Hi all
my english is not perfect
I can no longer convert put mp3 in Ogg there is no longer the option in soundconverter any ideas?
Hi all
strange, on my machine i still have Ogg ![]()
yes I do not understand why I do not list them my version is as follows …
It doesn’t have any optional dependencies but perhaps it needs something else installed for that functionality?
I installed all the dependencies written on the wiki
Soundconverter doesn’t need any additional codecs for conversion. As far as I know, it utilizes gstreamer capabilities for decoding and encoding.
What is the output of yay -Qs gst-
I don’t like reading output in screenshots. I prefer text in code tags. ![]()
I’ve used soundconverter in the past, i sometimes encoutered some issue like no ogg, since i’ve moved to https://archlinux.org/packages/community/x86_64/ciano/
For me the best converters out there are XCFA (unluckily no further development by the, if I’m right, french developers; still keep a package of the last version as a backup, because no more availability in AUR) and Soundkonverter (most complete in my opinion; supports a ton of formats). I still hope that someone will pick up development of XCFA.
[psyderian@Andromeda ~]$ yay -Qs gst-
local/gst-libav 1.18.5-1
Multimedia graph framework - libav plugin
local/gst-plugin-pipewire 1:0.3.42-1
Multimedia graph framework - pipewire plugin
local/gst-plugins-bad 1.18.5-3
Multimedia graph framework - bad plugins
local/gst-plugins-bad-libs 1.18.5-3
local/gst-plugins-base-libs 1.18.5-1
Multimedia graph framework - base
local/gst-plugins-good 1.18.5-2
Multimedia graph framework - good plugins
local/gst-plugins-ugly 1.18.5-2
Multimedia graph framework - ugly plugins
local/gst-python 1.18.5-3
Multimedia graph framework - python bindings
do with the command yay -Qs gst-
I have already heard of ciano never try
I advanced on my side, I found by myself the solution to my problem it was a missing package … That digital ink for nothing … Thank you all the same for your help!
Additional output on my system, which provides ogg format in soundconverter :
local/gst-plugin-gtk 1.18.5-2
Multimedia graph framework - gtk plugin
local/gst-plugins-base 1.18.5-1
Multimedia graph framework - base plugins
Maybe installing those already solves the issue.
Edith says :
I accidentally deleted the package in my list, which would have solved the issue.
