After I did an online fresh install, my sound has not been working. Looking with pulseaudio, it is receiving the sound from my apps, but it just isn’t playing. Strangely enough, if I change the profile from my speaker (the only profile available to me), back and forth between Pro Audio and
“Play and record hi-fi quality music” it does play a blip of sound before cutting out again. If done enough times, it can work for whatever is open at the moment. Sometimes, after I close the pulseaudio application, the sound stops working.
You have to stop pulseaudio.socket and pulseaudio.service
Run sudo systemctl stop pulseaudio.service and sudo systemctl stop pulseaudio.socket
After stopping pulseaudio and testing that your audio is working, make sure the following packages are installed: pipewire-alsa, pipewire-pulse, wireplumber
They should be installed by default if you’ve just installed Endeavour, but there’s no harm in checking.
It says that pulseaudio socket and server weren’t loaded, I’m assuming because the application isn’t open. Pipewire-pulse and pulseaudio are in conflict with one another, so I’ll be uninstalling pulseaudio if its messing with my sound so much and that it wasn’t needed anyways.
this was the issue if pipewire-puls eis replacing pusleadio for compatibility … but a slong as pulseadio itself is installed it will cause confusion with pipewire.-.
