Sound Issue
I just got a laptop and installed Endeavor OS on it with the KDE Plasma desktop environment, since I already installed it this way on my desktop and it’s been working beautifully there, however I seem to be having a problem with my audio. Audio does not play at all, nor does it seem to detect the laptop’s built in microphone. When I go to the audio settings, it lists several audio devices, seemingly associated with the different cores on the cpu. None of them play any sound when I go between them. Attempting to change the audio device, the only option seems to be “Pro Audio”.
Honestly, I’m not sure where to begin with this problem. I’m not sure if its a problem with Endeavor, KDE, Linux, or the laptop hardware itself. Any help?
What choices do you get in the drop-downs?
These are mine…
Just “Off” and “Pro Audio”, on both playback devices and recording devices
Post the output of the following, It will provide your system’s audio and driver info.
inxi -Aaz
Please use the preformatted text option when posting terminal output.
  Device-1: Intel Core Ultra Processors HD Audio vendor: Lenovo
    driver: sof-audio-pci-intel-ptl
    alternate: snd_sof_pci_intel_ptl,snd_hda_intel bus-ID: 00:1f.3
    chip-ID: 8086:e428 class-ID: 0401
  API: ALSA v: k6.18.63-3-lts status: kernel-api
  Server-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctl
  Server-2: PipeWire v: 1.6.11 status: active with: 1: pipewire-pulse
Welcome to the community @CyberValkyrie :waving_hand::smiley: :enos_flag:
Just expanding a little on @UncleSpellbinder’s command, could you share the output of this command too? (it does overlap with @UncleSpellbinder’s):
inxi -SMAxx --za
  Kernel: 6.18.63-3-lts arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
  Desktop: KDE Plasma v: 6.8.3 tk: Qt v: N/A wm: kwin_wayland dm: N/A
  Type: Convertible System: LENOVO product: 83TE v: Yoga 7 2-in-1 16IPH11
    serial: <superuser required> Chassis: type: 31 v: Yoga 7 2-in-1 16IPH11
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76574 WIN
    serial: <superuser required> part-nu: LENOVO_MT_83TE_BU_idea_FM_Yoga 7
    2-in-1 16IPH11 Firmware: UEFI vendor: LENOVO v: T7CN18WW date: 04/20/2026
    driver: sof-audio-pci-intel-ptl bus-ID: 00:1f.3 chip-ID: 8086:e428
Just to begin with, are you able to confirm the issue persists when you boot into the mainline (non-LTS) kernel?
It does persist, though I now have a “Stereo Output” option on the devices dropdown. This option also does not seem to work
Are you able to plug a pair of headphones in and see if those work?
Use the “Stereo Output” setting.
Headphones do work, with both “Pro Audio” and “Stereo Output”
Sorry, I should have noted this, but just confirming, those headphones are plugged into the 3.5mm audio jack, not a USB port?
Correct, just directly into the headphone jack
Without the headphones plugged in, if you crank the volume, do you hear anything at all? Even something tinny?
Nothing at all
There is an issue reported here:
This workaround was shared. You may like to give it a go?
Workaround (confirmed working, survives jack events and reboot)
  • amixer -c 0 sset Dmic0 cap and amixer -c 0 sset 'Headset Mic' on, then alsactl store
  • WirePlumber rule setting api.alsa.use-acp = false for alsa_card.pci-0000_00_1f.3-platform-sof_sdw
Was able to quite easily put in those commands for the first part of the workaround, but I’m not sure where that setting is located for WirePlumber or how exactly to change it.
I’d just like to confirm your PCI address matches what was shared in that GitHub issue. Can you please share the output of:
lspci -Dnnk | grep -A4 -iE 'audio|multimedia'
0000:00:1f.3 Multimedia audio controller [0401]: Intel Corporation Core Ultra Processors (Series 3) HD Audio [8086:e428] (rev 01)
	Subsystem: Lenovo Device [17aa:380b]
	Kernel driver in use: sof-audio-pci-intel-ptl
	Kernel modules: snd_sof_pci_intel_ptl, snd_hda_intel
0000:00:1f.4 SMBus [0c05]: Intel Corporation Core Ultra Processors (Series 3) SMBus [8086:e422] (rev 01)
	Subsystem: Lenovo Device [17aa:3845]
	Kernel driver in use: i801_smbus
This’ll create a WirePlumber config path in your user config folder. If you need this system wide (multiple users), you might create this under /etc/wireplumber/wireplumber.conf.d/ instead.
mkdir -p ~/.config/wireplumber/wireplumber.conf.d
Create and edit your custom config file:
nano ~/.config/wireplumber/wireplumber.conf.d/99-test-disable-acp.conf
Paste this into it:
monitor.alsa.rules = [
    matches = [
        device.name = "alsa_card.pci-0000_00_1f.3-platform-sof_sdw"
    actions = {
      update-props = {
Then restart your wireplumber service:
systemctl --user restart wireplumber
Please note, I’m not able to test this :downcast_face_with_sweat:
Guided in part by:
