I installed endeavourOS 2day I was trying to get audio working but now I can’t even see the audio icon and I cannot even launch the sound manager pls send help
Please post the link from the command
inxi -Faz | eos-sendlog
Use of uninitialized value $val2 in string eq at /usr/bin/inxi line 6943.
Use of uninitialized value $val2 in split at /usr/bin/inxi line 6948.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6950.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6953.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6954.
% Total % Received % Xferd Average Speed Time Time Time Current
100 5595 0 24 100 5571 76 17778 --:--:-- --:--:-- --:--:-- 17875
https://clbin.com/ZpWe4```
Welcome @minku and thanks. First off you didn’t need to delete your post. You could have just edited it. Also you only have to post the link. It keeps things much cleaner and easier to read.
ah okay, sorry
No need to be sorry. I’m just trying to help you. I see that pipewire isn’t running.
Sound Server-1: ALSA v: k5.15.8-arch1-1 running: yes
Sound Server-2: PulseAudio v: N/A running: no
Sound Server-3: PipeWire v: N/A running: no
when I try running pipewire it returns this
pipewire: /usr/lib/libc.so.6: version `GLIBC_2.34' not found (required by pipewire)
pipewire: /usr/lib/libc.so.6: version `GLIBC_2.34' not found (required by /usr/lib/libpipewire-0.3.so.0)```
Try reinstalling it with the following first and then reboot.
sudo pacman -S pipewire pipewire-pulse --needed
when i try that it outputs this but i will restart anyways.
warning: pipewire-pulse-1:0.3.48-1 is up to date -- skipping
there is nothing to do
update: yeah nothing happened
Try removing pipewire and revert to pulse audio.
sudo pacman -S pulseaudio
I tried doing that before, nothing happened, even after a restart.
Try it and see what it shows after reboot.
inxi -Aa
output post reboot
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
I dont know why pipewire is still there and why pulseAudio isnt running
pipewire-alsa
Maybe it needs pipewire-alsa as @Shjim say’s.
sudo pacman -S pipewire-alsa
sadly nope : ( still doesnt work, theres no change : /
Well it is probably picking up the wrong sound device. What does alsamixer show? Post an image.
alsamixer
I cant launch alsamixer for some reason it shows this
ALSA lib dlmisc.c:337:(snd_dlobj_cache_get0) Cannot open shared library libasound_module_ctl_pipewire.so (/usr/lib/libc.so.6: version `GLIBC_2.34' not found (required by /usr/lib/libpipewire-0.3.so.0))
There seems to be an issue with the GLIBC_2.34 file. ![]()
how do i fix that?
