol: 1.00]
├─ Sources:
│ 57. Internes Audio Analoges Stereo [vol: 1.00]
├─ Filters:
└─ Streams:
Video
├─ Devices:
├─ Sinks:
├─ Sources:
├─ Filters:
└─ Streams:
Settings
└─ Default Configured Devices:
0. Audio/Sink alsa_output.pci-0000_00_14.2.analog-stereo
pacman -Qs pipewire
local/gst-plugin-pipewire 1:1.6.8-1
Multimedia graph framework - pipewire plugin
local/kpipewire 6.7.4-5 (plasma)
Components relating to pipewire use in Plasma
local/libpipewire 1:1.6.8-1
Low-latency audio/video router and processor - client library
local/libwireplumber 0.5.16-1
Session / policy manager implementation for PipeWire - client library
local/pipewire 1:1.6.8-1
local/pipewire-alsa 1:1.6.8-1
Low-latency audio/video router and processor - ALSA configuration
local/pipewire-audio 1:1.6.8-1
Low-latency audio/video router and processor - Audio support
local/pipewire-jack 1:1.6.8-1
Low-latency audio/video router and processor - JACK replacement
local/pipewire-pulse 1:1.6.8-1
Low-latency audio/video router and processor - PulseAudio replacement
local/qemu-audio-pipewire 11.1.1-1
QEMU PipeWire audio driver
local/wireplumber 0.5.16-1
Dann habe ich wohl noch ein Anliegen und zwar stimmt jetzt auch die Bildschirmauflösung nicht mehr. Statt der üblichen FullHD-Auflösung, gibt es nur noch 1024x768er-Auflösung.
