Sound not working on iMac 2017 21.5 inch model
I have an iMac 2017 21.5 inch model, which I installed EndeavourOS on. The sound NEVER works, on Endeavour OS. I tried searching up on the internet and saw a solution on the Manjaro forums which called for running echo 'options snd-hda-intel model=imac27' | sudo tee -a /etc/modprobe.d/sound.conf And yeah it did work but the sound quality was tinny and the solution was temporary, it just stopped working, the sound dosent work.
Here is my inxi output:
  Kernel: 6.1.23-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-linux-lts
    root=UUID=3ff9269d-dd56-4398-9f6d-729238a100de rw nowatchdog nvme_load=YES
    loglevel=3
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Apple product: iMac18,1 v: 1.0
    serial: <superuser required> Chassis: type: 9 v: Mac-4B682C642B45593E
  Mobo: Apple model: Mac-4B682C642B45593E v: iMac18,1
    serial: <superuser required> UEFI: Apple v: 451.140.1.0.0 date: 04/11/2022
Battery:
  Message: No system battery data found. Is one present?
Memory:
  RAM: total: 7.63 GiB used: 3.04 GiB (39.9%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges required.
  Info: model: Intel Core i5-7360U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
    family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF0
  Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache:
    L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 400 min/max: 400/3600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 18406
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat
    arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
    clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Vulnerabilities:
  Type: itlb_multihit status: KVM: VMX disabled
  Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT
    vulnerable
  Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
  Type: retbleed mitigation: IBRS
    prctl
    sanitization
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Type: tsx_async_abort mitigation: TSX disabled
  Device-1: Intel Iris Plus Graphics 640 vendor: Apple driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5926
    class-ID: 0300
  Device-2: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
    bus-ID: 1-3:2 chip-ID: 05ac:8511 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22")
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: Apple iMac built: 2012 res: 1920x1080 hz: 60
    dpi: 103 gamma: 1.2 size: 475x267mm (18.7x10.51") diag: 545mm (21.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel Iris Plus Graphics 640
    (Kaby Lake GT3e) (KBL GT3) direct-render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71
    class-ID: 0403
  API: ALSA v: k6.1.23-1-lts status: kernel-api tools: alsamixer,amixer
  Server-1: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
  Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
    driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 14e4:43ba class-ID: 0280
  IP v4: <filter> type: noprefixroute scope: global broadcast: <filter>
  IP v6: <filter> type: noprefixroute scope: link
  Device-2: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe driver: tg3
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
    chip-ID: 14e4:1686 class-ID: 0200
  IF: enp3s0f0 state: down mac: <filter>
  WAN IP: <filter>
Bluetooth:
  Device-1: Apple Bluetooth USB Host Controller type: USB
    driver: btusb,hid-generic,usbhid bus-ID: 1-9:6 chip-ID: 05ac:8296
    class-ID: fe01
  Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
Logical:
  Message: No logical block device data found.
RAID:
  Message: No RAID data found.
  Local Storage: total: 931.51 GiB used: 23.09 GiB (2.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: HDD HTS541010A9E632
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 5400 serial: <filter> rev: B5N0 scheme: GPT
  Message: No optical or floppy data found.
  ID-1: / raw-size: 735.54 GiB size: 722.92 GiB (98.28%) used: 22.97 GiB (3.2%)
    fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: endeavouros
    uuid: 3ff9269d-dd56-4398-9f6d-729238a100de
  ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.44%)
    used: 128.3 MiB (65.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
    uuid: 2860-11F4
  Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
  ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda5 maj-min: 8:5 label: linux swap
    uuid: 475097bd-9e15-40ee-adb3-b8e9a5eac863
Unmounted:
  ID-1: /dev/sda2 maj-min: 8:2 size: 185.87 GiB fs: apfs label: N/A
    uuid: 7ca69e63-8506-474d-804a-343d52996a1e
  ID-2: /dev/sda3 maj-min: 8:3 size: 7.91 GiB fs: vfat label: EOS_202303
    uuid: 6E2F-1F1B
USB:
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
    speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
  Device-1: 1-3:2 info: Apple FaceTime HD Camera (Built-in) type: Video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
  Hub-2: 1-5:3 info: Apple Hub in Aluminum Keyboard ports: 3 rev: 2.0
    speed: 480 Mb/s power: 300mA chip-ID: 05ac:1006 class-ID: 0900
  Device-1: 1-5.2:5 info: Apple Aluminum Keyboard (ISO) type: Keyboard,HID
    driver: apple,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s power: 20mA
    chip-ID: 05ac:0221 class-ID: 0300
  Device-2: 1-6:4 info: Apple Mighty Mouse [Mitsumi M1152] type: Mouse
    driver: apple,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s power: 100mA
    chip-ID: 05ac:0304 class-ID: 0301
  Device-3: 1-9:6 info: Apple Bluetooth USB Host Controller
    type: Keyboard,Mouse,Bluetooth driver: btusb,hid-generic,usbhid interfaces: 6
    rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:8296 class-ID: fe01
  Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
    chip-ID: 1d6b:0003 class-ID: 0900
  Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 34.0 C mobo: N/A
  Fan Speeds (RPM): N/A
  Processes: 194 Uptime: 3h 29m wakeups: 4 Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 Packages: 1162
  pm: pacman pkgs: 1138 libs: 300 tools: trizen,yay pm: flatpak pkgs: 24
  Shell: fish v: 3.6.1 running-in: kitty inxi: 3.3.26
Here is my output from lspci -v | grep -i audio:
frizzfrizzlol@endeavourlxr ~> lspci -v | grep -i audio
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
Here is my output from aplay -lL(lL is a lowercase L and an Uppercase L next to eachother):
frizzfrizzlol@endeavourlxr ~> aplay -lL
null
    Discard all samples (playback) or generate zero samples (capture)
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pipewire
    PipeWire Sound Server
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Default ALSA Output (currently PipeWire Media Server)
sysdefault:CARD=PCH
    HDA Intel PCH, CS8409/CS42L83 Analog
    Default Audio Device
front:CARD=PCH,DEV=0
    Front output / input
surround21:CARD=PCH,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
hdmi:CARD=PCH,DEV=0
    HDA Intel PCH, HDMI 0
    HDMI Audio Output
hdmi:CARD=PCH,DEV=1
    HDA Intel PCH, HDMI 1
    HDMI Audio Output
hdmi:CARD=PCH,DEV=2
    HDA Intel PCH, HDMI 2
    HDMI Audio Output
usbstream:CARD=PCH
    HDA Intel PCH
    USB Stream Output
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: CS8409/CS42L83 Analog [CS8409/CS42L83 Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 0/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 0/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 0/1
Hope this helps you figure out the problem. I appreciate any help. Thank you.
With pipewire server in use,
did you ever do the followings after installation?
  1. init or restart pipewire
    systemctl --user daemon-reload
    systemctl --user --now enable pipewire pipewire-pulse wireplumber
  2. local configuration (This is the pipewire’s way of configuration)
    copy /usr/share/wireplumber to ~/.config/wireplumber (for wireplumber)
    copy /usr/share/pipewire/client.cont, jack.conf, pipewire.conf, pipewire-pulse.conf to ~/.config/pipewire/client.cont, jack.conf, pipewire.conf, pipewire-pulse.conf
  3. global configuration (This is the pipewire’s way of configuration)
    copy /usr/share/wireplumber to /etc/wireplumber (for wireplumber)
    copy /usr/share/pipewire/client.cont, jack.conf, pipewire.conf, pipewire-pulse.conf to /etc/pipewire/client.cont, jack.conf, pipewire.conf, pipewire-pulse.conf
  4. local configuration for pavucontrol (each run of pavucontrol will search the local file client.conf)
    copy /etc/pulse/client.conf to ~/.config/pulse/client.conf (change the property of client.conf to readable and writable for user-name)
    autospawn = no
If not, please just do it, reboot, and see what happens?
run pavucontrol to check configured output devices.
run media-player to test play works.
Different person than op, same issue - installed EndeavorOS on a 2015 iMac (16,2), everything is working except sound. I tried yhcheng888’s suggestions - no joy, still no audio output. Anyone have any additional suggestions? I’ve searched this forum as well as the arch forum.
$ inxi -A
Device-1: Intel Broadwell-U Audio driver: snd_hda_intel
Device-2: Intel 9 Series Family HD Audio driver: snd_hda_intel
API: ALSA v: k6.3.2-arch1-1 status: kernel-api
Server-1: PipeWire v: 0.3.70 status: active
No joy with Endeavor, installed Debian Testing (as an FYI, neither Endeavor nor Debian is dual booted with macOS), was able to get sound working:
systemctl --user --now enable wireplumber.service
Will attempt again with Endeavor when I have the time.
Different issue but worth mentioning - both Endeavor/Gnome and Debain/Gnome both crash and reboot when the machine suspends. I’ve set it to not suspend when idle, that seems to have cured it.
This Arch Linux post was about the same sound card (possibly not an iMac, though)
https://bbs.archlinux.org/viewtopic.php?id=265211
