Hey, I installed Endeavour OS with GNOME yesterday. Unfortunately, I’m having an issue with the sound. On the login screen, there’s a sound icon, and the sound works. However, as soon as I log into my account, the sound stops working (the icon is also missing). After a fresh start, I run the following command: systemctl --user restart wireplumber pipewire pipewire-pulse , and everything starts working again. But after a restart, I have to run this command again to get the sound back.
After fresh start:
systemctl --user status wireplumber pipewire pipewire-pulse
● wireplumber.service - Multimedia Service Session Manager
Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
Active: active (running) since Thu 2023-09-07 10:06:46 CEST; 7min ago
Main PID: 1345 (wireplumber)
Tasks: 7 (limit: 19072)
Memory: 12.1M
CPU: 261ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
└─1345 /usr/bin/wireplumber
wrz 07 10:06:46 ms7c56 systemd[1260]: Started Multimedia Service Session Manager.
wrz 07 10:06:46 ms7c56 wireplumber[1345]: [0:00:16.504166544] [1345] ERROR IPAModule ipa_module.cpp:1>
wrz 07 10:06:46 ms7c56 wireplumber[1345]: [0:00:16.504175924] [1345] ERROR IPAModule ipa_module.cpp:2>
wrz 07 10:06:46 ms7c56 wireplumber[1345]: [0:00:16.504194574] [1345] INFO Camera camera_manager.cpp:>
wrz 07 10:06:48 ms7c56 wireplumber[1345]: GetManagedObjects() failed: org.freedesktop.DBus.Error.Name>
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
TriggeredBy: ● pipewire.socket
Main PID: 1344 (pipewire)
Tasks: 3 (limit: 19072)
Memory: 7.0M
CPU: 28ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─1344 /usr/bin/pipewire
wrz 07 10:06:46 ms7c56 systemd[1260]: Started PipeWire Multimedia Service.
● pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; enabled; preset: enabled)
TriggeredBy: ● pipewire-pulse.socket
Main PID: 1346 (pipewire-pulse)
Memory: 1.6M
CPU: 8ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
└─1346 /usr/bin/pipewire-pulse
wrz 07 10:06:46 ms7c56 systemd[1260]: Started PipeWire PulseAudio.
inxi -Fzxxxa
Kernel: 6.4.12-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: hpet,acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=a41bcd8b-d220-4506-bc87-f3dae74afe4e rw nowatchdog
nvme_load=YES resume=UUID=7bc6809b-98e0-4ad2-a000-37b481d4923a loglevel=3
Desktop: GNOME v: 44.4 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING PLUS (MS-7C56) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.E0
date: 07/03/2023
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
level: v3 note: check built: 2022 process: TSMC n6 (7nm) family: 0x19 (25)
model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2200 min/max: 2200/4650 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
bogomips: 88827
Vulnerabilities:
Type: gather_data_sampling status: Not affected
Type: spec_rstack_overflow mitigation: safe RET, no microcode
prctl
sanitization
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 2d:00.0
chip-ID: 1002:731f class-ID: 0300
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: AOC 27G2G4 serial: <filter> built: 2020
res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.6-arch1.4 renderer: AMD Radeon RX 5600 XT
(navi10 LLVM 16.0.6 DRM 3.52 6.4.12-arch1-1) direct-render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab38
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media Audio Adapter (Unitek Y-247A)
driver: cmedia_hs100b,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 0d8c:0014 class-ID: 0300
serial: <filter>
API: ALSA v: k6.4.12-arch1-1 status: kernel-api
Server-1: PipeWire v: 0.3.79 status: active (process) with:
1: pipewire-pulse status: active 2: wireplumber status: active
3: pipewire-alsa type: plugin 4: pw-jack type: plugin
tools: pactl,pw-cat,pw-cli,wpctl
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-3a5943beb073 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Local Storage: total: 1.49 TiB used: 22.66 GiB (1.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 42A4SANA temp: 37.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 033 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Ultra USB 3.0
size: 114.61 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: GPT
SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
ID-1: / raw-size: 96 GiB size: 93.93 GiB (97.85%) used: 10.32 GiB (11.0%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 71 GiB size: 69.33 GiB (97.65%)
used: 7.72 GiB (11.1%) fs: ext4 dev: /dev/sda6 maj-min: 8:6
ID-4: /var raw-size: 48 GiB size: 46.95 GiB (97.80%) used: 2.82 GiB (6.0%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: yes
compressor: zstd max-pool: 20%
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
mem: 52.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 610
Processes: 325 Uptime: 10m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 3.01 GiB (19.4%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages:
pm: pacman pkgs: 941 libs: 265 tools: yay Shell: Zsh v: 5.9
running-in: alacritty inxi: 3.3.29
